Go Back   RCCrawler Forums > RCCrawler General Tech > Paint and Body
Thread: Help with backing paint
Old 10-01-2018, 09:54 AM   #1
Default Help with backing paint
I painted a body this weekend with createx airbrush paint. The main color is a dark brown with a tan stripe. I like the tan color but want to back it to block light. Help me RCC you’re my only hope.
touch racing is offline   Reply With Quote
Old 10-01-2018, 01:14 PM   #2
Default Re: Help with backing paint
White silver or black depending on how you want it to end up.
Take a scrap and see what you like. I like silver then black over it so you cant see it.
Not sure if this is what you are asking.
Ditchrat is offline   Reply With Quote
Old 10-01-2018, 02:03 PM   #3
Moderator
Unless that paint brand has a line designed to adhere to lexan bodies, no matter what backing paint you use, it's going to all flake off the first time you use the truck.
Jim85IROC is offline   Reply With Quote
Old 10-01-2018, 02:04 PM   #4
Yes mostly asking about color. In the past silver has been my go to backer color with PS paints. This is the first time I've used createx paint. Just looking to see what others have used.
Old 10-01-2018, 02:14 PM   #5
Createx paint is some of the best paints you can use in your airbursh for lexan. Your going to be fine.
It is also an acrylic, so treat it exactly the same as you would the PS line. They are completely compatible, go with what you know and the results should be very similar.
Old 10-01-2018, 04:20 PM   #6
Man, those colors are exactly what I've been looking for, for a '78 K10... I just wish I could find them (or, close enough) in rattle cans!
As for backing, I would do a couple coats of silver. Think of it like mixing the paints, white will keep it bright/make it lighter, black will make it darker, and silver will be somewhere in between (leaning towards the lighter side.) After a few backing coats, you can lay down any color you want, and it won't make any appreciable difference to the visible color.
TheLetterJ is offline   Reply With Quote
Old 10-01-2018, 05:33 PM   #7
My parents had a brown and tan 86 K5 so when I picked this up I had to duplicate the paint colors. That’s what led me to createx. I mix black and red to get the brown. White and yellow for the tan.
Help with backing paint - Similar Threads
Backing for Paint Truckmechanic304 Paint and Body 10 03-11-2016 12:52 PM
Question about backing metallic paint Smonkman Paint and Body 6 03-25-2015 09:49 AM
using regular paint as a backing? ? ccampbell94 Paint and Body 4 08-18-2014 05:48 PM
Backing Paint? alexchen86 Paint and Body 0 11-15-2011 06:47 AM
backing paint usa1man Paint and Body 15 03-01-2007 09:45 AM
