12-28-2011, 04:31 PM | #141 |
RCP CRAWLERS Join Date: Nov 2007 Location: Upland CA
| Re: Tommy's Big Willy
love the track bar set-up I'll try that on the next Willys very nice build thread |
12-28-2011, 04:39 PM | #142 |
I wanna be Dave Join Date: Aug 2008 Location: Austin, TX, USA
| Re: Tommy's Big Willy |
12-28-2011, 05:29 PM | #143 |
Newbie Join Date: Nov 2011 Location: tinley
Great Build, Where do you get the body? |
12-28-2011, 05:38 PM | #144 |
12-29-2011, 08:16 AM | #145 | |
I wanna be Dave Join Date: Oct 2006 Location: Martinsburg WV
| Re: Tommy's Big Willy Quote:
I used aluminum for mine. Which had me doing a lot of creative cutting and manipulation. I even had to make a little jig to bend one part accurately. Looks to me like you arrived at the same point with 1/8th the time and effort!! I should've used steel Hammer Time!!!! Looking spot-on so far Tommy. Nice work on the front end setup. The TSL's look pretty good! I came very close to going with them, but I was afraid they'd be too small... | |
12-29-2011, 09:00 AM | #146 |
RCC Addict Join Date: May 2008 Location: Green Bay
Man. lookin good....another great track bar mount.....I need to dig back into mine, dump the 4 link, add the track bar and move the servo....between you and Mike..your killin me !!
12-29-2011, 09:47 AM | #147 | ||
I love the TSLs on this rig! I had some RC4WD Mickey Thompson Baja Claws, but they were too large. I wanted to make sure the tires tucked into the rear fenders nicely and the TSLs are a near perfect fit. They kinda look like 33's on a lifted Willys. Just what I wanted! Thanks, Darin! I consider it an honor if I'm at all responsible for any improvements you make to your Willys. That think is truly epic!! Keep us updated! | ||
01-03-2012, 02:11 PM | #148 |
I should've known I wouldn't be happy with a plastic bumper. I'm not done with this bumper yet, but you can see where I'm going with it. I need a place to mount my winch, right? And the shape of it will hopefully provide adequate clearance for more steering throw. |
01-03-2012, 03:37 PM | #149 |
Well, that went kinda quickly. I may call it done. I usually run a stinger so I have a good place for the winch hook to attach to, but I think I may leave this one bare. Who knows, maybe I'll do more to it, but if I want to make this month's comp I think I'll leave it for now and move on to more pressing items. |
01-03-2012, 03:54 PM | #150 |
I wanna be Dave Join Date: Feb 2009 Location: Cowtown, USA
I like the bumper there Tommy! BTW, you going to run this rig in C3 at your comps? Oh yeah....I found your new driver, and its 1:6 scale. Finally, A Realistic Steve Jobs Action Figure | Geekologie - Gadgets, Gizmos, and Awesome |
01-03-2012, 03:58 PM | #151 |
I like that front bumper, it looks like it would slide right past rocks on the sides and the tires won't get snagged on it. Do you have any issues w/ the front tires rubbing against the shocks/springs at full steering lock? I got so annoyed at my Orange Jeep w/ the tires turning the pre-load collars that I switched to the internal white 'scale' shocks even though the SCX-10 shocks worked so much better. |
01-03-2012, 04:15 PM | #152 | ||
This won't be my "real" C3 rig. I'm still working on my Wraith for that. But until I get the Wraith up and running again (been waiting on my warranty ESC for 3 months now), this will suffice. It won't be competitive, but it'll be fun! Quote:
01-03-2012, 06:23 PM | #153 |
Yeah, the tires definitely contacts the shocks/collars. It's worse when the suspension articulates. Tires get into the bumper, too, but not as bad as with the previous bumper. A little more offset would help, but not sure I want to do that. I mentioned this earlier, but here's a pic to illustrate. The track bar mount and axle make contact on the driver's side. It doesn't really limit the travel all that much, but it is something I wish I could've avoided. It just wasn't practical to do so. Yes, I know I need to also trim the plastic axle mount. Overall look as it sits now. |
01-03-2012, 09:42 PM | #154 |
I pulled the wheels/tires off the Wraith to check how the offset would work on this rig. They definitely provide more tire clearance and I have inserts to widen the track more if I need to. I really like the white wagon wheels, but they may simply not have the offset I need to work on this truck. This would likely have me considering a color change from my original plans if I stick with the Mayhem wheels. What do y'all think? And ignore the tires. This rig will definitely be running Swampers. |
01-03-2012, 10:37 PM | #155 |
Looking for new Trails Join Date: Dec 2008 Location: GPS locating signal.....
Looking good .
01-03-2012, 11:27 PM | #156 |
Newbie Join Date: Dec 2011 Location: Mont-Tremblant - Québec
Nice Jeep!
01-04-2012, 06:05 AM | #157 |
01-04-2012, 08:57 AM | #158 | |
Could you make or have made a thicker inside piece that would give you more track width? ? Maybe wide hexes with barrel nuts? Kind of extreme, but those wheels really belong on there. No matter what color you pick, they look great... Last edited by Big Mike; 01-04-2012 at 09:02 AM. | |
01-04-2012, 09:17 AM | #159 | |
In addition, a vendor here is selling inserts for these wheels that increase the width 1/4". That would yield another 1/8" of clearance between the tires/shocks. I think I'll be picking up a set of those, as well. I'm going to end up with the most expensive stamped steel wheels ever! | |
01-04-2012, 10:15 AM | #160 |
WOW, lookin real good Tommy. I know I had issues with my stamped Steelies as well with the WK axles. I moved my shocks inboard more to stop the contact to them....I don't think I had bumper contact though. I'll be posting an update to mine tonight, got the 3-link done ! Thanks again for the ideas. |
