04-15-2014, 12:30 PM | #921 |
2013 2.2P Nat. Champion Join Date: Sep 2009 Location: BorderLine Crawlers Season 3 is on!
| Re: Skaldiddog's "Progress"
Damn those are sexy axles Rob. Update on my cases...all are being re-cut from scratch following a less than optimal final assembly. The new ones will be mill finish for that bling look. I'll post pics when I get an update. Not holding my breath on having them ready for AZ. J |
04-15-2014, 04:16 PM | #922 |
I wanna be Dave Join Date: Oct 2004 Location: QC-AZ
"less than optimal" What was wrong exactly? You could always send me some material so that I could take a shot at them. |
04-16-2014, 08:11 AM | #923 | |
| Re: Skaldiddog's "Progress" Quote:
You got CAD files for stock cases? J | |
04-16-2014, 08:41 AM | #924 |
Joel...just curious here...if you're going through the motions to make new cases couldn't you make a few more changes and come out with an even better end product? Seems like you could slim the cases down in a few spots and maybe move the motor around a little. Two of the biggest things I notice when going between my XR and Berg are that the trans case gets hung on ridges and makes the truck hold a line that I don't necessarily want it to...or it butts up against something and requires some "forceful" driving to free it and the other thing is that the rear motor is so far out in front of the tubes. Neither of these changes would require different tubes or lockers so that's what got me wondering. The changes you've made are nice...subtle and necessary. That 7075 is gonna slide beautifully as well |
04-16-2014, 10:16 AM | #925 |
| Re: Skaldiddog's "Progress" |
04-17-2014, 08:00 AM | #926 | |
What size block? | |
04-17-2014, 08:44 AM | #927 |
It would probably be best to prototype from Delrin before dropping the coin on a 7075. A blank size of 4"x3"x5/8" per case half.
04-17-2014, 09:08 AM | #928 |
Quarry Creeper Join Date: Dec 2009 Location: aurora
I do have a CNC router in my garage if that helps. I even have a big chunk of 1" thick chunk of delrin that I haven't touched since I got it and can get more for nothing. I also have extra Ti-Fighters if you want to look at them and take some measurements cause they are small and have rearranged gears and motor mounts. Let me know if I can help in any way :-) Sent from my XT1080 using Tapatalk |
04-28-2014, 12:29 PM | #929 | ||
In the meantime I shortened my shock cap mods by 0.112". This lowered the rig by about 0.2". I lowered my battery tray by 0.15" back to it's original location and am running less pre-load on the rears, more rear limiting, less limiting on the front and lighter oil all the way around. The rig handles better now. After many hours of driving and tweaking this setup I'm quite pleased. Only downside is that I had to go back to the hood-less shell due to the body getting all up in the front end. I also moved the BEC back to the chassis for safety and binding issues. I knocked it off flailing on my roof at the West Coast RC finals. But I didn't take a rollover. I like the look better without the BEC hanging out front. The significantly lower COG of the lower rig offsets the BEC move back to the chassis. Sorry BC but I just can't bring myself to do this to the body you did for me. Everyone that sees it in my garage asks me about it. Finally made some RC friendly vise jaws from black delrin. And some under-cabinet banana hangers. That is what happens when I have spare time and Clown Oil. Looking forward to fun AZ road trip and comp!!! | ||
04-28-2014, 12:38 PM | #930 |
Rock Crawler Join Date: Mar 2008 Location: Not painting
04-28-2014, 01:17 PM | #931 |
04-30-2014, 07:49 AM | #932 | |
| No mo' toe! Quote:
So after all of these years of [accidental] toe in I've decided to remake my steering linkage and move the bearing holes inward to parallel with the kingpins so that I ain't go toe no mo'. Got some 7075-T651 from Switzerland. Hardest alloy de aluminum I could find. Took three weeks to get it dangit. New linkage will be smaller but just as strong or stronger than the current one. The question is do I bust butt and do it in the next 48hrs or wait till after AZ. We'll see. J | |
04-30-2014, 08:35 AM | #933 |
Rock Crawler Join Date: Apr 2007 Location: presKit
04-30-2014, 08:53 AM | #934 |
Rock Crawler Join Date: Mar 2009 Location: AZ
Hey Joel, Just curious why you had to buy the aluminum from switzerland? Looks like www.onlinemetals.com has 7075-T6. Although not sure if there is a difference between 7075-T6 and 7075-T651 though. |
04-30-2014, 09:23 AM | #935 |
E.Y. Designs Join Date: Sep 2011 Location: Springfield, OR
I was just thinking of your rig this morning and wondering why you never got around to making a new steering link LOL.... Good luck in AZ and have fun!
04-30-2014, 09:42 AM | #936 | ||
| Re: Skaldiddog's "Progress" No. Quote:
J | ||
04-30-2014, 11:17 AM | #937 |
Last minute vehicle prep/fab is where the fun is at! http://tciprecision.com/machine-ready-blanks Not sure on their prices but I am considering looking into using them next "production run" I do. |
04-30-2014, 12:07 PM | #938 |
05-01-2014, 08:28 AM | #939 |
| Crunch time...
So I put in ~4hrs yesterday and knocked out design and workholding. I had to make a 6061 mounting plate as part of this. I even test fit a bearing in the 7075 plate. I learned from VP to do test cuts/fits in the exact material you are going to use as 6061 and 7075 "get out of the way" of cutting tools in different manners. Thanks for the blem gold Voodoo Matt. My hat was actually a little loose and now it fits nice and snug. Tonight will be a time crunch to finish, pack, do the yard and get some sleep. Fun stuff. J |
05-05-2014, 08:08 AM | #940 |
| Steering done...pics later
Was a madman last Thurs night and finished my steering link in a functional sense, just in time for the comp this past weekend. I'll knock out the cosmetic cuts tonight and share some pics tomorrow. J |
