08-18-2017, 09:51 PM | #81 |
Quarry Creeper Join Date: Dec 2016 Location: Orange County
| Re: From the "tub up" I have my fingers all over this thing more than my first girlfriend... My question is (turbodan, I was looking at your post) ssd 2 speed conversion shift lever definitely has a flop. Is AX31183 truly necessary? http://www.rccrawler.com/forum/attac...1&d=1503114652 Last edited by Cheez; 08-19-2017 at 05:40 PM. |
08-19-2017, 10:56 AM | #82 |
Pebble Pounder Join Date: Feb 2015 Location: Bay area
I've always wondered about the differences between a build like this with aluminum everything, vs one with only carefully placed metal bits. I can only imagine that much extra weight will take its toll. Either way, looks good, hope it runs well! |
08-21-2017, 05:24 PM | #83 |
Okay guys, I need help! Is the axle built wrong? The housing points down and only rotates further down. Probably something silly, my inexperience is showing http://www.rccrawler.com/forum/attac...1&d=1503357842 |
08-21-2017, 11:24 PM | #84 | |
Quarry Creeper Join Date: Aug 2016 Location: British Columbia
| Re: From the "tub up" Quote:
08-22-2017, 09:00 AM | #85 |
Rock Crawler Join Date: Mar 2016 Location: HB
Yep, wrong hole. Move it to the lower hole. The mounts you are using are actually for the RR10 Bomber. |
08-22-2017, 03:49 PM | #86 |
Thanks guys for the input....after disassembling and reassembling every possible combination I find that the lower hole on the axle mount makes only a slight difference. This is the product description for the mount..."Vanquish Products AR60 Dual Shock/Link Mounts for AR60 Axles. Shock and link locations are threaded for easier installation. Designed to work with stock AR60 axle housings as well as Vanquish V2 axle housings". It says nothing about being for the Bomber. I'm thinking the problem is with the upper links being to short. I unscrewed a rod end on each one and that lessened the axle downward tilt. The threads on the links are stupidly short so in order to get a "normal " looking rear axle I would have to unscrew the four rod ends about 1/2 way off. So Vanquish titanium upper links are on the way. |
08-23-2017, 01:02 PM | #87 |
Your other option would be to use the longer Jato rod ends but that's just asking for rod end failure. Youll be happy with the VP links. I've only busted 2 rodends in a year and I launch my yeti pretty good
08-24-2017, 10:38 AM | #88 |
Question for those of you that have SSD 2 speed conversion and Axial shift support AX31183. My servo tie rod has a tllt of 4-8 degrees, it's just a little less than pictured ( nothing is secure yet). I know it's mentioned that it should be as parallel as possible, but will this be ok? http://www.rccrawler.com/forum/attac...1&d=1503592649 |
08-25-2017, 02:29 PM | #89 |
A shoutout to Chris at SSD getting back to me so quickly regarding this and letting me know that it should be ok. It's all about bench testing before hittin' da rocky road. Last edited by Cheez; 08-25-2017 at 02:31 PM. |
08-25-2017, 06:01 PM | #90 |
Starting to get tingly looking forward to scratching it up and getting it dirty. HH motor/esc still weeks away. http://www.rccrawler.com/forum/attac...1&d=1503705372 http://www.rccrawler.com/forum/attac...1&d=1503705372 http://www.rccrawler.com/forum/attac...1&d=1503705372 http://www.rccrawler.com/forum/attac...1&d=1503705372 |
08-31-2017, 05:29 PM | #91 |
Couple of Yeti's hanging out waiting for a motor http://www.rccrawler.com/forum/attac...1&d=1504222127 Last edited by Cheez; 08-31-2017 at 05:39 PM. |
09-02-2017, 03:38 PM | #92 |
Added GPM front sway bar, probably not needed, but what the heck more bling. This ultimately may be an exercise in futility but maybe not. Minimal crawling/zero jumping. Thinking about going with Pro-Line Ultra Reservoir Shocks 105mm Fr/Re Rock Racers for the front. Seriously considering Motor Option1 x Puller Pro BL 540 Standard 2700kv - Waterproof $125.99 ESC Option1 x Holmes Hobbies TrailMaster BLE Pro Waterproof $134.99 I'm open to opinions. This is a no budget project but my allowance is slow in coming http://www.rccrawler.com/forum/attac...1&d=1504388248 |
09-04-2017, 01:23 PM | #93 | |
Quarry Creeper Join Date: Jul 2017 Location: Sweden
09-05-2017, 10:45 AM | #94 | |
I'm really enjoying the build, researching wheels and tires now, haven't decided whether to go with panels or body. Maybe both Looking forward to pictures of your build | |
09-05-2017, 12:01 PM | #95 |
RCC Addict Join Date: Jun 2016 Location: Germany
Regarding tires may have a look at the hyrax i use them in my AX10. They will be also great at the Yeti with 2 Stage proline foams or CI. The included ones are too soft and without sidewall support. Also nice are the Voodoo klr have the Gold comp. on ssd rockracer. Bombproof ... Rc ... Yeti never Gesendet von meinem Nexus 5 mit Tapatalk |
09-06-2017, 09:05 AM | #96 |
| Re: From the "tub up" http://www.rccrawler.com/forum/attac...1&d=1504710242 Considering these....anyone have them? |
09-06-2017, 11:57 AM | #97 | |
09-10-2017, 06:32 PM | #98 |
Added Pro-Line ultra reservoir 105 mm shocks Looking forward to seeing how they work out. http://www.rccrawler.com/forum/attac...1&d=1505089850 http://www.rccrawler.com/forum/attac...1&d=1505089850 |
09-11-2017, 04:15 PM | #99 |
| Re: From the "tub up" http://www.rccrawler.com/forum/attac...1&d=1505089850 Pulled the trigger on these. |
09-14-2017, 05:06 PM | #100 |
Happy to see the mailman today I plan on going with ottsix Voodoo u-4 silver and CI Deuces Wild. http://www.rccrawler.com/forum/attac...1&d=1505430144 Last edited by Cheez; 09-14-2017 at 05:21 PM. |
