11-10-2009, 01:47 PM | #61 |
I wanna be Dave Join Date: Apr 2007 Location: clarksburg
And heres the upper link mount shown from the rear. |
11-10-2009, 01:48 PM | #62 |
RCC Addict Join Date: Jun 2008 Location: Monroe, NC
That will be one sweet setup. Cant wait to see it take shape!
11-10-2009, 02:08 PM | #63 |
Thanks man! I hope it turns out like I invision it.. Heres another drawing of the end of the springs where it meets the axle, it will also be the mounting point for the lower link as well. |
11-10-2009, 05:24 PM | #64 |
RCC Addict Join Date: Mar 2007 Location: St. Louis (High Ridge)
looking good. don't expect a lot of spring action in the rear as there is none, don't forget the deuce springs are smaller. like 6 3/8" leaves instead of 13 5/8" leaves like the 5-ton tractor's
11-12-2009, 01:23 PM | #65 |
Small update, I cut all the plates for the spring mounts, and the upper links. |
11-13-2009, 11:00 AM | #66 |
Ok I managed to get the upper link mount and the spring perch made. Now I only have one more upper 3 more lowers and 3 more perches.. Im wanting to run the scale heims from RC4WD but damn their expensive.....Ill have about 70.00 in just the rod ends. for hardware im looking to use 3m stuff but Im worried about them holding up?? Can some of you gus that are using the small hardware chime in and let me know how they hold up .... |
11-13-2009, 11:14 AM | #67 |
Great work on this so far man. Looking forward to seeing more.
11-13-2009, 05:29 PM | #68 |
RCC Addict Join Date: Jul 2006 Location: Johnston SC
i always use 3mm hardware and have never had any failures. looks good
11-16-2009, 03:13 PM | #69 |
Thanks guys, I have work my tail off on these mounts this weekend. Its amazing the amount of time I have in these things.. Their just hot glued on their for now. I have some 3mm hardware on the way ,should be here by wedensday. I think I am getting this brazing down with the brass, but no matter what I do I cant get the steel to braze up?? Whats the trick???? |
11-16-2009, 06:21 PM | #70 | |
Rock Stacker Join Date: May 2007 Location: Vivaa Las Vegas!(Ringgold Ga. is home)
11-16-2009, 06:24 PM | #71 |
Quarry Creeper Join Date: Aug 2009 Location: Syracuse
Thats very cool, why aren't you going to use 3 axels? |
11-16-2009, 07:29 PM | #72 |
Im going to , but the bank is a little short of fundage at the moment. So instead of waiting till I get the xtra money I decided to push on with the build. Besides theirs pleanty to do till I get the 3rd axle.. Like Build the cab build the bed build the links build the steering build the front spring hangers build the fuel tank build the interior build the exhaust build the trans mount build the light system build the bumpers build the winch build the tow hooks build the steering servo mount build box for the electronics build spare tire carrier and Im sure theirs something Im forgetting?????????? |
11-17-2009, 12:44 PM | #73 |
OK Its a small update, but its an update!!! I built the front spring hanger so far............................................... .................................................. .................................................. .................................................. .................................................. ......................................................... .................................................. .................................................. .................................................. ................................................. |
11-17-2009, 02:41 PM | #74 |
I wanna be Dave Join Date: Aug 2008 Location: Austin, TX, USA
Mmmm.....Crown Royal. |
11-17-2009, 08:37 PM | #75 |
Quarry Creeper Join Date: Sep 2008 Location: Detroit
Very nice chassis/suspension work, very realistic.
11-17-2009, 08:47 PM | #76 |
11-17-2009, 09:16 PM | #77 |
SORRCA Committee Member Join Date: Dec 2008 Location: Parkston, SD
Man! Great work on all the brackets! I want to see more please! Subscribed Can't wait to see how this turns out! Crown is my drink of choice.......mmmmmmm! |
11-19-2009, 08:31 PM | #78 |
Well the 3mm hardware showed up and Im totaly bummed out...These bolts are way to large..I want to go with some button head bolts that are 1 or 2 mm if they make any???If anybody has a lead on where to get some in 1 to 2mm X 1/2,1/4 and 3/4 long I would realy appreciate the heads up!!any whoo heres the pics of the nasty lary stuff.. I also started to draw up the cab in 10th scale , but same as the bolts it was a waisted venture.....I think its to big for the tires, so Im going to go with 12th scale. And just incase someone wants to know what it looks like in 10th scale .. Ill post some pics of the finished cab drawings tomorrow from work...Stay tuned and the next post wont be so disapointing.. |
11-19-2009, 08:46 PM | #79 |
I wanna be Dave Join Date: Dec 2006 Location: In Cali.
11-19-2009, 08:57 PM | #80 |
Thanks Tom! What head size would you recommend??
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/multi-axle-rigs/205518-rcjeepbuilders-military-build.html | ||||
Зарубежные проекты 1.9 | This thread | Refback | 10-07-2011 09:43 AM |
