Go Back   RCCrawler Forums > Scale Rigs General Tech > Multi Axle Rigs
Thread: Szczerba's MC6 6x6
Old 10-10-2014, 10:29 PM   #121
Default Re: Szczerba's MC6 6x6
What is the width of those MC6 bodies? I picked up a Tonka firetruck toy the other day I want to make a 6x6 out of but I'm thinking it will be too narrow..
Sp3cia1-K is offline   Reply With Quote
Old 10-10-2014, 10:30 PM   #122
Back on post 112. About 8" wide at the body widest point.
Szczerba is offline   Reply With Quote
Old 10-11-2014, 11:22 PM   #123
Thanks for that! Completely missed the specs on that post, too busy looking at the pretty pictures
Old 10-12-2014, 09:02 PM   #124
Shane, this build is very sick. the way you make it all come together smoothly is just sweet.
how many hours do you have in this build with all the planning and building? 50?
pitcher2103 is offline   Reply With Quote
Old 10-12-2014, 09:13 PM   #125
No worries. Just holler if you need more info or pictures.
Thanks. I try to post as I go, even if no one comments. I feel it's my job to show how the kit goes together and then how I changed it up. It took about a month total of time. I would say more than 50 hours. I know two weekends I spent both days at least 6-8 hours each day building.
Old 10-22-2014, 09:32 PM   #126
Default Szczerba's MC6 6x6
Two issues solved tonight.
Driveshaft and trans
Wraith Uni's, Gmade shaft, hastly welded but it works, for now.
Saw Sam63 do this awhile back and it gave me the idea for this shorty steep angle driveshaft need.
Second issue. The trans main shaft has no way of controlling back and forth movement in the trans. This caused a cross pin to strip out a plastic engagment area up towards the front of the planetary box. So, washer on backside of shaft snugged up against the driveshaft will keep it from stripping. I forgot to take pics of the stripped part but I was able to fix it with new grooves.
Old 10-27-2014, 08:30 PM   #127
Stripped a plastic pin engagement area in the transmission just easing around at the Recon G6 this weekend. Guess Ill have to fit an ax10 trans in somewhere, sometime.
Did manage to snap a picture with Shaun Rice's 6x6.
Old 10-28-2014, 10:00 AM   #128
I found just the cab on ebay the other day, if anyone was wondering.
1 12 Scale RC Cross Military Off Road Crawler 6x6 8x8 Truck Unpainted Body Kit | eBay
Old 11-05-2014, 06:06 PM   #129
Surgery to figure out trans stripping issue.
$0.00005 piece of plastic f's up the whole trans. No replacement part either.
Its on the left end of the through shaft inside the bearing.
It's a press fit POS style of planetary drive thing. See last pic.
Old 11-05-2014, 06:26 PM   #130
R2 from RC4WD seems like it will work. I'll need to figure out a mount for it but I believe I can handle that.
Old 11-05-2014, 08:22 PM   #131
This. Will burn in mount to steel chassis supports that fit inside the C-Channel frame.
Old 11-06-2014, 10:48 AM   #132
Look I know I'm a noob on this forum, but shouldn't this be in the 1:1 section? I'm gonna need like a banana or something to prove this is 1:12.
Derek Larsen is offline   Reply With Quote
Old 11-06-2014, 12:19 PM   #133
Thanks, if it weren't for the dern 3mm button head hardware, I would be with you on that.
Old 11-06-2014, 07:57 PM   #134
Success
. Name:  ImageUploadedByTapatalk1415328915.223633.jpg
Better driveline angles now.
Celebration time.
Old 11-06-2014, 08:08 PM   #135
Tire&Foam Extraordinaire
Nova's Ark's Avatar
Nice work. The R2 will hold up. Those are great basic transmissions.
..Uploaded from the lab @ the C.I. Compound...
Nova's Ark is offline   Reply With Quote
Old 11-06-2014, 08:12 PM   #136
Shot it full of lithium grease. It's almost the same ratio setup as the stock MC6 trans was. No gearing changes needed, even using the included R2 pinion. Now, wait for the axles to blow up so TLTs can be swapped out.
Old 11-07-2014, 12:04 AM   #137
More vids plz!
BoyFreakWonder is offline   Reply With Quote
Old 11-08-2014, 02:00 PM   #138
hello, very good job,
you do not think that a two-speed gearbox could be an optimal solution, such as the Vaterra Twin Hammers gear box?
soloomega is offline   Reply With Quote
Old 11-09-2014, 07:21 PM   #139
Originally Posted by BoyFreakWonder View Post
More vids plz!
see below
The R2 trans ending up being really really close to the same ratio as the stock transmission. I could do a two speed trans but I wanted to go with something bullet proof right now so I could actually drive it. I can easily have a new motor pinion swapped out in 15 minutes to gear up the truck.
A bunch if iPhone videos mashed together.
Wife was driving in the wooded/leafy sections at the first part of the video.
1080p it, no music.
Old 11-11-2014, 08:59 AM   #140
That rig looks like a blast to drive! thanks for the video.
rcjeepbuilder is offline   Reply With Quote
Szczerba's MC6 6x6 - Similar Threads
Szczerba's 2.2 XTV Szczerba 2.2 Scale Rigs 195 09-30-2015 08:37 AM
Szczerba's 2.2 CXT Szczerba Axial Wraith 109 12-04-2013 06:08 PM
Szczerba's 2.2s Villian Szczerba Axial AX-10 Scorpion 75 10-17-2013 05:38 PM
Szczerba's FF-SZ 2.2s Szczerba Axial AX-10 Scorpion 389 06-11-2013 08:30 PM
Scratch 6x6 trials **UPDATE.. Now MAN-KAT 6x6** dankycrawler Multi Axle Rigs 37 04-18-2013 02:09 PM
