08-14-2014, 02:44 PM | #1101 |
Rock Crawler Join Date: May 2009 Location: Calgary
| Re: Skaldiddog's "Progress"
This thread needs a new burger picture. Just sayin'. |
08-14-2014, 03:00 PM | #1102 |
Are you just adding these to the front inners or more?
08-14-2014, 03:20 PM | #1103 |
2013 2.2P Nat. Champion Join Date: Sep 2009 Location: BorderLine Crawlers Season 3 is on!
| Re: Skaldiddog's "Progress" |
08-19-2014, 09:05 AM | #1104 |
| Annual buff-out
It was time again for the annual front axle overhaul. Thrashed servo, knuckle bushings, knuckle bearings, teflon motor skid and less than optimal CVD pin slop. First off were the CVD pins. This time I was able to increase the pin OD from 0.0930" to 0.0935" on the short side and 0.0940" on the long. Nice press fit into both holes on each cup. The barrels tightened up a little bit too. The old pins showed the telltale narrowing on each end where the S300 wins the battle every time. CVDs now have less slop and more beef. Knuckle bushings were way trashed. I installed my last set of "stock" VP spec bushings but they are still too loose. The top holes in the knuckles have expanded over the years. Next year I'll make custom bushings for each hole. Less slop and more beef yet again. Bearings were all feeling worn and new ones still press fit nicely. VP rocks! Teflon skid gooped overnight under 5 cable ties so it's on. I'll button her up tonight and break everything in over the next two weeks. I went gay and fine sanded the mill "side" finish on the leading edge of my tie rod (not pictured). It looks all fancy now. Looking forward to crawling with all y'all Yankee-Canadians and hoping the weather holds. J |
08-23-2014, 05:57 AM | #1105 |
Try to Bend it Join Date: Aug 2009 Location: Perth Australia
Nice one buddy, good luck in RI here's to making it back to back championships.
08-25-2014, 07:51 AM | #1106 |
08-25-2014, 09:29 AM | #1107 |
| Boneheaded |
09-06-2014, 07:46 PM | #1108 |
Good luck in the morning buddy |
09-07-2014, 11:05 PM | #1109 |
Rock Crawler Join Date: Mar 2008 Location: Not painting
Can-ah-may Saw-(wãh)-gah-shêar-ah
09-09-2014, 07:48 AM | #1110 |
09-09-2014, 07:50 AM | #1111 |
09-09-2014, 08:02 AM | #1112 |
Way to back up a win with a top 5 champ. |
09-09-2014, 08:29 AM | #1113 |
09-09-2014, 02:58 PM | #1114 |
RCC Addict Join Date: Apr 2012 Location: Williamsport, PA
Joel it was great meeting you man. Awesome driving this weekend and thank you so much for giving JSlick and I some relief from judging Saturday.
09-10-2014, 08:08 AM | #1115 | |
| Re: Skaldiddog's "Progress" Quote:
J | |
09-10-2014, 11:58 AM | #1116 |
| Donged |
09-10-2014, 12:29 PM | #1117 |
| Re: Donged
Congrats on the top 5! How many years in a row have you been able to do that? 4 now? |
09-10-2014, 03:11 PM | #1118 | |
| Re: Donged Quote:
4 it is (2011-2014 4,4,1,5). That's a record. So is not finishing the finals course any of the 4 times. Hope to fix that one day. J Last edited by SkaldidDog; 09-10-2014 at 03:25 PM. | |
09-24-2014, 07:54 AM | #1119 |
| Dogs |
09-24-2014, 12:59 PM | #1120 |
| Re: Dogs |
