10-10-2006, 09:16 PM | #21 |
MWRCA'er Join Date: Apr 2004 Location: Machesney Park IL
Works perfectly now. Just so everyone knows, you just connect a wire to the red node and connect that to the empty terminal on the switch. Other then that it is wired exactly as my picture. |
10-11-2006, 09:20 AM | #22 |
I wanna be Dave Join Date: Jan 2006 Location: Iowa, the antirecreation state!
Sure, after I figured it out. JK, this is perfect. Works great. I like my two push butttons too. Lotta shtuff to cram inside but I like it. Thanks for your time Jay.
12-04-2006, 11:46 AM | #23 |
Rock Stacker Join Date: Nov 2006 Location: us
Im doing a mx3 3rd channel mod, ive read the thread in the tech section and then read this thread about an error, my question is where are you getting your five volts from, the orange or green wire? Thanks for the help. |
12-04-2006, 08:57 PM | #24 | |
Dirt Addict Join Date: Jan 2004 Location: Stumblin' thru the parking lot of an invisible 7-Eleven
Jay | |
12-05-2006, 12:36 PM | #25 |
Awesome! Thanks for the help. |
12-15-2006, 08:52 PM | #26 |
Newbie Join Date: Nov 2006 Location: sandy
ok i need some help. i removed the switch and have wired it up just likr in the photo. so switch has ground and 5v power but no 2.5v center off ? when u move the switch it just turns off the transmitter. any ideas?
12-15-2006, 11:31 PM | #27 | |
Jay | |
12-16-2006, 02:03 AM | #28 |
I have mine wired to the red node not the green one and it works perfectly. |
12-16-2006, 06:37 AM | #29 | |
Jay | |
12-17-2006, 11:54 AM | #30 |
Newbie Join Date: Dec 2006 Location: everett
For the stage 1 switch setup with a 3 pisition momentary like used in the write up. Does the rear return to center with the switch or do you have to do it manualy? Cant you just ajust the trim in the menu on the remote to center the rear instead of instaling a manual trim? thanks for the help steve |
12-18-2006, 03:55 AM | #31 |
with the three posion switch when u put it in the center the rear centers it's self. also i figured out my problem with mine (i feel stupid) i grabed 10 ohm resistors not 10k ohm (makes a big difference). so now i have rear steer and love it thanks guys.
12-21-2006, 06:58 AM | #32 | |
Jay | |
12-23-2006, 02:59 PM | #33 |
Pebble Pounder Join Date: Jun 2005 Location: west depford
want to thank jay for the tech article. just got done doing the mod works like a charm thanks again
12-24-2006, 06:31 AM | #34 | |
Jay | |
01-15-2007, 12:36 AM | #35 |
Rock Stacker Join Date: Apr 2006 Location: sparks
i see on your tech write up that you have a trim pot there in the stage two how do you wire that in to the switch. if you could can you like show it like you did on the switch with the yellow lines i can understand where they go then. not really able to understand the white box schematic. thanks for any help on this.
01-15-2007, 12:40 AM | #36 |
oh and is there any certain size wire that needs to be used?
01-18-2007, 12:10 AM | #37 |
is there any one that can show me where the wires go for the pot. cause i know where the other wires go but the three for the pot. where do they go?
01-18-2007, 10:03 AM | #38 |
This should be correct for stage 2 wiring. Can use most any size wire....whatever is flexible and easy to work with. The wire size is not critical. Jay |
01-19-2007, 02:06 AM | #39 |
ah that is what i was looking for thank you very much now as soon as my transmitter gets here i can do that |
01-19-2007, 02:08 AM | #40 |
oh and you are right after looking at the manual there is no rear trim on the transmitter |
