Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > HPI Venture
Thread: U/d for the venture?
Old 03-01-2020, 10:54 AM   #1
Default U/d for the venture?
Is there anybody making under drive for the venture? Are they all a standard fit?
crazee horse is offline   Reply With Quote
Old 03-01-2020, 10:57 AM   #2
Default Re: U/d for the venture?
The Ventures ring/pinion geometry is not interchangeable with any other brands. You'd have to custom install a transfer case with od/ud built into it.
meatmonkey is offline   Reply With Quote
Old 03-01-2020, 12:05 PM   #3
That's ain't good. Thanks for the reply bud
Old 03-02-2020, 11:18 AM   #4
I can't remember what he his name was but there's (at least) one guy that achieved overdrive to the front axle but flipping the T-Case upside down.
QuesoDelDiablo is offline   Reply With Quote
Old 03-04-2020, 11:39 AM   #5
R2j
SORRCA Committee Member
R2j's Avatar
I run the Deadloc t-case that has O/U drive in both of mine.
https://deadloc-racing.myshopify.com...16727917264967
R2j is offline   Reply With Quote
Old 03-04-2020, 01:51 PM   #6
I just don't understand why you can't just change the gears in the diff?
Old 03-04-2020, 03:23 PM   #7
Attachment 387607
Think that's got my name all over it... 😂
Old 03-05-2020, 10:31 AM   #8
Short answer - because no one makes gears that would fit. Every company has their own unique diff/gear geometry and no one has made gears specific for the Venture.
Old 03-05-2020, 10:45 AM   #9
Luck for us the Venture has a divorced transfer case so UD/OD is possible with a different transfer case (like what Deadloc has done). I just designed a transfer case for the Trail king (making it more compact and a left drop) and now I feel like I might have the ability to come up with something for the Venture.
Hmmm... I'll have to tear down my t-case to see what I can do with it. I think I'll be able to re-use the shafts and 2 of the gears so I'll just need to look out for other gears that are a good fit. I'm still not great at calculating overdrive ratios so if anyone has recommendations I'd greatly appreciate it.
HumboldtEF is offline   Reply With Quote
Old 03-05-2020, 04:14 PM   #10
Sounds great and I'm sure you could make some money if you were to sell some!!!
Old 03-05-2020, 05:40 PM   #11
I was doing a little research and now I see (or i'm reminded rather) that the front and rear outputs on the stock T case share the same gear so I'll need to come up with a way to split them up.
I was thinking it would be as simple as getting some of the stock t-case gears and reconfiguring them but theres a little more to it.
If I do come up with something it would be a 3D printed case and I'd most likely just share the files and list the parts required.
Old 03-07-2020, 11:23 AM   #12
Please come up with a new t-case housing. Additional gear reduction with and od/ud option would be the hot ticket.
Old 03-21-2020, 10:24 AM   #13
So I've just read on Facebook that flipping the transfer box gives overdrive to the front, can anybody confirm this?
Old 03-21-2020, 10:58 AM   #14
I heard that as well, just tested and yes it does overdrive the front. Thanks for the reminder.
you will need to grind a bit off the end of the new output shaft for the front so that the driveshaft can attach, probably 1mm or so.
Now I'm gonna see if I can design a new case to accomplish this using the stock guts.
Old 03-21-2020, 11:20 AM   #15
Looks like I need to dig that Venture back out for some play time!
soze is offline   Reply With Quote
Old 03-21-2020, 11:23 AM   #16
Flipping the transfer case will give you 50% overdrive to the front, this is the same amount that TF2 guys use for C1 competition. If you go the the route of flipping the transfer case, you will need to re-gear the transmission. Basically you will need a smaller pinion on the motor and a larger spur gear on the trans. If you don't re-gear you will fry your motor.
Dezertdirt is offline   Reply With Quote
Old 03-21-2020, 11:34 AM   #17
Originally Posted by Dezertdirt View Post
snip
Thanks I'm no good a gear ratio calculations.
The unfortunate thing is gearing down is not really easy, there is no space to run a larger spur in the housing (also there are no larger spurs available) and gearing down with the pinion is limited though I do have a new motor mount that allows a little more gear down.
https://www.thingiverse.com/thing:3569491
Yeah it basically removes any gearing down that the T-case used to do and its 1:1 from the tranny to the rear axle and for the front it gears up.
Dang, the terrible Venture gearing strikes again!
Old 03-21-2020, 02:43 PM   #18
One thing you could do is get a GRU like this one, amazon used sell similar ones.
https://store.rc4wd.com/31-Ultra-Com...tor_p_780.html
Old 03-21-2020, 02:58 PM   #19
True, I actually ran one on my Venture early on. I'm still not sure I want 50% overdrive though.
I'm gonna try to mess around with this gear generator to see what I can come up with, looks like a handy little tool (first I've seen of it so I dont know much yet)
This is setup as the stock T-case (tooth count only)
https://geargenerator.com/#300,300,1...0,0,0,0,0,3,96
U/d for the venture? - Similar Threads
MT Venture TAT76 HPI Venture 51 01-29-2020 12:32 AM
My Venture Tchinghar HPI Venture 1 06-11-2019 03:04 PM
My Venture Delta5Actual HPI Venture 2 05-19-2019 03:51 PM
The venture is here! Jfrisch01 HPI Venture 127 03-06-2018 07:34 PM
Another venture. aubie Chit Chat 6 12-25-2005 05:35 AM
