View Poll Results: Would you be interested in this kind of chassis? | |||
Yes | 9 | 45.00% | |
No | 11 | 55.00% | |
Voters: 20. You may not vote on this poll |
01-19-2011, 05:35 AM | #141 |
RCC Addict Join Date: Mar 2010 Location: Colorado Springs, Co
| Increase Leverage
I think I'm going to make a small piece of delrin to attach to the arm and move my servo connection a little further away from center of the axle to help increase the stearing power mechanicaly. A small piece of delrin should hold up just fine in this instance. I was going to trim off the extra piece of the arm but trimming it doesn't get me any more of a stearing adfantage as the arm hits the C at that new location. Hummm.
01-19-2011, 08:30 AM | #142 |
looking good. get some CVD's and you will get more. |
01-19-2011, 08:58 AM | #143 |
01-19-2011, 10:15 AM | #144 |
Oh, I thought they looked like the dogbone and stub. 3racing are different than the losi CVD.
01-19-2011, 10:28 AM | #145 |
The 3racing cvds have a thin metal sleve that retains the pin so it cant slide out. It works really well. The shaft is kinda thin and im afraid that it might not hold up very well. We will have to see though once i get it on the rocks.
01-19-2011, 11:04 AM | #146 |
How much weight are you running in the front and rear?
01-19-2011, 02:39 PM | #147 |
Right now the wheels weight 7.4 oz each - The internal Proline weight Rear wheel 3.2oz each, no weight just rubber and and foam. That's not where it's going to stay, I just need to play with the weight a bit. |
01-19-2011, 03:11 PM | #148 |
I like te Pro-Line wheels, they are easy to mount and the weights are ok. I added another oz. to each front wheel to ge me up to 8.4 and the rear is at 4ish. Just worrying about breaking the CVD. I have a combo of the LCC stubs and the MRC shafts. Oh I got the CCBEC programed. Thanks
01-19-2011, 04:54 PM | #149 |
I was thinking about running only 1 ouce of weight in the front as a starting point then work from there then I'll put the proline weights in all the wheels then add and ounce to the front as a start point.
01-21-2011, 11:23 PM | #150 |
| Starting point for setup
So I'm in the begining stages of setting my rig up for Motorama(hopefuly I can afford the registration). This is my starting point. Chassis - MVP v2 in "RED" Tires & Wheels -------------- G-made wheel widners in the front 7 & 7/8th inches wide with the titus wheels. Proline titus wheels HB Rovers Crawler Inovations soft foams No Additional weight in either the front or rear(3.2oz ea with no aditional weight added). Tipping, Climbing, Articulation ---------------------------------- Virt climb - 55 degrees max with three wheels on the plank 50 degrees with all four wheels planted Decent - 41 degrees before it wants to go end over end 38 degrees with all four wheels planted Side Tip - 41 degrees Virt Tip - 72 degrees Belly Clearance at rest - 2 1/4 in (wheel Base 8 7/16ths) Belly Clearance compressed - 1 in (wheel Base 8 1/2) Front Articulation - 4 1/8th in Rear Articulation - 3 3/4in Weights ------------------------------------ Front end - 1 lb 4oz FLW - 10.4oz --------------------- FRW - 10.6oz Total 2 lbs 4.7oz RLW - 10.2oz ----------------------- RLW - 9.7oz Rear end - 1 lb 1oz Electronics -------------------------------------- Castle Creations Sidewinder 1/18 Castle Crearions BEC 7V HT 645 33t mini tourque master 12 tooth pinion Mechanical --------------------------------------- Ackerman Mod 3Racing CVD 3RACING drive shaft Solid rear axle and lock outs. Aluminum C's and nuckles Shocks --------------------------------------- Losi Aluminum threaded not limmited Blue Springs Front droop Rear Pre-Load -9mm Last edited by Abavuso; 02-27-2011 at 04:39 PM. |
01-25-2011, 04:55 AM | #151 |
I wanna be Dave Join Date: May 2010 Location: The east coast
adam, what width wheel widener are you using? wouldn't happen to be these from ckrc: http://www.ckrccrawlers.com/gmade-22...mm-p-2708.html i'm working on a turning radius issue with my maxstone 16 and your idea of adding a small plate to the knuckles to give true zero ackerman is a good one but in stock form i don't have enough room to do that with the stock tires. i figure if i push them out i'll have the space i need. |
01-25-2011, 05:30 AM | #152 |
Yes those are the widners i used. Make sure you watch that your track width doesnt go over 8in wide. My motowoks wheels made it 8 1/4 in wide but the proline titus wheels makes it 7 7/8th wide. So if you add the widners and its too wide you can change your wheel or trim the widner. For my motoworks wheels ill probly send them to crawlerinovations and have him narrow them for me so they will be legal.
01-25-2011, 06:41 PM | #153 |
| Motorama...
Looks like it's Motorama for the MVP v2 as it's first comp. I hope the snow clears up so I can do some testing before then
01-25-2011, 07:45 PM | #154 |
Glad to hear it, are you running the widners on the front and rear?
01-25-2011, 08:00 PM | #155 |
Front only at the moment i want to test it both ways.
01-28-2011, 11:19 PM | #156 |
Newbie Join Date: Dec 2010 Location: Australia
how are you going with the center skid you had draw up have you had any cut yet?
01-29-2011, 06:10 AM | #157 |
| I found somone to machine it for me, only problem is the crap CAD software that I'm using doesn't convert so that he can read it. So I'm learning some new software now that can convert so I can get the Skid made. Working in 3D is a whole new Ball game for me.
02-27-2011, 04:37 PM | #158 |
| Pictures!!!!
Today I took home a 2nd place finish at our local comp... I'm very happy with how this little truck is preforming. Can't really say theres much that needs chainging on it. Here's some pics... Local Comp Mototama |
03-29-2011, 06:04 PM | #159 |
Newbie Join Date: Feb 2011 Location: Nederland,Colorado
I've been looking for a chassis for my mrc and this one looks great and good price let me know when they are ready to be sold ill buy one off you in a heart beat.
03-29-2011, 06:42 PM | #160 |
Will do, if you head over to my web page you can buy them when they are back in stock... http://abdesigns.biz I should be finished moving and my stock built back up by mid May I would think.
