09-23-2014, 07:04 AM | #61 |
Fan of wheelspeed Join Date: Jun 2011 Location: Southern IN
| Re: Szczerba's MC6 6x6 Love the cage work and how it slopes towards the rear. It went from a somewhat docile to very aggressive over night it seems. The fender flares and chopped off plastic definately added a low slung look to the profile. My favorite detail...the last pic with the light/rock gaurd over the light.
09-24-2014, 08:22 AM | #62 |
Newbie Join Date: Jan 2011 Location: italy
hello, could you tell me if there is the panhard on the front axle? i dont see it... about the esc and the motor what you think to use regards |
09-24-2014, 08:54 AM | #63 | |
| Re: Szczerba's MC6 6x6 Quote:
No panhard bar, as it is a 3 link setup with true coil springs. There is no side to side axle movement and no noticable bump steer. I'll try the stock 35t motor and will use a Holmes Hobbies BRXL with a Castle BEC pro to power lights and whatnots. | |
09-24-2014, 09:21 AM | #64 | |
Do you think that the trasmission is good for an hard use, like axial trasmission? or also for a soft scaler use? im interested to buy a 8x8 or rc cross | |
09-24-2014, 11:58 AM | #65 |
| Szczerba's MC6 6x6
Not sure on the transmission yet either. Havent ran the truck. I think it would hold up for light scaler use. The axles have been known to break with light use but not all of them. TLT compared widths, only 1/4" wider with same wheels/tires/foams! Since these can be built as pass throughs, they will be a good option for Cross RC replacements. The cross rc wheels have alot of offset so going a narrower offest wheel, The tlts will work fine. Rear Fronts Last edited by Szczerba; 09-24-2014 at 12:09 PM. Reason: hkjb |
09-24-2014, 05:29 PM | #66 |
Quarry Creeper Join Date: Dec 2011 Location: Gold Coast, Australia
How do you think that coil spring set up will actually work out on the trails? Seem consistent?
09-24-2014, 08:32 PM | #67 | |
From my research guys were saying the black and red stock springs were too soft, so I ordered the yellow firm Springs at time of purchase. When I ordered those, I got an email from StellaModels saying the metal shock frame brackets were recommended for those springs, so I got those. I just got through driving it around the shop floor over some Minor tire height obstacles and it worked really well. I am glad I cut and re-boxed back in the backside cab fender areas. Makes for much more clearance once the front tire goes over an obstacle. The front tires tuck and have plenty of cab clearance underneath. The stock axle steering throw was quite surprising as well. I am using a HiTec 7954SH and a 1" AL servo arm. The drag link is at an angle to the steering link but it doesnt seem to hurt the steering. More pics on the steering in a bit. | |
09-24-2014, 08:58 PM | #68 |
Random pictures 614FF, CC BEC Pro, Holmes Hobbies BR-XL, stock 35t motor is smooth and peepy, 3s 2200mah . |
09-24-2014, 09:22 PM | #69 | |
Thanks James. I pulled the rear cage lines and bed from this 1:1 below. The slopeness does make the man cab look alot meaner than just a militray work horse. Those are the lights and light guards that came with the kit. Last edited by Szczerba; 09-24-2014 at 09:23 PM. Reason: oklj | |
09-24-2014, 09:43 PM | #70 |
I think if I was to build a 6x6, one of these kits will be the way to go for sure! It'll be good to see how it goes once its all finished up
09-24-2014, 09:49 PM | #71 | |
With the cool scale factor and quality of 90% of the parts (potential axle shaft support issues) I am not afraid to recommend it to you. It was $643 shipped with what you see in the first post and I think it's really worth it. Only gripes I have are they need to correct the axle shaft support mistake and make a 2.2 1/10 or 1/9 scale version! Don't worry, it will get drove, I don't build static shelf models. Last edited by Szczerba; 09-24-2014 at 09:50 PM. Reason: jkvg | |
09-25-2014, 12:51 AM | #72 | |
Many thanks, very interesting comparison with the tlt , job Quote:
09-25-2014, 08:14 AM | #73 |
| Re: Szczerba's MC6 6x6 Yep, like I said, the Cross RC wheels have quite a bit of offset, so if different wheels were used, you could get narrower with the TLTs, if needed. They'll be fine, even using the Cross RC wheels. Edit Also, the TLT axle housings can be cut/trimmed to fit the Cross RC spring mounts. I am not 100% sure it will work but measuring it out, it looks like it would fit with some axle housing dremeling and a new hole or two. .... Last edited by Szczerba; 09-25-2014 at 08:36 AM. |
09-25-2014, 10:23 AM | #74 |
I wanna be Dave Join Date: Mar 2007 Location: roland,ar
Nice! cant wait to fondle this in person... You may have to make me a rear cage to for mine.. or ill just buy this one in a month or 2.. |
09-25-2014, 11:45 AM | #75 | |
I wanna build a 2.2 version one day. May gin up some funds for the 1/10 RC4WD big daddy MAN. | |
09-25-2014, 08:53 PM | #76 |
| Re: Szczerba's MC6 6x6 |
09-26-2014, 06:26 AM | #77 |
if said Awesome is what i think it is... TSS sneak peak via FB It'll be a MONSTER... |
09-27-2014, 11:55 AM | #78 |
A little bit of awesome here. Not much though. Light mounting and interior chopping. Rearmount panel and light buckets. |
09-27-2014, 12:38 PM | #79 |
Dress up on cab almost done. |
09-27-2014, 02:53 PM | #80 |
Bed Chopped up savox servo box? ...... What color for the bed panels? Black? |
Szczerba's MC6 6x6 - Similar Threads | ||||
Szczerba's 2.2 XTV | Szczerba | 2.2 Scale Rigs | 195 | 09-30-2015 08:37 AM |
Szczerba's 2.2 CXT | Szczerba | Axial Wraith | 109 | 12-04-2013 06:08 PM |
Szczerba's 2.2s Villian | Szczerba | Axial AX-10 Scorpion | 75 | 10-17-2013 05:38 PM |
Szczerba's FF-SZ 2.2s | Szczerba | Axial AX-10 Scorpion | 389 | 06-11-2013 08:30 PM |
Scratch 6x6 trials **UPDATE.. Now MAN-KAT 6x6** | dankycrawler | Multi Axle Rigs | 37 | 04-18-2013 02:09 PM |
