12-24-2015, 03:37 AM | #121 |
RCC Addict Join Date: Oct 2014 Location: UK
| Re: Bent my first SSD axle today....disappointed
RPP might have them next week. It is holiday season so shipping times may not be predictable...
12-24-2015, 07:22 AM | #122 |
Rock Stacker Join Date: Nov 2015 Location: Lubbock
Completely understandable SSD, thanks for the update. Your involment in this thread is the main reason I'm ordering. Shows outstanding customer service and dedication to the hobby.
12-24-2015, 08:24 AM | #123 |
Rock Crawler Join Date: Nov 2012 Location: Charlotte
I'm impressed that SSD designed and got a solution put together so quickly. Well done!!
12-30-2015, 12:03 PM | #124 |
Quarry Creeper Join Date: Nov 2014 Location: WA
Very nice solution. Reminds the MIP. Is the hex have a set screw? Also will be nice have another part number with this HD axle built-in a wide diamond axle a for the yetis, so the new buyers already get this without need to go thru non-HD axle. |
12-30-2015, 04:45 PM | #125 |
RPP has these in stock now for anyone wanting them.
12-30-2015, 06:46 PM | #126 |
Quarry Creeper Join Date: Dec 2013 Location: NoVa
Got mine ordered from RPP this evening...
12-30-2015, 09:18 PM | #127 |
housing and new HD shafts have been ordered. Is it stupid that I'm pumped about getting them in?
12-30-2015, 11:14 PM | #128 |
Mine are on the way !!
01-04-2016, 09:00 AM | #129 |
Mine should be here today as long as the post office doesn't forget to put it in my mailbox.
01-06-2016, 04:25 PM | #130 |
Newbie Join Date: Sep 2015 Location: Washington, DC
Good News! My axle shafts came in today! I hope this set works out better than the last 3 sets. They look strong and the design makes a lot of sense. Can't help but to wonder why this wasn't the original design. |
01-06-2016, 07:22 PM | #131 |
Newbie Join Date: Jul 2015 Location: Lenoir City, TN
Got my new axle and diamond skid in today! Can't wait to get everything all back together. Does anybody know if the vanquish or strc rear lower shock mount will work with this axle? Thanks. Sorry if it's been asked already. |
01-06-2016, 07:27 PM | #132 |
I'm using the VP ones on mine
01-07-2016, 09:36 AM | #133 |
Hey Steven, Who did you get the skid from, I can't seem to find it in stock anywhere? |
01-12-2016, 06:00 PM | #134 |
I wanna be Dave Join Date: Apr 2015 Location: Roseville, Ca
Is anyone running the new HD shafts? Haven't heard anything so I'm assuming there holding up? Curious if theres any slop between the shaft and keyed hex? I hope not.
01-12-2016, 07:36 PM | #135 |
Can anyone confirm or deny vp currie centered shafts fit in ssd centered housing?
01-12-2016, 07:39 PM | #136 |
From what I understand these were tested before released, I'd assume you are good. Every one I bent was at that pin, removing that pin was a logical idea. Mine should be here any day, but weather is probably going to slow my using them... |
01-12-2016, 10:16 PM | #137 | |
Rock Crawler Join Date: May 2007 Location: Corona, CA
| Re: Bent my first SSD axle today....disappointed Quote:
So being a machinist I am kinda disappointed on how much slop is in the hex. It could be tighter, but I am not drive line expert and also don't mass produce things so I do understand there is some variance that can happen when things get mass produced. Of course this is just a observation with out actual drive time. But I do believe these shafts will be much better than stock. On paper the stats look great but we will see. | |
01-13-2016, 03:40 PM | #138 |
Anybody having an issue with the wheel nuts staying tight? Using the stock ssd axle. Only one side keeps backing off.
01-13-2016, 04:28 PM | #139 |
Haven't had to chance to run mine much because of the weather but what I have done doesn't show there being an issue.
01-13-2016, 05:28 PM | #140 |
| Re: Bent my first SSD axle today....disappointed That wasn't a SSD issue, that's a yeti thing. Make sure it's really clean, thread lock and I ended up using a m4 jam nut too. The speed and shock loosen that nut. It's only one side cause the other one tightens from the exact same force
Bent my first SSD axle today....disappointed - Similar Threads | ||||
New SSD SCX10 axle housings | STANG KILLA SS | Axial SCX-10 | 1394 | 03-10-2023 08:34 AM |
SSD Rear Axle | Hunter711 | Axial Yeti | 152 | 09-09-2019 12:56 PM |
SSD New wraith axle housing | Szczerba | General Crawlers | 180 | 03-01-2016 08:19 PM |
Bent an Axle shaft today | JavelinSST390 | HPI Wheely King | 3 | 08-19-2007 06:30 PM |
