08-18-2017, 06:59 AM | #41 |
Quarry Creeper Join Date: Oct 2012 Location: Oregon
| Re: $200 (all in) budget crawler options?
Hmm, just saw a picture for a "RGT RR-4" which appears to use the Everest 10 style driveline parts in an Axial bomber style truck. RGT Racing RR-4 Electric Rc Car 4wd Off Road 1/10 Scale RC Rock Crawler_US Stock | eBay Edit: Best of all, there are NO videos of it on ebay, found some info on it on these very forums though. Rgt rr-4 Edit2: Nope one video is on ebay under rgt rock hammer. Last edited by clm; 08-18-2017 at 07:23 AM. |
08-18-2017, 07:04 AM | #42 | |
| Re: $200 (all in) budget crawler options? Quote:
The Everest 10 or any of the AX10 clones is probably the way to go. | |
08-18-2017, 07:54 AM | #43 |
Moderator Join Date: Aug 2017 Location: Readsboro, VT
| Re: $200 (all in) budget crawler options? Yeah, I think the TH clone has fallen out of favor for a couple reasons. It's a hair on the small side, and the cheap electronics are a turn off. I think the Everest will give a better long term upgrade path too. Right now I'm liking the Everest or maybe the Gen7, except now they're saying Early October for the Gen7. It keeps moving back.
08-18-2017, 08:08 AM | #44 |
| Re: $200 (all in) budget crawler options? Looks much closer to the Bomber stock, but still has all the same driveline components as the E10 and that forum link above says it is faster stock. |
08-18-2017, 08:17 AM | #45 |
It looks like a good possibility. Being faster will save me on a motor buy, and the better tires might save me on that front too. I also like the longer frame with the more vertical shocks. This should help with torque twist and will let me use more scale bodies. On the negative side, the axle wideners and slightly different axle components make me wonder if it's worth the extra money over the Everest. The best price I can find on Ebay is $65 above the Everest. It's a definite possibility.
08-18-2017, 08:57 AM | #46 |
The housings are the same which means internals should still be more or less Axial compatible, and any internals that the E10 might need upgraded will likely need upgraded here as well.. and I can only find one video about it on youtube so you might be able to get more views being the first one into it. It will likely need the same mods to increase steering as all the other versions. My only real dislikes about the E10 are the crawler specific chassis and the smallish body. This swaps them out with a more scalish chassis and apparently a body that hinges up, and then tosses in some tires that look a bit more scale. Any weak c hub issue could be rectified with cheap off brand scx10 aluminum hubs. Yeah, as for the price, it barely fits into your $200 price limit. But then again I don't value the main chassis of the E10 very highly as it is an older design and likely one of the first things that get replaced when modding an E10 Last edited by clm; 08-18-2017 at 09:04 AM. |
08-18-2017, 09:12 AM | #47 |
It barely fits into the price range, but it's already got a lot of the upgrades I wanted to do to the Redcat, so it might be a better option. In the long run it'll likely save me money.
08-18-2017, 11:42 AM | #48 |
The rock hammer looks like a nice rig and ya the worst part about the e10 is the chassie no adjustments at all and the suspention geomitry just sucks the exceed might be better i dont know my exceeds are different scales 1 1/5 and 1 1/18 It looks like the hsp has the best cbassie plates but there realy easy to make also i found a cc01 landfreeder fot a hair over 160 its more a scale truck and wont keep up with a bomber unless your a awsome driver lol but still a opion eBay Tamiya 1:10 CC-01 LandFreeder w/ESC EP 4WD RC Car Kit Off Road Truck #58579 | eBay |
08-19-2017, 10:10 AM | #49 |
Hmm, I would think the cc-01 being even less capable crawling then the Barrage and clones. Best bet if you really wanted to go cc-01 length now days is a MST chassis that is cc-01 length to put the Tamiya body on.
