03-01-2013, 10:16 AM | #61 |
Oppan Gangnam Style Join Date: Jun 2005 Location: Shingle Springs
| Re: Hardbody TJ 6x6 Propane Style
Nice, looks better now, I hope to see it in action sometime soon!
03-03-2013, 01:41 AM | #62 |
Rock Crawler Join Date: Dec 2009 Location: Redding
Picked up some styrene for my first time. Easy to work with and light. Here is the bed I put together. |
03-05-2013, 01:46 AM | #63 |
Pulled the GR7 and Split Skid today and put in all the steel RRP gears. Also decided to try some more styrene work. Here are some inner fenders. Also started on a hardtop. I hope I can run a few packs through it this week. |
03-06-2013, 03:24 AM | #64 |
Made some front suspension changes to take care of the steering issues I was having with the CMS. Steering is great now and suspension travel is spot on. Painted the inner bed. Picked up some 2/56x3/8 buttonhead screws for the beadlocks. Looks damn good with the custom MThead beadlocks all painted up. Also tuned the weights and foams in all 6 wheels. I ran it outside for 20min today. All seems to be fitted properly and working well. The 21t rock racer motor is a monster, tons of wheelspeed but lacks the low end I like when running the divorced setup. I think I will try a quality 35t handwound to see if I am happy with the overall speed. |
03-06-2013, 08:08 AM | #65 |
Quarry Creeper Join Date: May 2012 Location: My own personal Heaven
Looks awesome! I'm glad I found this thread, it will help me a lot with the 6x6 build I'm gathering parts for. Great work!
03-07-2013, 11:25 AM | #66 |
Did the driveshaft mod to help with strength. Used a female shaft on both yolks with a male glued in on one side. I use an axial aluminum link cut down to stuff in the center of the male driveshaft so it can't twist or collapse. |
03-08-2013, 07:09 AM | #67 |
Pebble Pounder Join Date: May 2008 Location: australia
Vey unique build Never would have thought that a 6x6 TJ would look any good Must crawl pretty good with its weight low,and being long. |
03-08-2013, 05:58 PM | #68 |
Since this will become my fun to drive rig I just assume I will need tunes. I took apart a portable battery powered IHome speaker system I found and packed it into the dash. It runs on 6v and has a small amp board. I had to build the dash out about a 1/4 inch to fit it all. It has a slide switch on top to turn on and off and an indicator light in the dash. |
03-09-2013, 09:26 AM | #69 | |
Rock Crawler Join Date: Sep 2012 Location: Pasadena
03-09-2013, 10:06 AM | #70 |
Rock Stacker Join Date: Sep 2011 Location: Spring Hill
what material did you use to form the outside shell of the bed?
03-09-2013, 01:09 PM | #71 |
The outside of the bed is made from 2"x12" brass sheets from the hobby shop.
03-09-2013, 01:20 PM | #72 |
| Re: Hardbody TJ 6x6 Propane Style |
03-09-2013, 01:32 PM | #73 |
If you looking for speed and lowend and tons of top end, go brushless! You can pm me about a Tekin Rs, and you can find novak 13.5-18.5's sensored for like $40 on the fs section all the time! Brushless is like a crazy addition! My wraith is running a castle Mamba Max Pro with a tekin 7.5 t scx4x and it hauls butt! And still has way more lowend than any brushed motor! |
03-09-2013, 02:27 PM | #74 |
I built this around a brushed setup because of the G6 running I like to do. I have plenty of crawling low speed resolution on the 35t and it still has more wheelspeed than I need.
03-09-2013, 02:41 PM | #75 |
Decided to build a hard cab using styrene with a hybrid 3/16 brakeline cage inside. It just didn't look right to me topless with a cage. The rear window is a piece of clear lexan that I cut to shape. |
03-10-2013, 06:51 PM | #76 |
Went out for the first trail run out at the gorge. Lasted 10 minutes and had a pinion/spur failure in the GR7. This was the second pinion I toasted. I am using a RRP steel diff gear(spur gear in GR7) and RRP 12 tooth pinions. Gear mesh was perfect both times but something causes an issue when running. Ends up chewing up the pinion and thirsting the teeth. Not sure what to do.
03-10-2013, 07:30 PM | #77 | |
| Re: Hardbody TJ 6x6 Propane Style Quote:
How does it feel with the motor out? Does it spin free or is there some excessive resistance in the driveline? If so, disconnect things one by one till free. Also articulate the axles one by one and see if there is any binding (I had this issue on one of my 6x6 trucks. Also, is your pinion steel or aluminum? Lubed? | |
03-10-2013, 08:07 PM | #78 | |
03-11-2013, 09:50 AM | #79 |
It looks like the GR7 I got was slightly out of spec. This was an issue that came up on some of the first released units. The bearing on the flat plate of the GR7 will fall out and slide due to the seat being slightly too big, it doesn't allow the bearing to wobble around but just free enough that it will fall out if you turn it upside down. My solution was to shim the bearing and remove the play in the output shaft/bearing. It's all back together and seems to be working well. Only time will tell!!!
03-11-2013, 02:47 PM | #80 |
Cool, I hope that fixes it. I'd lube the gears too since they are metal on metal.
Hardbody TJ 6x6 Propane Style - Similar Threads | ||||
Scratch 6x6 trials **UPDATE.. Now MAN-KAT 6x6** | dankycrawler | Multi Axle Rigs | 37 | 04-18-2013 02:09 PM |
TTC Propane Style | Propane | 2.2 Scale Rigs | 17 | 10-16-2012 09:19 AM |
