12-28-2017, 12:04 PM | #41 |
Quarry Creeper Join Date: Jun 2007 Location: east michigan
| Re: The venture is here! |
12-28-2017, 12:30 PM | #42 |
RCC Addict Join Date: Feb 2008 Location: your back yard
12-28-2017, 02:25 PM | #43 | |
Rock Crawler Join Date: Dec 2009 Location: Suffolk
| Re: The venture is here! Quote:
Untitled by JASON MCKIMMEY, on Flickr | |
12-28-2017, 04:53 PM | #44 |
I'm liking the SCX-10 Honcho wheels on the FJ. Substitute some hex head scale hardware for the stock beadlock hardware and I'd say that they would be a perfect set of trail beater wheels. Those flats on the CV shaft could be used as a guide to extend the flats down far enough on the shaft to fully engage the spool. |
12-28-2017, 05:56 PM | #45 | |
Quarry Creeper Join Date: Sep 2012 Location: St louis
Lol thats what I was thinking, I will be doing that to a set of vvds, just haven’t yet. The axial beadlocks are growing on me but I think I’m gonna spray them white. Sent from my iPhone using Tapatalk | |
12-29-2017, 12:43 PM | #46 |
12-29-2017, 01:00 PM | #47 |
If you guys don’t know already, the scale king (exclusive RC) is making all kinds of stuff for our ventures. I see a dash, seats, etc all in the making They already have a snorkel, couple cool rotopax mounts, door handles,grille and wipers. I myself ordered the snorkel and rear window rotopax mount today. Also sensored brushless system is on order as well Sent from my iPhone using Tapatalk |
12-29-2017, 01:42 PM | #48 |
Thanks for the info. One of the first things I did was tuck the bumpers in as close as I could. Fj is looking good with those wheels. Sent from my SM-G930V using Tapatalk |
12-29-2017, 01:55 PM | #49 | |
Sent from my HTC U11 using Tapatalk | |
12-29-2017, 01:59 PM | #50 |
12-29-2017, 02:18 PM | #51 |
Ended up just getting the snorkel. It does look super scale! Can’t wait for the interior parts. My links should be shipping to, just waiting on the PayPal to the guy and he will be sending them! Sent from my iPhone using Tapatalk |
12-29-2017, 02:54 PM | #52 |
Ok, after a quick test run in the backyard rock garden, the steering leaves a lot to be desired in the servo department, lol. I also was wondering what was restricting the turning radius. So I took it apart and found the little steering stops on the c-hubs. A few minutes of dremel work and they were gone. No change in steering angle. So after some more investigation the dog bones themselves are the actual limiting hard stop. I confirmed this by taking them out and putting the knuckle back together and immediately gaining a good bit of steering. So my next experiment was to see if anybodies' CVD's would fit. I tried SCX10 OE, Ascender, and SCX10.2. None of them fit. The closest to working was the SCX10.2 U joints but they won't work because of the inner big bearing in the knuckle. The knuckles will not swap either as the "C" is narrower on the venture. On all the others the CVD portion of the axle would not fit in the C-hub. So looks like we are waiting for HPI or the aftermarket to develop some CVD's or u-joints that will fit these C-hubs so we can get some more steering angle. |
12-29-2017, 02:57 PM | #53 | |
Yeah I had already tried that lol, had the same idea as you at first but nothing will swap over. Gonna just wait for those aftermarkets. Sent from my iPhone using Tapatalk | |
12-29-2017, 10:09 PM | #54 |
Did a little tinkering tonight. Really wanted to mount a winch and my biggest pet peeve (it’s just and opinion) but winches that hang off the bumper. It looks tacky to me, then there is less approach angle, bumper is really far from the body, etc etc. Got the fair lead mounted to the bumper, and winch to the frame/ bumper mount. No rubbing and it works excellent. Only lost about 1/8 of inch of bumper clearance from the body, which is nbd to me. Here’s what I came up with Yes the winch mount is slightly crooked, broke a drill bit and in turn lost my nice starting hole lol Sent from my iPhone using Tapatalk |
12-29-2017, 11:14 PM | #55 |
Found some more time to do something that protects the inside of the truck. WHEEL WELLS! Coincidentally, my wife got new Tupperware for Christmas so what a better time to make some out of her “cheaper” stuff. I’m sure you’ve all seen this before so I’m not gonna explain how to do it. Just take a look at the pictures! I will be hitting them with a few coats of back spray paint. Sent from my iPhone using Tapatalk |
12-29-2017, 11:21 PM | #56 | |
12-30-2017, 10:55 AM | #57 |
Guess what today is.... nvm I’ll tell you, Paint wheel wells and wheels. 2- coats outside of wheel well 2- inside 3 coats white on wheels and 1 coat clear It’s a little cold out side lol 15* but I’m only taking them outside to paint then right back into the warm! I’ll install everything tonight and put up some pics. Sent from my iPhone using Tapatalk |
12-30-2017, 02:12 PM | #58 |
Paint was dry enough to work with, couldn’t wait to get it together. Wheel wells installed, and wheels put back together! Sent from my iPhone using Tapatalk |
12-30-2017, 11:51 PM | #59 |
Decided to go ahead and move the battery tonight. This is what I came up with. It’s not perfect, it’s not beautiful, but it should work. Removed esc (it already looks like a perfect spot to mount s battery!) Had to shim up some to get the clearance from the dog bone to the transfer case. Being that it doesn’t flex, I have around 1/8 of inch, so rubbing should never be an issue. Before it was all tightened up Need to grab another battery strap but she fits, and it works Sent from my iPhone using Tapatalk |
12-31-2017, 06:03 AM | #60 |
Looks good. Do you think you would have enough slack in the wires to get the ESC mounted in the forward part of the factory battery tray?
The venture is here! - Similar Threads | ||||
Just ordered a venture | dwblue00 | HPI Venture | 39 | 01-07-2018 06:35 PM |
No HPI Venture | Frank211 | General Scale Talk | 111 | 12-14-2017 04:55 PM |
My HPI Venture is on it's way... | QuesoDelDiablo | 1.9 Scale Rigs | 86 | 11-29-2017 04:58 PM |
Another venture. | aubie | Chit Chat | 6 | 12-25-2005 05:35 AM |
