04-09-2017, 03:41 PM | #81 |
RCC Addict Join Date: Aug 2008 Location: Paulina
| Re: CHEAP replacement led strips for vp rigid housings?
Works good. Need to tighten the pivot on the mount but good. Edit: and drop it down. Looks like it's wayyyy up there. Last edited by calcagno45; 04-09-2017 at 04:20 PM. |
05-06-2017, 09:01 AM | #82 |
Only after about an hour of run time one of my VP Q Series lights stopped working. Anyone replace a Q Series LED?
05-06-2017, 10:11 AM | #83 |
I wanna be Dave Join Date: Apr 2015 Location: Roseville, Ca
I'd like to know what led vp uses for those, they are bright. But try contacting vp for a replacement?
05-06-2017, 12:03 PM | #84 |
| Re: CHEAP replacement led strips for vp rigid housings? Me as well. They were very nice and VERY bright for sure. I did contact them through the "Contact Us" on the website but no response yet. Will contact them via phone next week. If they weren't so expensive i would just chuck the housing but would like a replacement if i could. Heck i would buy 2 just in case.
05-06-2017, 10:55 PM | #85 |
Moderator Join Date: Jan 2004 Location: chicago
i got my strip from them for around 20 bucks shipped iirc.
05-08-2017, 01:39 PM | #86 |
Still no word from VP and i haven't had the chance to call yet. I decided to open up the light since there was no reason like a pop, sizzle or smoke for it to stop working. Neg - Not burnt just bad lighting Hmmm That doesn't look right. Pos + unsoldered itself Should i re-solder? I found the LED board with no wires online if it would be better to start from scratch. |
05-08-2017, 02:39 PM | #87 |
Hook it up to power/ground and press the wire to board/solder and see if it works. If so, solder it back on and your good to go. Easy fix.
05-09-2017, 07:41 AM | #88 |
Quarry Creeper Join Date: Jan 2015 Location: Bucharest, Romania
I'm using this https://www.aliexpress.com/item/10W-...608.0.0.h94RTi and it's crazy bright. However you'll need an LED driver in order to make it work correctly, something like this https://www.aliexpress.com/item/High...608.0.0.h94RTi. Or you can use a variable CC step down module and you can adjust the mAh as you want http://www.ebay.com/itm/DC-DC-LM2596...wAAOSwt5hYb5jk I installed the chip on a aluminium angle, with a little thermal adhesive and this is the final result: Last edited by Tzicul; 05-09-2017 at 07:45 AM. |
05-13-2017, 09:13 PM | #89 | |
| Re: CHEAP replacement led strips for vp rigid housings? Quote:
Thanks for the info. Cheap and Stupid bright set up. | |
05-13-2017, 09:17 PM | #90 | |
YT Vid "> | |
CHEAP replacement led strips for vp rigid housings? - Similar Threads | ||||
Review: MORE LED module for Vanquish Rigid Industries LED light bars | JasonInAugusta | Electronics | 29 | 04-04-2014 08:29 AM |
Axial universal light bar snap in insert for LED strips | Sheepdawg23wm | General Scale Talk | 3 | 02-22-2014 01:22 AM |
VP Rigid Led M.O.R.E mount | fatroofus | Axial SCX-10 | 5 | 12-18-2013 10:37 PM |
