11-10-2010, 07:18 PM | #801 |
Quarry Creeper Join Date: Jun 2009 Location: Visalia, CA
I did not know where else to post this question but here it is, I bought a used FXR in the FS section and it does not have the gold colored solder posts. I dont like how some of the wires are soldered to the bottom of the electronics board that is exposed and want to re solder them to the top (also has a broken capacitor). Is this normal in an older FX-R or do I need to replace the solder posts. I just don't want to ruin it. Thanks for any help.
11-10-2010, 09:24 PM | #802 |
I wanna be Dave Join Date: Jun 2004 Location: Whales
You just have to be VERY careful not to cross solder the connections. For a setup like that, I like to tin a piece of wire and then cut it about 1/16" long (the tined part), then place the wire through the post hole and solder the back side. That way the wire coating is covering the wire all the way down to the board and it's very nice and clean on the backside. The cap can be soldered to the wire in a variety of ways, but the closer to the board the better Enjoy!!! Last edited by kaetwo; 11-11-2010 at 10:06 AM. |
11-11-2010, 09:21 AM | #803 |
Pebble Pounder Join Date: Mar 2008 Location: El Dorado Hills, Ca
The posts are there for a reason. They act as a heatsink. However some are succesful with removing them and running the unit. We of course don't reccomend this as it's consider modifying the unit and voids the warranty. If you want it fixed you're better off sending it to us.
11-16-2010, 03:33 AM | #804 |
Newbie Join Date: Feb 2010 Location: Melbourne Australia
Hey guy's, I'm looking at getting the FXR/35T combo for my scx10,it has a bluebird 14kg/190oz servo,I'm a bit concerned about heat issue's as i will putting the esc in a plastic box as i do a lot of water and mud driving in the winter,summer time the lid would be off but in winter it be sealed shut,i have read a lot of good things about this speedy but are worried about it getting to hot,i run 7.2v nimh's and a winch (2ch radio so i have a steering/winch switch) i would rather use the internal bec as an external bec is just one more thing to keep dry, The box would be the same size as the one below,it has the RX and the winch controller in it ,any thoughts would be greatly appreciated, Last edited by Trex; 11-16-2010 at 05:15 AM. |
11-16-2010, 11:14 AM | #805 |
I mount mine in the Axial electronics box and it works great in the winter. It's cool enough that I don't worry about it, however in the summer, you would want to check the temperature once in a while to make sure that it doesn't get too toasty. |
11-16-2010, 08:33 PM | #806 |
| Thanks matey i didn't even think of the axial box,i will find it and put the esc in there in the summer time it wont need it to be waterproof so i will leave the lid off,this is a very informative thread,good work guys |
11-30-2010, 02:46 PM | #807 |
Randy P, so if I were to send the ESC to you the posts could be added? How about the cap and some wire leads off each post so that I could just add the connectors I need. How about the cost and a time line? This is the last part of my Wreckluse build and am anxious to finish. A pm would be greatly appreciated as I get an alert on my phone when I have a message on the forum. Thank you, Ron (Nor Zepol)
10-01-2011, 02:14 PM | #808 |
Newbie Join Date: Oct 2011 Location: Detroit
great review...I think i will purchase two as well...Very informative thanks! |
12-23-2011, 11:49 AM | #809 |
Pebble Pounder Join Date: Nov 2011 Location: Yucca Valley
| Re: Kaetwo's Tekin FX-R Review...
Having an odd issue with my new fxr's, everything wired and good to go all responds ok thanks to Harley's 4 pl how to. Thing is when doing the one touch setup i had to use rev(push trigger forward) to get the esc to recognize my input then neutral and then forward(trigger pulled back) when all is done it responds fine its just that i have a higher speed in reverse than i do in forward. All EPA's were set to zero before the one touch programming was performed as well. Only thing i can think of is i have the reverse dialed down through my tekin hotwire and maybe its interpreting forward for reverse through the one touch setup. Any help would be great. Happy holidays to all!!!
12-23-2011, 12:44 PM | #810 | |
Rock Crawler Join Date: Oct 2009 Location: Brussels
| Re: Kaetwo's Tekin FX-R Review... Quote:
Thanks all | |
12-23-2011, 01:40 PM | #811 |
Im gonna dail the reverse up through the hotwire when i get home and see if it goes full speed in forward then. If it does that will tell me it is confused on fwd and rev. Where ill go from there im not sure...... I guess ill just start trying to figure out where to set my controls to rev instead of normal or keep reverse up all the way on the esc's and set the rev EPA with the 4pl
12-23-2011, 03:02 PM | #812 |
It's a Futaba thing, set the throttle servo to reverse on the radio and all will work correctly.
12-23-2011, 04:34 PM | #813 |
| Re: Kaetwo's Tekin FX-R Review... |
06-21-2012, 08:46 AM | #814 |
Newbie Join Date: Apr 2012 Location: China
VERY nice review. And a very long lived thread. LOL. Sorry I skipped the 40 pages between 1 and 41, maybe the answer to my question is in there somewhere :-) I will get a FX-R for my Axial Wraith for crawling. I will also consider to go 3S LiPo (now I'm using 7.2V NiMh). What would be the best choice of motor in your opinnion? 35T, 45T or 55T Keep Rockin' |
06-25-2012, 08:45 AM | #815 | |
Pebble Pounder Join Date: Aug 2011 Location: Aiken
If your going to run a 3s you would need a 35t or less. | |
06-25-2012, 11:55 AM | #816 |
Pebble Pounder Join Date: Feb 2012 Location: wooster
06-25-2012, 12:00 PM | #817 |
Yashua Join Date: Sep 2010 Location: Learn the parable of the fig tree
Can someone explain the differances between a FXR and a FXR Pro? Is it that the FXR Pro will handle a little more power? |
06-25-2012, 12:02 PM | #818 |
06-25-2012, 12:06 PM | #819 | |
Controls: Forward/Brake/Reverse ON Resistance: 0.0012 Ohms Input Voltage: 4-9 Cells, 2S Lipo (3S Lipo with 35T or higher motor) BEC: 6.0V/3.0A Motor Limit: 13 Turn Throttle Profiles: 7 choices on board Reverse Type : 3 choices on board; none, delay, immediate Reverse Strength: 11 steps on board Rock Crawler Spec: 3S Lipo compatible when used with 35T or higher motor Dimensions: 1.1 x 0.80 x 0.40 " (28 x 20 x 10mm) FX-r Pro: Controls: Forward/Brake/Reverse ON Resistance: 0.0006 Ohms Input Voltage: 4-9 Cells, 2S Lipo (3S Lipo with 35T or higher motor) BEC: 6.0V/3.0A Motor Limit: None Reverse Type : 3 choices on board Reverse Strength : 11 steps on board Rock Crawler Spec: 3S Lipo compatible when used with 35T or higher motor Dimensions: 1.1 x 0.80" x .60" (28 x 20 x 15.24mm) Weight: 0.8oz (24g) Pro has slightly better specs (no motor limit on 2S), not enough of a difference to me though. | |
06-25-2012, 12:11 PM | #820 | |
Fxr pro- no motor limit, slightly lower on resistance , slightly larger/heavier I would say the PRO just gives the user more motor options... | |
