12-02-2016, 07:27 PM | #61 |
Rock Stacker Join Date: Dec 2015 Location: East TN
| Re: CHEAP replacement led strips for vp rigid housings?
That is interesting. Mine worked perfect and didnt have to do anything with the wires. Ill look at mine again tomorrow and see if i can tell how the leds are actually wired underneath that yellow coating.
12-02-2016, 08:05 PM | #62 |
Rock Crawler Join Date: Aug 2007 Location: Philadelphia
| Re: CHEAP replacement led strips for vp rigid housings? |
12-02-2016, 10:34 PM | #63 |
12-05-2016, 03:34 PM | #64 | |
| Re: CHEAP replacement led strips for vp rigid housings? Quote:
I got mine today. They are insanely bright. On 2S they barely light up, but on 3S you can't even look at them. They are very blue not white though. And 5.5" is too wide for any of my RC's. I wish they'd sell smaller ones. Mine also came shipped in a thin, plastic bag so the box took a beating. Both lights work fine, but I'm tired of companies shipping products in unprotected packages. | |
12-05-2016, 03:39 PM | #65 | |
12-05-2016, 04:39 PM | #66 |
This is going off of my memory which isn't saying too much. My bulb has dimmed after two handfuls of concussions. But this is what I think I remember... Now that I think about it I was told you can't cut COB LEDs, but you can carefully shave/grind them. Something about not letting the layers touch. |
12-05-2016, 05:01 PM | #67 | |
12-05-2016, 07:07 PM | #68 |
I wanna be Dave Join Date: Apr 2015 Location: Roseville, Ca
What's weird is the side you cut off worked but the other side didn't work. Makes no sense. Do you only have the 5.5"? The 7" has the leds setup differently. There setup like this / / / / / / (7") vs l l l l l l l (5.5"). |
12-05-2016, 07:26 PM | #69 |
Nope, I just ordered the 5.5" size. Didn't see a use for 7" bars since I don't run anything near that big.
12-07-2016, 09:34 PM | #70 | |
Rock Crawler Join Date: Aug 2015 Location: Fort Knox, Kentucky
12-07-2016, 11:00 PM | #71 |
Don't think so. I did a quick search on ebay but only thing I saw was a 48mm 6-7v cob from china.
12-15-2016, 08:47 AM | #72 |
01-28-2017, 09:10 PM | #73 |
Ive been meaning to update my last post, but the seller set me the correct white cob leds. I asked what he wanted me to do with these blue tinted leds and he said I could have them. Pretty cool of him to do that. Anyways having all these blue ones I successfully cut off a quarter inch, then a half inch then a full inch off and it still worked after each cut. I just used some sheet metal shears to cut it down. So you can cut down cob leds. |
01-28-2017, 11:54 PM | #74 |
Yep, i said that and posted pics awhile ago of my cut leds but there still seemed to be alot of skeptics that said it couldnt be done. Oh well glad it worked for u as well.
04-03-2017, 07:09 PM | #75 |
RCC Addict Join Date: Aug 2008 Location: Paulina
FYI, just cut one of the COB lights finally and it continued to work. I pulled the led strip out of my Team Associated light bar that started to burn up and shoved the $2 COB strip into the AE aluminum housing. Double checked it was still working and all seems to be good. Going to try mounting it up on my Bomber in a minute to give it a test drive. Will take some pictures shortly.
04-03-2017, 08:02 PM | #76 |
Pics |
04-04-2017, 12:17 PM | #77 |
It's BRIGHT. I didn't get to mount it up but anxious.
04-04-2017, 04:07 PM | #78 |
Rock Crawler Join Date: May 2016 Location: SoWIs
I haven't found any exact specs, but I'm guessing each LED element has it's own resistor, so each long column of LED's has a +12v and gnd busbar on either side. So if you cut the COB, you have to be sure the busbar doesn't short onto the aluminum back. When I cut the strip LED's that are pre-applied to aluminum backing, I sand the cut end flat on a belt sander parallel to the cut. That reduces the chance the powered copper doesn't short to the backing.
04-04-2017, 05:42 PM | #79 |
That and a little conformal coating, liquid electrical tape, E6000 or something over the cut just in case.
04-04-2017, 10:25 PM | #80 |
Really just anything that you'd normally put over an exposed solder joint. If something touches the edge just right, it would be like hitting an exposed wire - albeit very thin.
CHEAP replacement led strips for vp rigid housings? - Similar Threads | ||||
Review: MORE LED module for Vanquish Rigid Industries LED light bars | JasonInAugusta | Electronics | 29 | 04-04-2014 08:29 AM |
Axial universal light bar snap in insert for LED strips | Sheepdawg23wm | General Scale Talk | 3 | 02-22-2014 01:22 AM |
VP Rigid Led M.O.R.E mount | fatroofus | Axial SCX-10 | 5 | 12-18-2013 10:37 PM |
