Go Back   RCCrawler Forums > Scale Rigs General Tech > Large Scale Rigs
Thread: Just pulled the trigger on a Dragon
Old 08-19-2016, 10:15 AM   #61
Default Re: Just pulled the trigger on a Dragon
Yeah Baby
Cool I got my re-fund sent to my Pay Pal from Oakridge Hobbies
And I also got the UPS tracking order for my Jeep
Its been picked up and on its way
There saying Tuesday the 23rd
Yeah baby
Cotswold just got a new loyal customer
They hooked me up
No bullshit no games
I should of ordered from them
Live and learn again
It shipped today on its way
kgb424 is offline   Reply With Quote
Old 08-19-2016, 09:37 PM   #62
I found this and thinking about buying one or two of these
Its a Dragon 1/6th scale British Welbike
The British Paratroopers used to air drop them
So they could cover ground faster
I could put one in the 1/6 scale trailer with some tie downs
And pull it behind the Dragon Jeep
Old 08-20-2016, 12:07 AM   #63
Originally Posted by kgb424 View Post
I looked to see if you posted your new Dragon
And there is minus signs every where
There is something XXXXXXX wrong with your camera or phone
Cause if I mine are too big, it says in a window it will not post
Mine have never done the minus sign
So I have no idea what's going on with your pics
The minus sign never happened to me
The just don't post
Your's act like there posting, Right ?? but your getting the minus sign
I just don't know, they show up on my phone, tablet, pc and laptop, so I don't know what the issue is....
Bitter End is offline   Reply With Quote
Old 08-20-2016, 01:17 AM   #64
On my old Samsung Galaxy S3, it had problems with the screen rotation when texting it kept changing the screen rotation and flipping back and forth
So if I turned it off, the pictures would post sideways even if the camera was oriented right, cause of the screen rotation setting
My new Samsung Galaxy S6 does the same thing if you chose the portrait setting it locks the rotation, if you use auto setting,it rotates
Some times I have to use the paint program and rotate the pictures then save them
Then when I post them,they are right side up and correct
Its like the camera is over or under rotating them
And some times, I have to resize them before they post
Some time its a real pain in the ass to get the pictures to post if taken on my phone
The pictures from my Sony digital camera are fine, once I figured out the size setting, there is no screen rotation
I Have had no problem with the camera pics posting, I just don't always have my camera on me
So I use my phone and some times have problems but got figured out now
Old 08-22-2016, 08:22 PM   #65
Hey does anybody know if
They make RC4WD axles or some other version of axles for the first generation Toyota axles
I got normal axles in the rear axle, the front axle has the XVD shafts
My problem is if you use VP/Wraith style hubs, so I can use wheels with SLW hubs, the threaded part of axle shafts are not long enough, you barely catch any threads and under power come loose
If I use a thin or thick hub and a RC4WD Wagon wheel there is plenty of threads
Are you not supposed to use those the VP/Wraith styles hubs and SLW wheels
Cause I freshened cleaned and re-lubricated the Toyota axles and noticed the hubs
Old 08-22-2016, 09:42 PM   #66
I don't think you can use the VP/ Wraith hubs with SLW hub wheels
Cause the threads section is not long enough on the RC4WD axles
Not sure if the Toyota 2 axles have a longer thread section
There probably all have the same lenght of threads
You can use a thinner hub to get more threads, but the hub lip leaves a hole
That the lip of VP/Wraith hubs go into, and with out the right hub there is a gap
And I don't like that, it sucks that I can't use my Hutchinson Beadlocks with the TSS Brake drums
I got to use my RC4WD Pro Tens stamped steel wheels and a thin hubs to get enough threads for the wheels to be tight
I don't have this problem with SCX10 axles or Wraith AR60 axles
Only the RC4WD axles are the threads not long enough
Old 08-22-2016, 10:01 PM   #67
Yeah Baby
I checked UPS tracking for my Jeep and its on time
It's supposed to be here 8/23/2016 at the end of the day
It started in Washington state At Cotswold and then went to Oregon and it left today at 11 am
Its now in Sparks Nevada which is about 45 miles north of me
The waiting really sucks, now that's its close
Can't wait to smell the box
Old 08-22-2016, 11:29 PM   #68
Yeah baby
You just got to be smarter then the wheel
I figured it out, use the thin Axial hub and my Hutchinson beadlocks with .475 SLW hubs and I'm getting threads
To the end of the axle and seem tight, I will see what happens
Old 08-23-2016, 08:09 PM   #69
I got my Dragon Jeep and did some mock up
The RC4WD Toyota axles are not wide enough, they might work with some wheel wideners
But I still think the leaf springs would be too far in the chassis too work properly
And the same with the GCM 4 Ten Chassis its not wide enough and it would need to be stretched
The GCM 4 Ten chassis has the wrong profile for the Dragon Jeep
So I guess I'm making new chassis rails for the Dragon and use SCX10 axles
And four link the new chassis
Old 08-23-2016, 08:17 PM   #70
I wanted to use leaf springs and the Toyota axles
I don't think they make wide axles that use leaf springs
And I'm not going to spend hundreds of dollars on axles
I will need another 1 to 1 transfer case and a SCX10 Transmission
I got a set of 100 mm shocks from my Wraith
Old 08-23-2016, 08:30 PM   #71
Has any one here ordered from
Tamiya America Inc, I ordered some glue
To build the Jeep and they took my money
But have not shipped any thing yet
Old 08-23-2016, 09:39 PM   #72
I've ordered quite a few things. It takes a few days to process their orders. I believe they ship out of California, so depending on where you live it takes a while to get.
