07-17-2020, 04:41 PM | #1821 |
Rock Crawler Join Date: Apr 2020 Location: Northern MN
| Re: Have tech questions? Will answer.
I really like rc reviews servo test videos. I’ve learned a lot. Here’s his video describing the actual servo tester that you see. https://youtu.be/ONnbbiON610 |
07-18-2020, 04:36 PM | #1822 | |
Newbie Join Date: May 2020 Location: Columbus
| Re: Drag Brake Quote:
07-19-2020, 10:43 PM | #1823 | |
I wanna be Dave Join Date: Jun 2020 Location: The Big Island
| Re: Have tech questions? Will answer. Quote:
07-20-2020, 09:33 AM | #1824 |
If the servo isn't turning then you probably have a broken gear in the servo. If the servo turns but the wheels don't then check the linkage. The set screw on the servo horn can get loose and the teeth strip out. Tighten that up. __________________________ Handy gearing spreadsheet |
07-24-2020, 05:42 AM | #1825 |
Newbie Join Date: Jun 2018 Location: Cape Town
Question: Will the 0° timing mark need to shift if set up for CW if originally set up for CCW? This is for skewed slot motors only. I found 2x different points of lowest amp draw when running my skewed motor in opposit directions, its about 10° difference |
07-28-2020, 04:13 PM | #1826 |
Rock Crawler Join Date: Nov 2019 Location: Erie
Does anyone have an opinion on the following? I have 2 motors, a Holmes Puller Pro V2 Stubby 2200kv and a Holmes Revolver V2 (standard) 2200kv. One will find a home in my Capra, the other in a trail truck build. I totally understand one sensored, one sensorless. Just curious how these 2 compare torque-wise? Thanks gents.
07-28-2020, 06:39 PM | #1827 |
The revolver is a incredible motor, vs my PullerPro’s. I have 2700stubby, regular and 3500regular. The 2200 revolver puts them to shame torque wise and creep ability. The pullers take a throttle curve for incredible speed with torque. The curve for revolvers makes it literally creep gear tooth by geartooth. Downside is the noise factor. On a crowded trail, the whiners do complain, I usually drive past or over them and stay ahead. Hang up and Drive |
07-28-2020, 08:12 PM | #1828 |
Thanks Mike! That’s what I was assuming but glad to get confirmation. Looks like the Revolver will end up in the Capra and the Puller Stubby is going in the Gmade.
07-29-2020, 01:53 PM | #1829 |
| Re: Have tech questions? Will answer. Technically it wont shift, but.... The brushes will shift a little bit from forwards to reverse and will cause the minimum point to change. A skewed arm doesn't have "virtual zero" at different points, its the same for both directions.
07-31-2020, 07:18 PM | #1830 |
My friend got a Crawlmaster Sport 550 8t motor and wanted me to install it in his rig. By hand I could not turn the motor shaft. I put a pinion on and could turn it by hand but with a ton of resistance (this is a brand new motor). I keep my old Ice charger around because it has a motor run in feature. Hooked the motor up and got an error reading as if one of the leads wasn’t hooked up which was not the case. Fast forward to today. He got another of the same motor, brand new as well. Same thing. Couldn’t turn the shaft by hand and barely with a pinion. Hooked it up to the Ice and got the same error reading and the motor did nothing. Took one of my Holmes motors and a Traxxas motor and hooked them up to see if the charger was defective. Both of these motors worked fine. Was there a issue with these motors? I know the 8 turn was just recently released so thought I’d ask if there was something going on with them that I haven’t heard. Thanks
08-02-2020, 07:04 PM | #1831 |
Newbie Join Date: Aug 2020 Location: Knoxville
Motor question here. I have a castle slate 3800kv combo on my TRX4. What determines motor speed on these? It says on the can it has a 100,000 RPM limit but data logging says it exceeds that using 3s(assuming the parameters are set correct for the motor type). For instance if I were to get a Holmes puller pro v2 which has an rpm limit of 50,000, would it exceeds that limit on the same 3s battery? Does the ESC have any limiting capabilities to keep it check? I don't wanna void any warranty I have with my castle system! |
08-02-2020, 11:36 PM | #1832 | |
Quarry Creeper Join Date: Jan 2017 Location: Olathe
The max unloaded RPM of a motor should be the KV * Number of Cells * Max charge per cell; so 3800kv * 3 cells * 4.2v/c = 47880 RPM. | |
08-08-2020, 03:06 PM | #1833 |
Quarry Creeper Join Date: May 2017 Location: Bellevue
Yes!!! Now I’m not lying when I tell girls I use a Magnum;) That being said, generally I use the leads you guys solder on and connect them to the ESC via bullet connectors (in this case, HW1080). If I’m correct, really the best practice would be to solder the ESC leads direct to the motor right? In looking to really get a sense of how great this motor is, should I do as such, or being a layman is the difference negligible? Sent from my iPhone using Tapatalk |
09-01-2020, 04:42 PM | #1834 |
negligible to direct solder in a crawler. Thanks everyone for keeping this thread going. I'm back in a point where I can be hanging around again. Not down a few employees any longer. |
09-01-2020, 11:43 PM | #1835 |
Rock Crawler Join Date: Apr 2008 Location: pittsburgh
Is the crawlmaster 550 15t too hot in a trx6 on 3s 2200 spektrum smart packs? I have 5000 50c packs, but really like the difference when running the small packs with the 21t trailmaster. I can gear down to 9t pinion if need be Last edited by rag6; 09-01-2020 at 11:44 PM. Reason: Add info |
09-02-2020, 09:11 AM | #1836 |
Quarry Creeper Join Date: Oct 2012 Location: Oxford
Hi there John, Have been looking at the SWM2 and wondered if it would be man enough to power a snub nose in a lightweight comp rig? I had a thread about this a while back but no definitive, pmd Robert and he thought it may be possible but recommended asking if you had tried this combo and your thoughts?. Thanks |
09-04-2020, 12:28 AM | #1837 | |
My guess is Technically the smaller pack probably has a lower C-rating which means there could be more voltage sag, lower voltage means you need more throttle to reach the same speeds, thus requiring more amp draw, this the possibility of higher temps. But really you would have to already be bushing the motor the its thermal limits for this to push you over. But I could be wrong. | |
09-05-2020, 10:21 PM | #1838 |
Why does my Savox servo on my TRX4 only turn right and not left?
09-05-2020, 10:23 PM | #1839 | ||
09-06-2020, 06:05 AM | #1840 | |
__________________________ Handy gearing spreadsheet | |
Have tech questions? Will answer. - Similar Threads | ||||
suspension tech questions. | Gen3_Teg_88 | General Crawlers | 9 | 07-13-2018 08:29 AM |
axle tech questions | 808eng_rc | Multi Axle Rigs | 4 | 11-07-2013 02:08 PM |
(HH) Tech Questions and Customer support thread | JohnRobHolmes | Holmes Hobbies | 3483 | 02-05-2013 09:08 PM |
2 stupid newbie questions needs answer | Mysterious | Axial XR10 | 21 | 06-18-2012 09:22 AM |
? Who has the answer to thes questions ? | mik236 | Team Losi Comp Crawler | 12 | 05-23-2010 02:40 PM |
