01-26-2016, 03:03 PM | #1 |
Quarry Creeper Join Date: Dec 2015 Location: Sutter
| Shift servo setup.
I am building a trailfinder 2 which has the 2 speed Transmission. Anybody have a tutorial on how to setup the shift servo. I've never done anything like this. Using a airtronics mt4s for reference. Sent from my SM-T320 using Tapatalk |
01-26-2016, 04:08 PM | #2 |
Newbie Join Date: Nov 2015 Location: Nazareth
| Re: Shift servo setup.
I'm not familiar with that particular radio, but I have the Futaba 4PLS. If you're using a toggle (on/off) switch or button on the radio, its pretty simple. What I would do is power your servo up so it centers itself. I'd use this for 1st gear. Position your shift linkage to where it should be for gear one, and put the horn on your servo. Then, set the end point on your radio to its lowest setting. Power the servo up again and raise your end point until it moves your shift linkage into 2nd gear. Typically, I'd adjust the end point high enough until the servo starts to buzz or movement stops on your linkage. Then back the end point off a few points so you don't stress the servo. You may need to slowly turn the wheels to get it to engage completely until it breaks in. This is the exact process I used to setup the Dig unit in my Wraith, it only moves about a half an inch between the 3 options. Here is a video I found with a quick YouTube search.. https://www.youtube.com/watch?v=U745x3YB5RA Last edited by CraigH; 01-26-2016 at 04:13 PM. |
01-31-2016, 05:09 PM | #3 |
I'm struggling with this a bit. Do you start out with both high and low epa at 0 then only move one higher? Sent from my iPhone using Tapatalk |
01-31-2016, 07:26 PM | #4 |
I wanna be Dave Join Date: Apr 2014 Location: North Carolina
| Re: Shift servo setup. |
Shift servo setup. - Similar Threads | ||||
Twin Hammers Shift Servo Setup Instructions from Horizon | badger | Vaterra Twin Hammers | 28 | 11-27-2016 09:44 AM |
Shift servo? | Minirider82 | Vaterra Ascender | 9 | 02-21-2015 11:44 AM |
Trying to set up a Shift servo. Might have a bad servo? | m1009cucv | Electronics | 2 | 02-11-2015 07:12 AM |
Trying to setup rc4wd 2speed in jk shift servo gets hot | mtgrizzlymn | Axial SCX-10 | 6 | 09-16-2014 07:07 AM |
Help Setup Gear Shift Servo Please!! | alexchen86 | RC4WD Trail Finder 2 | 4 | 07-20-2012 11:30 PM |
