11-20-2016, 07:53 PM | #41 |
Rock Crawler Join Date: Jan 2014 Location: Frog Lake AB, Canada
| Re: CHEAP replacement led strips for vp rigid housings?
Do any of you guys know if the COB light strips come any thicker? I think I could make use of one in 5.5"L X .70"W.
11-28-2016, 08:31 AM | #42 |
I wanna be Dave Join Date: Apr 2015 Location: Roseville, Ca
I knew it. Good thing I haven't tried cutting mine. Ended up ordering 5.5" and 7" from the eBay seller in California. They are awesome (except housing), Im thinking about using them everywhere (1:1 rock lights, under the hood or trunk, work bench ect.). |
11-28-2016, 12:40 PM | #43 | |
| Re: CHEAP replacement led strips for vp rigid housings? Quote:
11-28-2016, 01:49 PM | #44 |
His 2nd picture shows it out of the housing next to one in the housing. They have 5.5" or 7".
11-28-2016, 02:13 PM | #45 |
Rock Crawler Join Date: Aug 2007 Location: Philadelphia
| Re: CHEAP replacement led strips for vp rigid housings? |
11-28-2016, 02:53 PM | #46 |
11-28-2016, 05:54 PM | #47 |
Rock Stacker Join Date: Dec 2015 Location: East TN
The cheap cob leds that you can order off ebay can absolutely be cut down...i ordered 7in strips that were to big for my setup and cut nearly 2 inches off of it and it still works perfect. I can provide pics if there are any nonbelievers.
11-28-2016, 06:14 PM | #48 |
Yes, could you? I would like to see just to confirm its possible. Thanks.
11-28-2016, 06:32 PM | #49 |
Lol exactly. Pictures are worth a thousands words. |
11-28-2016, 06:47 PM | #50 |
11-28-2016, 07:04 PM | #51 |
Thanks for the pictures. But, I was hoping for a close up of the actual cut. What housing did you use in the cut down version? |
11-28-2016, 07:40 PM | #52 |
I took the led out of the black "housing" and used a pair of side cutters to cut the led down. Just made sure i cut inbetween the square led sections. Then i cut and bent the black housing around the remaining section of the led. Really simple and i think you might be looking to deep into it. Took me all of 2 min to cut it down
12-01-2016, 01:45 PM | #53 |
Wow looks really good. But looks expensive. Lol
12-01-2016, 03:46 PM | #54 |
Billet will be very nice and very strong, but I would also assume it's going to be a lot more expensive than the Black Beauty V2.
12-02-2016, 09:45 AM | #55 | |
RCC Addict Join Date: Aug 2008 Location: Paulina
I just received 4- 5.5" strips in the mail for a whopping $8 shipped. I'll gladly cut one up for testing as well. | |
12-02-2016, 10:10 AM | #56 |
Lol sweet. Let us know how it goes and take some pictures please. Im going to order some more and also order some 12v power supplys to hook up in the garage. |
12-02-2016, 10:19 AM | #57 |
12-02-2016, 01:54 PM | #58 |
Post #12. He also sells a 7" too.
12-02-2016, 02:20 PM | #59 |
So it looks like they're both right and I don't have time to figure out why.... Cut one of the 5.5" bars in half with a dremel. The half that had the original wiring soldered to it no longer works. For kicks I cut the original wire lead in half and soldered that to the other half of the LED power leads and that half still works which is what's pictured above. I tried cutting a few sections off the half that isn't working and I can't get it to work again at all. I also realized I could cut these with kitchen scissors and a Dremel is way overkill. I have no clue why I'm getting this result. I only had a few minutes and now I have to run to a meeting. I might have time to play with it more later. Discuss.... |
12-02-2016, 05:15 PM | #60 |
I wanna be Dave Join Date: Aug 2006 Location: under a rock and a hard place
Hmm, interesting ^^^^^^ I would be curious to see what you find out if you do a bit more loooking into it. |
CHEAP replacement led strips for vp rigid housings? - Similar Threads | ||||
Review: MORE LED module for Vanquish Rigid Industries LED light bars | JasonInAugusta | Electronics | 29 | 04-04-2014 08:29 AM |
Axial universal light bar snap in insert for LED strips | Sheepdawg23wm | General Scale Talk | 3 | 02-22-2014 01:22 AM |
VP Rigid Led M.O.R.E mount | fatroofus | Axial SCX-10 | 5 | 12-18-2013 10:37 PM |
