03-11-2013, 04:24 PM | #81 |
Rock Crawler Join Date: Dec 2009 Location: Redding
03-11-2013, 07:13 PM | #82 |
Pebble Pounder Join Date: Oct 2007 Location: Ohio
| Re: Hardbody TJ 6x6 Propane Style
This 6x6 is looking great really nice job! I hope you fixed your pinion problem!
03-13-2013, 02:15 PM | #83 |
Done!!!!!!!!!! Next to my class 1 jeep and wraith. |
03-13-2013, 03:06 PM | #84 |
RCC Addict Join Date: Mar 2009 Location: Across the street from Folsom Prison
Turned out pretty sweet George. You G6n Saturday? From my phone using my fingers. |
03-13-2013, 05:41 PM | #85 |
03-13-2013, 06:14 PM | #86 |
My son and I took an hour and hit the gorge today for a little test run. Didn't get any other pics but the rig did great. The 1300mah 3s lasted for about 40min under standard G6 style driving using the stereo too. With my 5 batteries I should be able to run just about 3 hours straight. Final weight tips the scale at 11.5 pounds. As for the running gear, no problems there!!!! The 35t Tekin handwound with a 12 tooth pinion in the GR7 was warm but not too hot, plus the last 125 yards to the car was ran full throttle with a fresh battery(wanted to see how hot it would get). Crawling control and resolution was better than expected on the rocks, and the top end speed was faster than I expected too. The Dinky GR7 and split skid are an awesome combo that I recommend if you want the interior space. I climbed lines with little effort that take me a few attempts with either of my other rigs. The real challenge is the overall length. I can make most turns but I find its easy to slip down onto a rock jamming between the front and middle axles, having so much metal work you can hang up pretty easy if not paying attention. However the rear quad steer really helps free the rig when jammed up. I very happy with how it turned out, too bad being such a clean nice rig won't last long. I didn't build it to look at it, I built it to drive it!!!!! Last edited by Propane; 03-13-2013 at 06:43 PM. |
03-13-2013, 09:56 PM | #87 |
Newbie Join Date: Jan 2011 Location: Anderson
Glad you got it to work and sounds like you had a good time out there
03-15-2013, 12:27 AM | #88 |
After a few flops onto the roof I realized how important a cage is going to be. I needed to spread out the 11.5 pounds to more than just the small cab especially when it takes its first tumble. This is what I came up with, simple clean and mounts into the bed which can be removed from the rig for maintenance. |
03-15-2013, 07:39 AM | #89 |
Rock Crawler Join Date: Sep 2012 Location: Pasadena
Nice!
03-17-2013, 11:59 AM | #90 |
Took the rig out to the G6 yesterday and finished the day under a solid pace. Everything worked properly and smooth and I can only see a few small changes that I might make. In glad I opened up the grill to get some airflow under the body and help cool the BRXL and 35t when running for hours on end. The motor was barely warm by the end but the BRXL was toasty. I love driving this thing!!!!!
03-17-2013, 04:55 PM | #91 | |
03-17-2013, 05:45 PM | #92 |
| John said its probably a bad inductor on the internal BEC. I just figure run it till it says it had enough.
03-22-2013, 03:49 PM | #93 |
Had to add some lights. I will run 2 sets. One chassis mounted and one cab mounted so its removable by a JST connector. I used the kit from The Chop Shop (Hoosierdady) and they work great. I like that you can cut them free and wire directly to a power source!!! And the clean wire job. |
03-22-2013, 04:10 PM | #94 |
Quarry Creeper Join Date: Apr 2011 Location: THE SHOP
| Re: Hardbody TJ 6x6 Propane Style It turned out real nice, everything is simple, straight & clean. |
03-22-2013, 04:36 PM | #95 |
I was putting things away and realized that I had also installed the rear heyok winch controller for the 645mg free spool rear winch I am working on. Didnt want to have to rip it all apart again when I get the winch finished up. But damn there are a ton of electronics on this rig! Getting hard to deal with all the wires and keeping them hidden and secure. BRXL Tekin 35T Handwound Hitec 5685MH steering servo Hitec 5685MH steering servo Hitec 5685MH steering servo BEC Pro Traxxas RX Heyok winch controller Heyok winch controller Heyok custom rear quadsteer controller RC4WD winch 10 LEDs(8 under and 2 tail) Ipod stereo All thats left is the 645 winch and the 4 more LEDs for the cab headlights and marker lights. |
03-22-2013, 09:10 PM | #96 |
WNYRCRC Join Date: Nov 2008 Location: Western New York
Wow. Now that is one sweet truck!!!! Great job
03-23-2013, 04:37 PM | #97 |
Rear winch mounted up and wired in!! I was unable to mount it underneath and hidden so bed mount it is. |
03-23-2013, 07:32 PM | #98 |
Propane, how are those reinforced driveshafts doing, i have some hotracing scale drive shafts i'd sell you cheap...
03-24-2013, 04:05 PM | #99 |
The rig took a 20ft+ cliff dive today. Have the top half of the fall on video. That will come soon. What I thought was going to be a total loss was not much more than some bent bumper mounts, bent bedside, one cage joint cracked off and some body cracks. What pisses me off is on the way back to the car under its own power and still wheeling away, I shred another pinion. It was just after a full throttle bump up over a ledge. I need a solution to fix or replace the GR7.
03-24-2013, 04:38 PM | #100 |
The trail finder 2 tranny?
Hardbody TJ 6x6 Propane Style - Similar Threads | ||||
Scratch 6x6 trials **UPDATE.. Now MAN-KAT 6x6** | dankycrawler | Multi Axle Rigs | 37 | 04-18-2013 02:09 PM |
TTC Propane Style | Propane | 2.2 Scale Rigs | 17 | 10-16-2012 09:19 AM |
