Thread: Red Threadlock
Old 02-15-2013, 01:17 PM   #1
Default Red Threadlock
Hi guys, just wondering why sort of Threadlock you all refer to as 'red Threadlock' because I have just looked and there is just too much choice
Any help would be greatly appreciated
ROCKST*R is offline   Reply With Quote
Old 02-15-2013, 01:42 PM   #2
Default Re: Red Threadlock
I usually use BLUE (242) unless I never want to separate the parts again, then I'll use red (271).
offroadace is offline   Reply With Quote
Old 02-15-2013, 02:07 PM   #3
Yes, do NOT use red unless you NEVER want to separate the parts. It is technically possible, but it's messy. Blue works for 99% of uses.
hibbs is offline   Reply With Quote
Old 02-15-2013, 02:34 PM   #4
www.ottsix.com
If you use RED and want to remove the bolt or screw later, touch your soldering iron to the area for a few seconds and it'll come right off
crawl-o-matic is offline   Reply With Quote
Old 02-16-2013, 09:06 AM   #5
Thanks a lot for your reply it was just what I wanted, I have previously used loctite 243 for everything and the tube I had has just run out and I wanted some more of that but also some red for permanently locking things and didn't know what sort I should get
Thanks for the tips guys, I wouldn't put it onto anything I want to remove but the soldering iron trick sounds good
Red Threadlock - Similar Threads
Ok to use threadlock on the BWD widener barrel nuts? StickyWheels Losi Micro-Rock Crawler 4 01-02-2012 12:47 AM
Removing ThreadLock rctoyguy Tools, and Procedures 15 10-22-2010 05:06 PM
Red XJ CarLo Axial SCX-10 16 07-12-2010 10:31 PM
Breaking the loctite threadlock bond JohnRobHolmes Tools, and Procedures 12 10-17-2006 04:01 AM
