07-12-2011, 04:56 PM | #621 |
I can't guess correctly at the weakest link in the chain, sorry I would say run a slipper clutch to keep the impact down, and don't be full throttling with the wheels at full lock. Rear gears are suspect if you come down hard on the rear under throttle. You would need an aluminum axle housing to take that sort of abuse.
07-12-2011, 05:57 PM | #622 |
Quarry Creeper Join Date: Mar 2011 Location: Kailua
Thanks for the info. I will be putting in an order soon.
07-18-2011, 12:14 AM | #623 | |
Newbie Join Date: Apr 2011 Location: Willamette Valley
Thanks! | |
07-18-2011, 07:41 AM | #624 |
If you don't care to compete and you can run 3s lipo, a 35t motor can work pretty well for you. Otherwise something around a 27t or 13t Crawlmaster would be my suggestion. Handwound will have more power and torque. On the wraith it would be very noticeable.
07-18-2011, 04:45 PM | #625 |
Thanks for the reply. I plan on using a 2S lipo. It sounds like I'll go with the extra power and torque of a handwound motor. Thanks! |
07-26-2011, 11:36 PM | #626 |
RCC Addict Join Date: Nov 2009 Location: Tulsa
Ok I am just about done with my sportsman just need a motor to get it running. I am running a cc sidewinder on a 1000 mah 2s lipo I want good wheel speed and lots of torque. I like the sport version for the price at this point. I will upgrade latter. I just can't decide between 45 and 35 turn. I have never really comped before so this is new to me. What do u think.
07-27-2011, 06:44 AM | #627 |
Go 35t.
07-28-2011, 01:06 AM | #628 |
Rock Crawler Join Date: Jun 2010 Location: Yelm,WA
John, How short should we let the brushes get before we replace them? |
07-28-2011, 07:40 AM | #629 |
Shorter than 7mm is my cutoff.
07-28-2011, 10:40 AM | #630 |
07-28-2011, 10:45 AM | #631 |
Spring tension gets too low and arcing occurs.
07-28-2011, 12:49 PM | #632 |
07-28-2011, 02:58 PM | #633 |
If you remember, please post up when you get more 35t's in stock |
08-04-2011, 06:58 PM | #634 |
20t through 45t on 5mm web in stock now |
08-04-2011, 10:19 PM | #635 |
RCC Addict Join Date: Sep 2009 Location: sacramento
john with the 28 turn crawlmaster what is the biggest pinion whould you use on 3 s
08-04-2011, 11:11 PM | #636 |
RCC Addict Join Date: Nov 2008 Location: Santa Fe, NM
08-20-2011, 01:03 PM | #637 |
Pebble Pounder Join Date: Jan 2009 Location: THE OTHER STATE OF MAINE
| 4s on torquemaster pro?
I recently picked up a new hh brxl and a 21t torque master pro Can i safely run 4s voltage on that motor? It will be in a wraith with stock gearing and tire size. 99 % of the time I plan to run 3s.
08-20-2011, 05:48 PM | #638 |
Newbie Join Date: Jul 2010 Location: Georgia
Any idea when the 35T motors will be back in stock? I need a matched pair. Thanks.
08-21-2011, 01:29 PM | #639 |
Also, I just noticed on your site that the mamba micro pro is not recommended for TorqueMasters 35t on 3s lipo. I know a few people still use them without issues but would it be safer if I went to a 45T for my XR10?
08-30-2011, 12:14 AM | #640 |
Newbie Join Date: Apr 2008 Location: australia
Gday mate just wondering when the 20t will be in stock, or do i have to order one as a custom motor.
TorqueMaster Pro Handwound Rock Crawler motors - Similar Threads | ||||
R1 w/ HH TorqueMaster Pro 540 Handwound | nafie | Electronics | 2 | 07-16-2011 10:12 AM |
