01-24-2007, 08:38 AM | #41 |
Rock Stacker Join Date: Apr 2006 Location: sparks
does it really matter what size resistor you use like if you use a 1/8 is tht sufficent?
01-24-2007, 05:54 PM | #42 | |
Dirt Addict Join Date: Jan 2004 Location: Stumblin' thru the parking lot of an invisible 7-Eleven
Jay | |
01-24-2007, 07:25 PM | #43 |
okay i was asking cause i hooked it up kinda the same way in my mx-3s. and when i used the rear steer it like activated all of the channels it made my throttle work and my front and rear. the front just twitched a little and the throttl just went forward. so what i am think is that on the mx-3s there is only one red voltage wire. i used that for power ths only black wire for ground and and then the middle terminal for the third channel. so my real question is if i use another terminal on the switch area is that enough power for the rear steer http://www.putfile.com/pic.php?img=4593879 http://www.putfile.com/pic.php?img=4593878 |
01-24-2007, 07:26 PM | #44 |
01-24-2007, 07:53 PM | #45 |
oh and does it have to be five volts cause if it does then i might have found where i went wrong.
01-24-2007, 10:53 PM | #46 | |
Jay | |
01-25-2007, 03:24 AM | #47 |
oh sorry the power wire that you have going to the green does that have to be five volts. cause i have found voltage it is just that when i hit the switch it make my throttle activate and goes forward. i am going to mess around with it a bit but it seem that any where that i get power from i get the the throttle working with it. but it does work in the mx-3s |
01-25-2007, 06:24 AM | #48 |
What radio are you working on? Jay |
01-25-2007, 08:03 AM | #49 |
mx-3s the synthezised unit to the mx-3. |
01-25-2007, 09:16 PM | #50 | |
Jay | |
01-25-2007, 09:45 PM | #51 |
yeah neither am i but i was wondering can you actually use a trim pot with a knob on it for your rear steer? i dont know if you know or not but wanted to ask and if you can what size do ou think?
01-26-2007, 06:49 AM | #52 | |
Jay | |
01-26-2007, 03:23 PM | #53 |
Rock Stacker Join Date: Jan 2007 Location: Canada B.C.
I have a couple MX3-S radios and was curious how hard it would be to do this mod, I have yet to pull apart one of my radios. Keep us updated on this, save me from having to test it for my self |
02-20-2007, 08:09 PM | #54 |
Newbie Join Date: Oct 2006 Location: Las Cruces
Being new to the MX-3, or any computer radio for that matter, I didn't bother to check the default EPA setting for channel#3/AUX. I modded, desoldered, resoldered, pulled traces off the board, and cooked my 10 year old Radioshack soldering iron, only to realize that the reason it would not turn left, was the EPA setting. All fixed now, but the lead to the input circuit is soldered directly to the end of an SMT component. (after cooking the shack 15w, I impatiently pulled out my 60w. Overkill) All that aside, Good tutorial. I'm super happy with my 4ws. Thanks!
03-19-2007, 02:32 PM | #55 |
I wanna be Dave Join Date: Jan 2006 Location: Iowa, the antirecreation state!
Is it poosible to overload a 10K resistor? Do I need a larger resister? Here is why I ask. I did this mod a long time ago and it has worked flawlessly for me with two momentary on, push switches until now. I am a tight basterd and stole my resisters out of an old junk VCR I had laying around. This third channel in my radio is also running a HS-5645MG servo. When it acts up the servo runs full crank to the left and will not correct unless I turn of the system. I have switched my HS-5955TG with the same problem. Also the resister is reading 5.6K when it is acting up. Here's a couple shots of what I got. It will come back to 10K sometimes. Do I need a higher voltage resistor? I am not a wiz when it comes to this shtuff. |
03-19-2007, 07:39 PM | #56 |
Pebble Pounder Join Date: Apr 2006 Location: Jackson
Where is everyone putting the trim pot for the stage 2 mod? I was thinking about putting it in the battery compartment, once its set it shouldn't need to be adjusted much.
03-20-2007, 07:11 AM | #57 |
I wanna be Dave Join Date: Oct 2006 Location: Martinsburg WV
I just used half of a reversing Y-harness for my rear trim. Yea, the pot is on the rig vs. on the transmitter, but it's cheap and easy to set up though. |
03-20-2007, 08:20 AM | #58 | ||
Jay Last edited by roktoy; 03-20-2007 at 08:23 AM. | ||
03-22-2007, 06:29 AM | #59 |
I ripped a different one out of the VCR a while back and this is the second one in the radio. Are their diff voltage resistors. I noticed the one Mnster has in the pic of his radio looks 3 times the size of mine. Gonna make a trip the Shack and see what they gots. Thanks Jay.
03-22-2007, 08:17 AM | #60 | |
They're rated by power capacity.....1/8 watt, 1/4 watt, etc. (voltage across multiplied by current thru them). The can typically withstand high voltages....certainly much higher than any battery we would use. Jay | |
