Thread: Burning up motors
Old 03-29-2013, 12:52 PM   #1
Default Burning up motors
Need some help. I have a 7lb axial jk. Running overdrive gears in front and under in the rear. Running 1.9 boggers. Ive fried a handwound 35t brood motor and a 55t integy. Motors get so hot they dont move. Loose all power. Give a minute it will come back for a sec and then fall on its face again?? Any ideas??? Thought about putting stock back in rear or running a puller motor???? Please help. Its getting expensive!!!!!:banghead::banghead::banghead:
SNOWYOTA is offline   Reply With Quote
Old 03-29-2013, 12:54 PM   #2
Scale Detail Engineering
Default Re: Burning up motors
if you remove the pinion, will it freely roll?
It sounds like you have binding.
johnnyh66 is offline   Reply With Quote
Old 03-29-2013, 12:54 PM   #3
Gearing or binding would be the first thing to check out.
DRTMI is offline   Reply With Quote
Old 03-29-2013, 12:55 PM   #4
If the motors are hot, then:
-You are overgeared
-You have a bind in the drivetrain
-Pinion to spur mesh is too tight
Actually this is a pretty simple issue....awaiting on YOUR reply.
Old 03-29-2013, 12:56 PM   #5
Wow, you should feel honored.....3 good replies within minutes!!
Old 03-29-2013, 01:13 PM   #6
Wow guys thanks. I will look at that when i get a chance. Am i over geared for just scaling? Had them thought id run them?
Old 03-29-2013, 01:24 PM   #7
What pinion/spur gears are you running?
Old 03-29-2013, 01:29 PM   #8
Old 03-29-2013, 01:30 PM   #9
it's gotta be binding or the mesh.
Old 03-29-2013, 01:30 PM   #10
owner, Holmes Hobbies LLC
JohnRobHolmes's Avatar
It won't free roll because you are running different ratios in the front and back. You are not overgeared. If your drivetrain has no binding I am going to guess you drive on high traction surfaces and the overdrive/underdrive is causing the heat.
Old 03-29-2013, 01:32 PM   #11
Anyways to keep from burning up motors??
Old 03-29-2013, 02:17 PM   #12
If theres no binding or the meshes are good I would think about going back to stock in the rear. Having such a large swing in gearing will cause you to overheat if you run on smoother surfaces alot. Things like cement, blacktop and large smooth rocks will cause the heat issue. Running your current setup over loose footing such as sand, dirt and pebble you probably wont even notice any heat related issues.
Phins Fan is offline   Reply With Quote
Old 03-29-2013, 02:23 PM   #13
I've always ran od/ud in my rigs and never overheated a motor.
Old 03-29-2013, 02:34 PM   #14
We have a couple of UD/OD rigs in house (2.2 & 1.9)....no issues on burning up motors.
Check for drivetrain binding first.
Old 03-29-2013, 04:21 PM   #15
Check for crunchy bearings in the knuckles.
Manning is offline   Reply With Quote
Old 03-29-2013, 05:16 PM   #16
Going to diagnosis it tonite. Brand new rig. Been out a total of three times now. Only think different in drivetrain is the gears.
Old 03-29-2013, 05:19 PM   #17
Thank you for all the help. Keep it coming.
Old 03-29-2013, 05:29 PM   #18
My 1.55 and 1.9 are both OD/UD and Ive never had any issues with heat either. My brother in law runs the same setup in his that I hhave and he burnt thru a couple cheapo motors before he listened to my advice and upgraded to a decent HH. The problem went away. At the end of the day you get what you put into it and if people dont want to upgrade the right things than I think they need to "downgrade" to compensate for their cheapness
Old 03-29-2013, 06:03 PM   #19
I'm having the same problems in my Wraith I am on my 5th motor in 3 days, all my driveline spins freely and same gears in front and rear axle, my motor gets so hot that the end ell melts off the motor, I'm running a mmp esc with a brushed motor, have tried different pinions, right now I'm running a 27t epic motor, running a 58t spur with a 6t pinion just to give it some torque, I have tried everything from 19t motors to 75 turn motors and smoked them all, I just want it to crawl with just a little wheel speed on 3s batts, sorry not trying to hi jack a thread but maybe someone can help both of us out.
tbacon38 is offline   Reply With Quote
Old 03-29-2013, 06:12 PM   #20
3s is your problem, what brand motors are you running
rcmedic is offline   Reply With Quote
Burning up motors - Similar Threads
Burning up motors 51JeepWillys Axial Wraith 17 03-21-2013 08:20 PM
Burning up MOtors HELP Pegasix Electronics 21 05-19-2012 04:19 PM
Keep Burning Motors Playa92687 Electronics 4 05-08-2012 04:48 PM
why am i burning up motors?? hoghead5150 Axial Wraith 52 11-08-2011 07:19 PM
Burning motors any thoughts? CrawlMater Electronics 6 11-29-2009 06:20 PM
