Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Kyosho Crawlers
Thread: *** Twin Force Upgrades ***
Old 12-23-2007, 01:59 PM   #61
ghetto fabulous newbie
13/43 #MA050 this is a replacement for the mad force.
yotachump is offline   Reply With Quote
Old 12-24-2007, 09:18 AM   #62
Bart bender's Avatar
Yes it is. Added to the first post. Thanks!
Bart bender is offline   Reply With Quote
Old 12-29-2007, 12:04 PM   #63
Carbon fiber chassis
MAW051
Old 01-03-2008, 03:17 PM   #64
Originally Posted by bretkissick View Post
Was just looking at the Maximizer Locker #2356. Does the CEN LOCKER (ceg-gs013) mentioned earlier also work well, direct fit?
Thanks
Yes the CEN locker is a direct fit. There is a little play when you slide it in the diff case but it works fine. Other than jb welding you can't beat these for the price.
blue-beard is offline   Reply With Quote
Old 01-06-2008, 09:41 AM   #65
COMPLETE TWIN TRANNY
MA101(UNDER PLATE)$8.00
MA102(MOTOR MOUNT)$7.00
MA103(MAIN GEAR SHAFT)$4.00
MA104(MAIN GEAR)$5.00
MA105(SLIPPER SHEET)$3.00
MA106(SLIPPER PLATE)$5.00
MA107(SPRING COLOR)$3.00
MA108(CENTER BULK)$6.00
MA017(DRIVE CHAIN)$11.00
MA016(SPROCKET SHAFT)$5.00
MA010(SPROCKET 11T)$7.00
MA008(SPUR GEAR)$9.00
BRG005(SHIELD BEARING(8X16X5)2PCS)$10.00
BRG006(SHIELD BEARING(6X12X4)2PCS)$11.00
BS52(2.6MM X 16 SHAFT)$3.00
FM352(CLUTCH SPRING)$4.00
(OPTIONAL)MA113(UNDER PLATE MOUNTING KIT)$8.00
___________________________________________
COMPLETE TWIN TRANNY $101.00
OPTIONAL MOUNTING KIT +8.00
$109.00
All you need is the screws to assemble it, and 1 4mm flange locknut.
Old 01-06-2008, 10:42 AM   #66
TEAM MODERATOR
Reflection's Avatar
SWEET!,Thanks Chump.
Reflection is offline   Reply With Quote
Old 01-06-2008, 02:31 PM   #67
I got this in post 62. Just with out dollar amounts.
Old 01-06-2008, 04:10 PM   #68
i was just making things easy.
Old 01-07-2008, 04:59 PM   #69
That's cool just adding the link to the breakdown. Anyone have a complete axle part number, or is there even one?
Old 01-09-2008, 09:12 PM   #70
Release your anger..
ThinkTank's Avatar
Default Perhaps another option for TF R&Ps
I was browsing on Kyosho's website and found that the newer
ST-RR truggy has chromoly R&Ps. I wasn't able to find a part number(maybe RCP could get it) or any useful information.
I'll keep looking.
ThinkTank is offline   Reply With Quote
Old 01-19-2008, 04:58 PM   #71
I found the 777 ST-RR uses 10t pinion IF102 and 43t ring IS101. I though I read this ST-RR was an Inferno but they don't list the Inferno on the parts breakdowns.
Well under a little more investigation this is the ST-RR. They list the light weight swing shafts that it has. Hope this helps.
Old 01-21-2008, 12:09 AM   #72
Will these parts work on a kyosho mad truck 1/10 scale?????
zeroskater9111 is offline   Reply With Quote
Old 01-21-2008, 07:23 AM   #73
TEAM MODERATOR
Reflection's Avatar
These are upgrades for the Twin and Mad Force 1:8 scale monster trucks.
Old 01-22-2008, 06:04 PM   #74
Updated CV shafts post 54 with measurements.
Old 01-23-2008, 03:07 AM   #75
Default Thunder Quake CV conversion
Here is a link that shows how to make duratrax Thunder Quake universal axles work. It looks like a lot of work to me and the stubs are not as beefy, but it is another option I thought I'd throw out there.
http://www.kyoshomonster.com/madjedi/p2_cva.php
jsudar is offline   Reply With Quote
Old 01-23-2008, 08:53 AM   #76
Saw that a couple of months ago, the stubs are 6mm but I think I saw some other Duratrax CVD's in 8mm, I was thinking of buying them and making any length CVD I wanted.But I Never liked Duracrap, oops, I mean duratrax.Also I don't like that these don't use a pin in the stub.
Old 01-23-2008, 02:58 PM   #77
Thanks jsudar, I was thinking of adding links to mods from peoples builds. If this isn't an issue with anyone. Here's the revo shaft mod
http://bruteforce.freeownhost.com/cr...evoshafts.html
Old 02-09-2008, 12:24 AM   #78
Found these while looking around. Aluminum link mounts by New Era.
http://www.neweramodels.com/item.cgi...=&part_id=8954
onespeeder is offline   Reply With Quote
Old 02-09-2008, 08:18 AM   #79
Holy cow. What a score. Very nice Onespeeder.
Old 02-11-2008, 05:28 PM   #80
I'll keep looking.
Did anybody figure out if these work? I found the parts # for the R&P's they are 10/42 ratio.I was reading and it sounds like they are a direct replacement for the ST-R R&P.
This is what it says.
"These are the new harder versions of the ST-R bevel gears."
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/kyosho-crawlers/58270-%2A%2A%2A-twin-force-upgrades-%2A%2A%2A.html
Posted By For Type Date
kyosho madforce kruiser ve - Monster Trucks @ URC Forums This thread Refback 02-22-2013 06:29 AM
