02-18-2018, 09:16 AM | #261 | |
Quarry Creeper Join Date: Jan 2017 Location: Olathe
| Re: Mamba Firmware V2.02 Quote:
I don't know if the Twin Hammers requires one or not, we don't have one at the office so I can't test it out. | |
02-18-2018, 09:23 AM | #262 | |
RCC Addict Join Date: Jun 2013 Location: Port Saint Lucie, Florida
Sent from my SM-G950U using Tapatalk | |
03-10-2018, 12:22 PM | #263 |
Rock Stacker Join Date: Mar 2016 Location: Saskatchewan
I just made a video about the new mode available in this firmware: https://www.youtube.com/watch?v=QlbpfjHuG6k I *think* everything I said in it is correct but if anyone wants to confirm that would be great. Hopefully it will help eliminate some confusion |
09-14-2018, 09:33 PM | #264 |
Newbie Join Date: Apr 2018 Location: Usa
So now that we have the race/crawl option is there any way we can set two different throttle and brake curves for race and crawl independently? Sent from my iPad using Tapatalk |
09-17-2018, 10:07 AM | #265 |
Quarry Creeper Join Date: Dec 2015 Location: Sutter
Can somebody explain how the adjustable drag break setting works. Using MambaX, gt3c w/aux set up on the 3rd channel. Drag break setting is 40% on esc which is generally the minimum I run on my lighter crawler. If I use the 2pos switch it goes from enabled to completely disabled. If I use the trim switch it seems to make no difference. Essentially what I’m looking to do is be able to adjust my drag break up in 10% increments or so. I’m usually able to figure this stuff out but the description talks about throttle milliseconds and I’m at a total loss. Sent from my iPhone using Tapatalk |
09-17-2018, 07:59 PM | #266 |
My guess is -100 is 1.1ms and 100 is 1.9ms. and it should be vairiable, so zero is 50% drag brake. but some how these settings are tied to the brake settings in the basic tab. Try setting esc drag brake to 0 or 100 and see if it makes a difference. What radio are you using? Are you sure of the aux ch settings on that? |
09-17-2018, 08:48 PM | #267 | |
Gt3C. I guess what I don’t fully understand is what the drag break has to do with throttle position as it describes in the aux advanced settings. Currently I do have the 3rd channel mapped to a 2 pos switch but it could (maybe) figure out how to map the 3rd channel to one of the 3pos switches. Sent from my iPhone using Tapatalk | |
09-17-2018, 11:29 PM | #268 |
I don't know that remote, so this is all guessing. is the 3 position switch momentary or does it does it lock into each position, I would guess it is momentary. each time you you click that momentary 3ch trim, it moves the neutral position only a small amount. you can possibly program it to travel in larger increments. this should be the switch you use to adjust the drag brake If you remapped ch3 trim to do what your doing, then I don't know what your doing. because it looked like it was already set at default to do the proper thing. just in tiny increments. but you need to know what signal as in (+100 or -100 forward or reverse%) is being sent on ch3 to know if the aux on the mamba x is working properly or not. Last edited by Voodoobrew; 09-17-2018 at 11:34 PM. |
09-21-2018, 09:35 AM | #269 | |
Thanks. I like the Gt3c but have found the hacked version to be very complex. Most of the features I’ve figured out through trial and error. I do believe it is set as momentary so maybe it’s a matter of changing the end points to to something like -50,0,+100 and then set the castle drag break to what I’d like the maximum to be (corresponding with the +100 end point.) Sent from my iPhone using Tapatalk | |
11-06-2018, 09:34 PM | #270 | |
Quarry Creeper Join Date: Aug 2018 Location: Toronto, Canada
Sent from my SM-N950W using Tapatalk | |
11-07-2018, 07:28 AM | #271 |
Moderator Join Date: Aug 2017 Location: Readsboro, VT
| Re: Mamba Firmware V2.02 You can configure the ESC to have a variable drag brake as long as your transmitter has a variable channel. On my trucks my aux channel is tied to the rotary pot on my transmitter, so I have full adjustability on the drag brake from 100% all the way down to 0%. I have it set so that below 10%, the ESC transfers from fwd/reverse to fwd/brake/reverse and it works beautifully.
11-07-2018, 07:32 AM | #272 | |
04-19-2019, 12:48 PM | #273 |
I wanna be Dave Join Date: Apr 2010 Location: Oakridge
Does anyone have a Monster X installed in their Traxxas UDR, if so could you share your Castle link settings with me? Thanks Ernie |
04-26-2019, 01:13 PM | #274 | |
Rock Crawler Join Date: Dec 2013 Location: Tuxedo NY
08-11-2019, 01:35 PM | #275 |
Quarry Creeper Join Date: Feb 2007 Location: Lleida
Nice features!
08-11-2019, 02:46 PM | #276 | |
Thats using the Rock race/crawler mode, this allows you to pick a crossover point that once your below (the drag brake value/percentage) the reverse mode changes from crawler reverse to a delayed reverse great for occasional bashing or faster crawlers. It is a really cool feature. Last edited by HumboldtEF; 08-11-2019 at 03:14 PM. | |
Mamba Firmware V2.02 - Similar Threads | ||||
castle firmware update1.46 | JesterSpec | Axial Yeti | 7 | 12-19-2014 08:33 AM |
Sidewinder Micro firmware | dextan22 | Electronics | 6 | 04-18-2013 02:00 PM |
Castle Firmware | skid plate | Electronics | 2 | 01-11-2011 10:23 AM |
Glitching with New Castle Firmware | EXW | Electronics | 16 | 01-24-2010 07:56 AM |