08-19-2017, 02:41 PM | #50 |
If i remeber the berrage and the mst use 1/18 scale axles i have a mrc based scaler and a ta02 almost the same as a cc01 only 4 wheel independent syspention insted of a solid rear axle and a much lower slung chassie and my tao2 is just as capable as the as my mrc clone scaller so i would think the cco1 would be even better than my ta02 and from the vids ive seen they can be made to ke3p up with the scx10 but a bomber no way but alot cheaper alot of parts suport and are relitivly scale and wont need a bunch of upgrades to get started but ya the tamiya bodys will fit the mrc based clones realy good and also the tanka trucks are about that size aswell i have a tanka van project thats gona run the 1/18 mrc axles as soon as i find a killer deal on a set
08-19-2017, 02:56 PM | #51 |
Not sure about the axles as I have never handled one, but the MST kits use full sized 1/10 scale electronics unlike the Mini Crawler based ones. All but the CMX-W are more of a true 1/10 scale instead of the fudged closer to 1/9-1/8 scale of most of the other kits. Things seem to be given their listed scale based on chassis parts then body measurements, which is fine but makes true scale models seem small... kinda like the Twin Hammers in that pic up there.
08-19-2017, 04:11 PM | #52 |
Pebble Pounder Join Date: May 2017 Location: Covington
I think it would be a good idea for you to consider something used like on ebay or a crawler forum classifieds section. I got a nice used Losi mini crawler that way.
08-20-2017, 08:26 PM | #53 |
Rock Crawler Join Date: Jan 2017 Location: DownUnner
Why not just buy a RTR second hand RR10 or SCX10.1? They are cheap and reliable. Add affordable brushed electronics and you've got a great rig. The Bomber needs nothing at first and the SCX10.1 just a set of cheap homemade lower links which should keep you going for a while (until the plastic gearbox gears strip). |
08-20-2017, 09:22 PM | #54 | |
08-21-2017, 02:29 PM | #55 |
Pebble Pounder Join Date: May 2014 Location: SF
i dont know if this has been said yet...i didnt want to read 3 pages of stuff. buy a star or get 30 posts and get access to the for sale/want ads. spend your 200 or 180, and pick up a nice starter rig. you will have to replace a lot down the road depending how much you drive on a knock off rig. you can put one together pretty cheap that is capable of doing a lot of stuff. thats just my 2 cents. |
08-23-2017, 10:42 PM | #56 |
Newbie Join Date: Aug 2017 Location: Tampa
I scored a losi night crawler of eBay for 100 bucks. I had a hobywing esc laying around but there 65. Then I nabbed a novak 13.5t sensored brushless for 30 and the thing is a beast. Cheap tough, but not like your bomber. Just an idea the losi rig is cheap second hand and very capable with a better motor. IMO but I'm new to this so just an idea
08-24-2017, 02:16 AM | #57 |
I like the design of the Losi crawlers, but they are not so suited for scale trucks and scalers have gotten my attention recently... |
09-06-2017, 08:06 AM | #58 |
Hey guys, I just realized that I never updated this thread. I ended up ordering a Redcat Gen7 Sport. It came in right at $200, so by the time I do a couple upgrades it'll be a bit over my original budget, but it pretty much checked all the right boxes for me. It was cheap, it's new, and all the buzz surrounding it will lend itself well to my plans for my youtube channel. I'm looking forward to getting it and my Bomber out on the trail to do some comparisons, and starting an upgrade series on the Gen7 for my channel. It should be a fun ride. |
09-06-2017, 09:33 AM | #59 | |
Quarry Creeper Join Date: Sep 2013 Location: Hicktown
BUT, it would be a great video to do for "what to do when buying a used RC Crawler" or something along those lines. What to look for while browsing ebay, what to do when you get the truck and/if it is in worse shape than the seller stated. Where to start with Maintenance. Stuff like that. I would agree about a used scx10 though. With the new SCX10 II out now people are unloading their gen 1 stuff for pretty cheap. | |
09-06-2017, 11:15 AM | #60 | |
Newbie Join Date: Feb 2013 Location: High Point
I was originally going to say "go for the $145 Redcat Everest 10!" but the GEN7 while pushing your budget, was an excellent choice in my opinion. If I can get my Savage Flux HP sold off, I'll probably purchase one of the regular E10's for my son. | |
$200 (all in) budget crawler options? - Similar Threads | ||||
What upgrades would you buy with a $200 budget for a stock yeti? | monstersobe | Axial Yeti | 8 | 11-12-2014 10:13 AM |
need advice, setup on budget 200$ | nitrooxide | Axial AX-10 Scorpion | 20 | 05-20-2012 12:58 AM |
lwarc's budget fj instascaler($200) | lwarc | Tamiya XC/CC01 | 50 | 11-04-2009 05:04 PM |
