02-06-2011, 10:59 PM | #561 |
Pebble Pounder Join Date: Jan 2011 Location: Mtz
Hey John, I just bought a br-xl fom u and love it. I am wanting to upgrade my motor to one of your pro handwounds. Just wondering when they will be back in stock. I was looking at either a 35 turn or 45 turn. What would you recommend for an ax-10 with 3s lipo, stock gearing and your br-xl esc. Thanks in advance.
02-07-2011, 07:45 AM | #562 |
I have both here, I will be sure the site shows inventory. Either would be a good choice. If you favor runtime, get the 45t. If you favor power and speed, get the 35. |
02-21-2011, 09:33 PM | #563 |
Jeep whore Join Date: Aug 2008 Location: Florida
would you reccomend these motors for heavy rigs? lets say over 10 pounds?
02-22-2011, 06:41 AM | #564 |
Single motor? Dual motor? How much power and speed you need? When geared slow enough it would be no problem, but if you plan to do 10mph mud bogs I think you would need to rebuild them every 30 minutes.
02-22-2011, 10:12 AM | #565 |
LOL, single motor, i would say slow to medium speed, i'm not going to do race the darn thing lol. i just want more torque then speed really. what tooth pinion would you reccomend? the rest of the drivetrain is axial parts( axles, trans) edit, not sure if it would matter but ill be running a 3s lipo |
02-22-2011, 10:24 AM | #566 |
You would be safe with a 45t to 35t motor if you aren't wanting too much speed. Maybe 40t as a good compromise. Start with a 14t pinion.
02-22-2011, 10:53 AM | #567 |
Okay, sounds good Thanks
02-23-2011, 12:58 PM | #568 |
Just updated the specs and site a bit. We can build these with laydown brushes at your request, just select the option on the motor page. Super easy and streamlined, although I do not recommend that option for the average person.
03-07-2011, 07:51 PM | #569 |
I wanna be Dave Join Date: Aug 2004 Location: san jose
hey John When are you getting in some more HH 540 16 turn motors in or even some 20 turn in. thanks |
03-07-2011, 11:17 PM | #570 |
I wanna be Dave Join Date: Sep 2006 Location: Stuck on a Rig in the middle of nowhere Utah.
I have been trying to learn more about motors but I still have a couple of questions. For my TTC rig I am looking for good low speed torque and control with massive wheel speed. I am going to run an Axial trany and gear it LOW. I am thinking of using 4s to 6s for the speed. What motor would handle the higher voltage better? And is lay down or stand up brushes better for this? It will be seeing water and mud. If need be, I can just run 3s. Just need some in put on motor selection. I would like it last. Thanks |
03-08-2011, 05:59 AM | #571 | ||
Be wary that the motor will wear fast. You will need to rebuild it every 20 to 30 minutes of runtime, and possibly more so when you get into water and mud. Putting an outerwear type filter on it would be a good idea. Alternatively you could use a big brushless motor. I have some customers using the Tekin T8 motors. They aren't cheap, but they are a big step above a 540 in power (and weight). | ||
03-08-2011, 06:58 AM | #572 |
Rock Crawler Join Date: Jan 2006 Location: Southwestern Pa.
| Does the rebuild interval also apply to my 55t on 6s? And by rebuild, do you mean new brushes and checking the commutater?
03-08-2011, 07:03 AM | #573 |
Depending on how you drive, a 55t on 6s will wear pretty fast too. 30 minutes would be a good interval for checks. New brushes and a comm cut would be standard for the rebuild, although you may not need new brushes so often being that it is a less amp hungry motor.
03-08-2011, 10:26 AM | #574 |
RCC Addict Join Date: Oct 2009 Location: Nanaimo, BC (Vancouver Island)
Hi John, I'm in need of a 35t torquemaster pro handwound for my Honcho, whats the chances you have one I can buy off of you, site says your out. Do your motors come pre broken in? Thanks Kurt
03-08-2011, 10:57 AM | #575 |
They come ready to go and broken in. I have some 35t fat packs here, and one 4mm web arm I could build up. If you want to select "custom" and put in your order for a 35t I can build it up for you. |
03-08-2011, 06:19 PM | #576 |
Just finished up a batch of 45t and 45t matched sets, on the site and ready to rock.
03-08-2011, 09:36 PM | #577 |
Rock Stacker Join Date: Apr 2010 Location: Portland/Vancouver
Any chance you have some 35T sports laying around that your site isn't updated with? edit...... (sorry...just realized I posted in the handwound thread :/) Last edited by Shot-N-The Dark; 03-09-2011 at 12:12 AM. |
03-09-2011, 03:45 AM | #578 |
Not right now. About 4 weeks for more machine wound stuff to hit port.
03-09-2011, 10:39 AM | #579 |
hey John What would be better the 20 turn motor or 16 turn in a scaler.Would one crawler better then other. thanks. |
03-09-2011, 10:56 AM | #580 |
Both TorqueMaster design? The 20t will crawl better. The 16t will probably just smoke unless you have some hellatious geardown to keep it from spinning slow under load.
TorqueMaster Pro Handwound Rock Crawler motors - Similar Threads | ||||
R1 w/ HH TorqueMaster Pro 540 Handwound | nafie | Electronics | 2 | 07-16-2011 10:12 AM |
