06-30-2014, 12:04 PM | #1021 |
| Re: Bye Bye Berg |
06-30-2014, 12:24 PM | #1022 | ||
2013 2.2P Nat. Champion Join Date: Sep 2009 Location: BorderLine Crawlers Season 3 is on!
| Re: Skaldiddog's "Progress" Quote:
To cover the hole left from removing the bottom of the gear case. Quote:
J | ||
06-30-2014, 01:18 PM | #1023 |
two and three flute for aluminum and plastics. Four and above for steel. |
06-30-2014, 02:00 PM | #1024 |
| Re: Skaldiddog's "Progress" |
06-30-2014, 02:05 PM | #1025 |
You ever gonna post more burger build pics or can I finally stop checking and unsubscribe to this thread?
06-30-2014, 02:17 PM | #1026 |
06-30-2014, 02:20 PM | #1027 |
| Re: Skaldiddog's "Progress" Its not a huge deal for stuff like skimming cases, but the work will go faster and have a better finish. The tools will last longer as well. If you ever have a project where you will be hogging a lot more, get a few new mills. Some radius on the tip (.007 to 015") will make them less likely to break too, a real big life extender. If you want to keep the chip load constant without changing feed rate, it would need an increase in spindle speed. |
06-30-2014, 03:20 PM | #1028 |
06-30-2014, 03:22 PM | #1029 |
I wanna be Dave Join Date: Jan 2008 Location: Arat Alabama
#carnivoreporn©
06-30-2014, 03:39 PM | #1030 |
RCC Addict Join Date: Oct 2006 Location: crawlifornia
#coronaryarterydiseaseyum #needsmorebeer Machining and eating are very similar apparently. Nice radius on that bite... What was your chew load and feed rate on that burger? That billet of beef needs hogging Where's the HDPE version of the case bottoms? Those look nice by the way. |
06-30-2014, 04:00 PM | #1031 | |
That been my XR hater tag line since I first saw one. J | |
06-30-2014, 04:16 PM | #1032 |
Alright! Daaaang. Be back in a week. Thanks! |
06-30-2014, 04:28 PM | #1033 |
06-30-2014, 06:23 PM | #1034 | |
J | |
06-30-2014, 09:02 PM | #1035 |
RCC Addict Join Date: Mar 2009 Location: The REAL Nor-Cal
Try Vespel. |
07-02-2014, 07:38 AM | #1036 |
| Blue Voodoos |
07-06-2014, 03:54 PM | #1037 |
RCC Addict Join Date: Jul 2008 Location: San Diego
WOW Those Berg case are a work of art. If I had the I would put them under glass and frame them.
07-06-2014, 04:54 PM | #1038 |
Ran those blues yet champ?
07-07-2014, 08:03 AM | #1039 |
| Taking Blues from Hop to Hunt... Short answer: promising. I put 6 packs on them on them on high traction granite. As with any new tire they were audibly and visibly poppy and hoppy with decent bite. Another 10 packs and the leading angled edge of the lugs will be a bevel. At that point I think they will be at their best blend of forward response due to broken traction (hunt) vs vertical response to broken traction (hop). I siped them as I have done all of my silvers FYI. Like a dummy I messed up one while reducing it so I have 7 tires now. It's the first one I botched so I guess it was a matter of time. I'll need to get one more in order to build/wear a comp ready set once I've defined optimum wear. Did I miss anything? J |
07-07-2014, 09:23 AM | #1040 |
Try to Bend it Join Date: Aug 2009 Location: Perth Australia
