04-19-2010, 10:49 AM | #61 |
I wanna be Dave Join Date: May 2006 Location: akron
04-19-2010, 11:04 AM | #62 |
Just jump it! Join Date: Aug 2008 Location: Cedar City, Utah
04-19-2010, 11:05 AM | #63 |
Quarry Creeper Join Date: Apr 2009 Location: sandia park, nm
damn. think i'll get some different parts to see if i can make something work. other than bearing size, are the axial ones close? like if got different size bearing, or knuckle might it work? just answered my question, thanks rotten. |
04-19-2010, 11:11 AM | #64 |
| I tried to put the axial knuckle on my RCP Hub carriers, Tight fit, i could probably make it work. But the axial shaft part is to short to reach the differental hole.... Story of my life, to short again!!
04-19-2010, 11:14 AM | #65 |
Rock Crawler Join Date: Feb 2006 Location: Where the foams are always wet
I have heard of people running axial knuckles with WK axle C's. They use the stock axial stub and the WK dogbone. It takes about 1/2" off the track width. Might be a good way to get high-steer....
04-19-2010, 11:17 AM | #66 |
Heres your problem with the CVD's though. Too short. Last edited by rottenbelly; 04-19-2010 at 11:24 AM. Reason: Fixed info |
04-19-2010, 04:55 PM | #67 |
Quarry Creeper Join Date: Jul 2008 Location: South Dakota
I think the bearings have the same I.D. I just stuffed a WK dogbone in an old wk hub and it was a nice fit. Just way to short like rottenbelly shows.
04-19-2010, 07:17 PM | #68 |
Pebble Pounder Join Date: Jan 2006 Location: Brockville
@ rottenbelly... so the axial knuckles will fit the rcp C's? so you could use an axial cvd and the hex pin would line up and everything, but the shaft just won't reach the locker? if this is the case.. i'd cut the axial cvd in the center somewhere... slip my bearings on.. and weld a piece of rod in there... iam poor so id just use a piece of an allen key..lol... for those of us with welders..
04-19-2010, 07:36 PM | #69 | |
The rest of your idea sounds good. I was thinking you could use a long berg dogbone and cut it down a little. You can see how much thicker it is at the dogbone area. Should hold up a bit better along with the axial cups. | |
04-19-2010, 09:27 PM | #70 |
Why doesn't some one buy these: http://www3.towerhobbies.com/cgi-bin...?&I=LXHLX4&P=7 as a test subject. They would have to have the end cut off and filed to the same dimension as a stock shaft so they fit into the diff. but it's worth a try.
04-19-2010, 10:15 PM | #71 | |
04-20-2010, 09:21 AM | #72 |
how about these? says they are 5x171. should fit with a trim job. http://www3.towerhobbies.com/cgi-bin...ssing%20Data** |
04-20-2010, 09:53 AM | #73 |
Something to look at is going to be the length of the wheel hex to knuckle measurement. Now you guys got me thinking!! Guess i will take my calipers to the hobby shop. |
04-20-2010, 11:38 AM | #74 |
i was trying to find one with a cup end to use the still good outers, but no such luck, yet. most are too thick or too short.
04-21-2010, 03:26 PM | #75 | |
Rock Crawler Join Date: Sep 2007 Location: Denmark
Yes.... they use 6x12mm bearings ..same as the LST cvd's | |
04-22-2010, 02:31 PM | #76 |
| http://tcscrawlers.com/Super-300-Sup...s-p-18076.html Just found Super 300's for Super class crawlers. Comes with two long shafts. So you would have to shorten them up a smidge for a WK. Then figure out how to mount up a stock Berg steering knuckle. Last set of axle shafts you would ever have to buy, that's for sure! I bet you could do it all for $175, hahahaha! |
04-23-2010, 02:34 AM | #77 |
Quarry Creeper Join Date: Apr 2008 Location: San Diego
No one wants to try and bug RCP into doing another order? I am sure if we get enough people willing to preorder we can get something done. I wanna get at least 2 sets... |
06-01-2010, 10:35 PM | #78 |
RCC Addict Join Date: May 2009 Location: NHFF world headquarters, working on the "rock mauling hill shooting NHFF pig squealing death rocket"
any more updates on, finding out what axles will fit, finding out if anymore will be made, and just what the heck are we to do with our wk axles? i have wk axles in my scale buggy and now i hate to beat on it because i know i cant get anymore cvd's.
06-04-2010, 09:18 AM | #79 |
Newbie Join Date: May 2007 Location: Guam
Here's build using T-MAXX cvd's. I hope this helps you guys out. Hustler style full droop Wheelie King Last edited by Pangasinan; 06-04-2010 at 09:24 AM. |
06-04-2010, 11:34 AM | #80 |
Rock Crawler Join Date: Jul 2005 Location: Rathdrum, ID USA
Some manufacturer is really missing the boat on this one. With all the WK's out there it sure looks like the demand is there. Has anyone contacted MIP directly to see if there is any reason why they have not brought the WK CVD to market? Did RCP have some legal rights to the WK CVD. Of all things why has HPI not become involved? I know all their stuff uses dogbone type drives, but you would think HPI would want to step in on this? I have a few sets of the RCP WK CVD's, but I continue to run the stock axle shafts in my crawlerfied WK. I don't do comps, but I have not broken a stock shaft in a long time. Driving style, or just lucky?
