Go Back   RCCrawler Forums > Vendors > Holmes Hobbies
Thread: TorqueMaster Mini - Losi Replacement motors! (discontinued)
Closed Thread
Old 02-08-2009, 06:40 PM   #61
Got any of these in?
Later
Farmer
Farmer is offline
Old 02-08-2009, 06:45 PM   #62
I just ordered one a few min ago on the sit....hurry
clarkrw3 is offline
Old 02-20-2009, 10:28 PM   #63
Are there any in stock? I ordered mine over two weeks ago. You guys are usualy fast at shipping.
Whats up?
90SouthCrawlers is offline
Old 02-25-2009, 08:26 AM   #64
Whats up?
John I wanted to thank you for looking into my problem and making it right.
Holmes Hobbies is a kick "ace" vendor:-P
Old 03-25-2009, 11:51 AM   #65
Hey, has anyone run one of these on 2s A123 1100mah? Just wondering how it would be on the lower 6.6 volts.
Would these cells keep up in a 1s configuration(30amp)
Any idea JRH?
thanks
gimpygolden is offline
Old 03-25-2009, 04:01 PM   #66
owner, Holmes Hobbies LLC
JohnRobHolmes's Avatar
2s 1100 mah a123 would work well, although wheelspeed may not be stellar. Totally fine on the 1p configuration though.
JohnRobHolmes is offline
Old 03-25-2009, 07:17 PM   #67
Cool thats what I wanted to hear.
Thanks
Old 03-27-2009, 11:12 PM   #68
Hey John, Do you have any idea when you'll have more in stock?
Old 03-28-2009, 06:54 AM   #69
A couple of days
Old 03-28-2009, 10:57 AM   #70
jeeper_05's Avatar
hey John, I have the one of the original runs of this motor, and I keep hanging brushes, I heard this is a common problem, what do i need to do to fix this?
jeeper_05 is offline
Old 03-28-2009, 11:43 AM   #71
Email me with your addy and problem, I will send out replacement brushes.
Old 04-10-2009, 03:20 AM   #72
Mine are hanging up to, did you get my message via your site?
Joat is offline
Old 04-10-2009, 06:22 AM   #73
Will this motor handle 11.1 volts?
youngblood is offline
Old 04-10-2009, 09:50 AM   #74
What do y'all mean by "hanging brushes"? I'm wondering if it's the same issue I've been having. Over time my motor would basically stall. I could flick it with my finger and it would start up again, but it would soon stall again after a little while. I ended up pulling the brushes out, cleaning it with brake cleaner thinking it was just dirty, re-installed the brushes and dabbing some oil on the bearings, and it's pretty much worked fine since with no stalling.
Is there something else going on I'm unaware of?
FWIW, I think I may have one of the earlier runs of this motor, too, but I'm not really sure.
Thanks,
Tommy
Tommy R is offline
Old 06-25-2009, 03:14 AM   #75
Location: Long Island-Land of one batch of rocks in Sag Harbor and at least one fellow crawler
How will this motor perform with the stock esc and battery? If I MUST upgrade the ESC what do you reccomend?
eddievedder is offline
Old 06-26-2009, 07:22 PM   #76
Old guy
ROCKEDUP RICKY's Avatar
Hey John, I put one of these motors in my TLT based MRC on a axial tranny. Geared it low, but I have no drag brake at all. Got it on a Rooster ESC. How could I inprove my drag brake, maybe a different ESC.
Other than that great little motor, got lots of wheel speed for my rig. And the weight difference from the 35t motor I had in there really helped my CG.
ROCKEDUP RICKY is offline
Old 07-20-2009, 02:24 AM   #77
when will more of these be in? thanks
Tklan Crawler is offline
Old 08-01-2009, 04:16 PM   #78
These motors are currently on hold for the next production. I would recommend any of the Reedy, Epic (trinity), or Novak mini motors as a quality motor.
If you need replacement parts, I still have stock in the replacement part section.
I expect to produce more in the next three to six months.
Old 12-18-2009, 11:26 AM   #79
Just got a box in, factory fresh. I have 33 turn motors on the site, which was the origional turn count I found out. I also have some 22 turn motors here if anybody is interested...
Old 01-11-2010, 09:29 AM   #80
Doh, forgot to unlock this thread when I posted.
Closed Thread
TorqueMaster Mini - Losi Replacement motors! (discontinued) - Similar Threads
Holmes Hobbies Torquemaster Mini 33 VS 22 turn Motors Paul97 Losi Mini-Rock Crawler 19 02-25-2010 11:44 AM
TorqueMaster Mini Giveaway Again!!! Losi Replacement motors! JohnRobHolmes Losi Mini-Rock Crawler 110 10-28-2008 10:46 AM
TorqueMaster Mini Giveaway! Losi Replacement motors! JohnRobHolmes Holmes Hobbies 156 10-20-2008 02:46 AM
You may edit your posts
