07-01-2016, 01:23 AM | #21 |
Quarry Creeper Join Date: Jun 2016 Location: Prague - Czech Republic
| re: Life of one YETI - Tom Frajer's Axial Yeti build log
Yesterday I prepared new motor, ESC and servo. Just connected everything up with castle link and castle quick connect on my table, calibrated, tweaked some settings using Castle Link software. Nothing much to show yet, but everything is working perfectly I did not put any electronics to my Yeti yet because I'm still waiting for this Liquid Electrical Tape so I can wyterproof my new receiver PCB. Hopefully I will do this today and then move on with instalation. |
07-01-2016, 05:37 PM | #22 |
Waterproofing receiver... |
07-01-2016, 05:41 PM | #23 |
Waterproofing servo. Seems like there is some coating but I was worried as it looks very uneven an thin on some spots. I used some liquid tape on top of it... And then filled up with dielectric silicone grease. And it is ready |
07-01-2016, 05:47 PM | #24 |
Mamba Monster X is bigger than stock ESC so I needed to clear some space for it... Then glued some plastic pad to raise it above screw hubs... Testing new ESC and motor combo... |
07-02-2016, 02:43 AM | #25 |
RCC Addict Join Date: Jun 2016 Location: Germany
I have the same ESC , my Yeti is the kit version and there is a plate included to mount bigger esc's . Nice build btw, looks a little bit like mine |
07-02-2016, 02:52 AM | #26 | |
| re: Life of one YETI - Tom Frajer's Axial Yeti build log Quote:
I hope I will put everything together today so I can test drive it tommorow. Hopefully I will not tear it into pieces - we will see Last edited by TomFrajer; 07-02-2016 at 02:54 AM. | |
07-02-2016, 01:55 PM | #27 |
| re: Life of one YETI - Tom Frajer's Axial Yeti build log |
07-02-2016, 01:59 PM | #28 |
New HH servo in place, ESC ready to mount... ESC mounted, receiver box stuffed with CC quick connect, receiver and lot of wires. Ready for motor&transmission installation... |
07-02-2016, 05:37 PM | #29 |
Ready to go! After test run. Everything OK. Steereing is razor sharp and fast. New suspension is great - almost no rollovers in full speed (2s, stock gearing) on asphalt - it is skidding Very happy with this! |
07-02-2016, 07:18 PM | #30 |
Rock Crawler Join Date: Mar 2016 Location: HB
Swap your front left and right rear tires, they're mounted backward. Build looks good. If your running fast, you might look into the HR front sway bar. It made a big difference on mine. Sounds like it's dialed in pretty good though if your not experiencing the yeti roll
07-03-2016, 03:45 AM | #31 | |
07-03-2016, 04:04 PM | #32 |
Work in progress... |
07-04-2016, 12:12 PM | #33 |
Newbie Join Date: May 2016 Location: Lodi
07-04-2016, 12:20 PM | #34 |
07-04-2016, 01:30 PM | #35 |
| re: Life of one YETI - Tom Frajer's Axial Yeti build log Perfect! Thank you, this is really great and I will definitely buy it for my Yeti. If you have any other suggestions for better durability based on what is already used on my build, please go ahead |
07-04-2016, 04:05 PM | #36 |
i did something similar to mine but diy style. without modifying the a-arm, i took just two alu tubes m4 and m5 innerdiameter 3mm and 4mm cut them to fill the gab where the hinge pin is free (18mm) to support the hinge pin without weakening the a-arm. at the next hit the a-arm and hinge pin still as new. broke my plastic steering knukle, vp waiting to install... on the nexT hit i bet, either the a-arm or c-hub will break. an aftermarket c-hub and stock a-arm are on the way. just incase i will leave the a-arm as my weak point like in the rear tthe wbhd. |
07-04-2016, 10:41 PM | #37 |
| re: Life of one YETI - Tom Frajer's Axial Yeti build log Looks good man, only suggestion is to get that reciever out of its hole and get it into the " fuel cell" , id drop a pic but cant seem to get this to take it.
07-04-2016, 10:42 PM | #38 |
Pardon guys, 47 yrs old here, how do you get allowed to post pics on this forum ?
07-04-2016, 11:58 PM | #39 |
Move that receiver out of its hole and into the " fuel cell" , any water above the pan and your day is over... ask me how i know LoL. added a switch from an rc airplane and got the out of the silly stock location , looks factory to me. Pardon so dirty, she had a long day today. |
07-05-2016, 04:56 AM | #40 |
| re: Life of one YETI - Tom Frajer's Axial Yeti build log I sealed it already very well in original receiver box and I will keep it there as I do not want to diasassemble it again. Should be OK, and it is lower than fuel cell box - this should be better to put weight lower.
Life of one YETI - Tom Frajer's Axial Yeti build log - Similar Threads | ||||
Tom G’s RedBull Yeti | Tom G | Axial Yeti | 3 | 07-05-2016 08:45 PM |
Yeti, Set, GO!!! FastEddy Bearings for the Axial Yeti | FastEddy | Axial Yeti | 13 | 04-21-2015 07:33 AM |
Yeti Located - Axial Yeti bashing | eunique | Scale Videos! | 0 | 02-12-2015 08:42 AM |
Yeti Located - Axial Yeti bashing | eunique | Scale Videos! | 0 | 01-09-2015 02:10 AM |