Sent from my SM-G900V using Tapatalk
Antfarm34 is offline   Reply With Quote
Old 08-23-2016, 10:18 PM   #73
I'm in Northern Nevada, so it should not take that long to ship
Its probably like Antfarm34 says it take a little while to process
Old 08-24-2016, 01:18 AM   #74
I need to go to Ace Hardware and buy some 3.5mm nuts that are 2mm thick
And some washers the same diameter as the 7mm Wraith links
Cause my 1.9'' Wraith setup with SCX10 axles, right now is 12 7/8'' or so
I looked at other Dragon Jeep builds to see if they show the wheelbase
One guy posted his was 13 5/16, and showed a picture of it, it looked good to me, so 13 5/16'' minus 12 7/8'' that's a 7/16 difference divided by 2 for the front and rear equals 7/32
so I'm thinking one 2 mm nut on each link front and rear
If that's that not enough then maybe a nut on each end of links,
Once I get some nuts and washers, I can adjust the wheel base
I tried the curved rod ends in the picture and they make the wheelbase with AR60 axles and SCX10 axles 14'' long
So with the short rod ends, I'm using now and some nuts and washers
I can adjust the links, to center the axles in wheel wells
Got a plan now and its on
And the Dragon chassis will also work for Jeep Mutt
I posted pictures of it mocked up in my Mutt build
Old 08-24-2016, 05:03 AM   #75
You're better off getting common hardware locally. I have a 35 year old Tamiya Buggy, so I can only get certain parts from them.
Old 08-24-2016, 09:52 AM   #76
The Ace Hardware here, has a whole section of metric hardware and all kinds of stuff, I can only find there
Home Depot has only a small section of 3.5 mm stuff
Ace Hardware has 3.5 mm, 3 mm, 2.5 mm, 4/40/ 2-56
I do buy small amounts at Ace, If I need a large amount of hardware
I will order from McMaster-Carr
Since I only need 16 or so Ace is the place
Old 08-24-2016, 10:12 AM   #77
I'm going to call in a favor and see if Mr Eastwood my old Machine shop college instructor
Will let me use his band saw, if not maybe I go up to college and see if I can bullshit
The new Machine Shop instructor into letting me use the band saw
Too cut out some chassis rails out of the left over 1/8'' steel plate that used for 1/6th scale Humvee chassis
I got enough too make 2 rails, that match the Dragon plastic chassis
Old 08-24-2016, 02:11 PM   #78
I joined the Band!
That is a very good idea. I would also look into making room to mount a crossbar to mount the front roll cage to. This will pay off if you get in a hard roll as I did.
twissted is offline   Reply With Quote
Old 08-24-2016, 02:20 PM   #79
I used a jigsaw that the last time and there was a lot hand filing and grinding
Cause the blade fought the metal and binded up a lot and could not get as close as I wanted
And the Dragon chassis has got curves too it, the band saw can cut curves
So there is a little grinding and filing needed,
Maybe I will cut a set for the Jeep Mutt too, will I got use of the band saw
Old 08-24-2016, 02:52 PM   #80
Yeah Baby
I'm glad I called Mr Eastwood, He is good people and miss helping him work on the machines, we talked a little about the Jeep build, He suggested I go up to college
And use the new CNC Plasma cutter, They got in Welding Shop
And tell instructor that Mr Eastwood sent me
The Instructor or one his students will setup and operate the Plasma cutter and cut out my rails out of the 1/8'' steel plate
The new semester starts this week and got wait until after the 1st of September so the class is going
Before I go up and ask him to help me out
And Mr Eastwood suggested I take the Advanced Welding class, and then be able to access the plasma cutter and welding equipment
Plus they got a lot of fabricating tools, benders, press brake's for sheet metal and thin plate, they got tubing benders and tubing knotcher's
I don't have any thing going except for 1/6th Dragon Jeep chassis and my 1/6th scale Jeep Mutt chassis
To justify taking a spot away from some one that needs the class
Cause the Machine shop got rid of the band saw, the Plasma cutter is the way too go
Just pulled the trigger on a Dragon - Similar Threads
Just pulled the trigger on a CC-01 abailey21 Tamiya XC/CC01 35 10-28-2012 09:43 PM
Pulled the trigger XJkid93 Axial XR10 2 04-19-2012 03:30 AM
pulled the trigger.. 94smasher Axial SCX-10 6 03-17-2012 03:59 PM
pulled the trigger 501 Team Losi Comp Crawler 14 12-27-2010 12:03 PM
Pulled the trigger smokediver Axial AX-10 Scorpion 18 03-07-2010 03:07 AM
