10-25-2012, 07:13 PM | #21 |
Pebble Pounder Join Date: Jan 2011 Location: Bramwell
| Re: cbp27's DRX Build
new tires look good! let us know how they do.
11-06-2012, 12:22 PM | #22 | |
RCC Addict Join Date: Nov 2008 Location: Frederick
| Re: cbp27's DRX Build Quote:
11-06-2012, 12:48 PM | #23 |
Quarry Creeper Join Date: Mar 2008 Location: Pittsburgh
I've run a few packs through my car with the Proline Road Rage tires, and they seem to get much better wear than the stock tires. However, they have much more grip, in fact, they don't want to break loose even with a 3s battery.
11-06-2012, 05:23 PM | #24 | |
Rock Crawler Join Date: Jun 2010 Location: Colorado Springs
11-06-2012, 05:26 PM | #25 |
RCC Addict Join Date: Oct 2008 Location: PA
Bringing it on Saturday?
11-06-2012, 05:40 PM | #26 |
| Re: cbp27's DRX Build |
11-07-2012, 05:43 AM | #27 | |
Are these the wheels you used? ::HPI RACING:: I found these http://www.rcplanet.com/ProductDetai...ctCode=HPI4475 by HPI. I wounder if they will wear better. | |
11-07-2012, 07:37 AM | #28 | |
I'm using Proline Road Rage tires. I haven't tested them much, but so far I have traction rolled the car yet. The HPI tire looks to be too short, at only 76mm tall (stock is 93mm tall). | |
11-07-2012, 08:57 AM | #29 |
| Re: cbp27's DRX Build What the flub? I keep calling crap the wrong stuff! I'll probably pick the Road Rage's and The HPI WR8 wheels. That should look good With the WR8, DRX, etc hopefully they will start making more wheels in diff styles. Some thing like the OZ LEGGENDA would be killer. Oz Racing - OZ Racing - RACING - LEGGENDA |
11-07-2012, 11:12 AM | #30 | |
11-07-2012, 11:13 AM | #31 | |
Gettin’ back on the horse Join Date: Feb 2006 Location: Hoonsville
11-07-2012, 11:48 AM | #32 |
Pebble Pounder Join Date: Jul 2009 Location: Suomi Finland PERKELE !
So basically HPI Super RS4 rims are only option if someone wants to use other than stock wheels ? Kyosho opts 1:8 byggy wheels but they look hideous. Proline Dirt hawgs look like they could take some multi-surface abuse. |
11-07-2012, 11:52 AM | #33 | |
11-07-2012, 12:30 PM | #34 | |
2.2 Ken Block tire: Gymkhana Tire D Comp (2.2"/57x80mm/2pcs) - 109747 at HPI Europe 2.2 Rally wheel: Wr8 Tarmac Wheel White (2.2"/57x35mm/2pcs) - 108075 at HPI Europe | |
11-07-2012, 02:54 PM | #35 |
Pebble Pounder Join Date: May 2011 Location: Port st. lucie
That's good to see. I have hope now that Hpi will release the DC wheels in 2.2.
11-07-2012, 03:46 PM | #36 |
11-07-2012, 05:24 PM | #37 |
The Kyosho Stock wheel is 63mm x 35mm. Hpi 2.2 is 57mm x 35mm. Kyosho stock tire is 93mm x 35mm. Hpi is 80mm x 35mm. I want 2.2 DC wheels. |
11-07-2012, 06:24 PM | #38 |
Quarry Creeper Join Date: Jun 2010 Location: Canberra, Australia
Looks like they are 1.9's for the off road tires - with a taller sidewall. And 2.2's for their 'on road' tires which have a smaller sidewall. Similar overall height, whcih is much smaller than the DRX.
11-07-2012, 10:49 PM | #39 | |
I've had my DRX traction roll on the stock tires with 3S. Just depends how hard you are on it (mainly doing tight donuts). Yes, I used the HPI 2.2 Mesh wheels (from the old Super Nitro), but any 2.2 wheel should work with the Pro-Line Road Rage or Dirt Hawg tires, including the DRX stock wheels. HPI's M compound is for medium and is good for high traction surfaces both on and off road. I had a smaller version of those knobby tires on my HPI RS4 Rally (not sure which compound) and the knobs don't last very long on the road. We should make a Wheel & Tire sticky for our rally section. | |
11-08-2012, 05:16 AM | #40 | |
cbp27's DRX Build - Similar Threads | ||||
cbp27's Defender 90 Build | cbp27 | 1.5 Scale Rigs | 293 | 02-02-2014 04:03 PM |
kyosho updating the drx | foproy | Rally | 31 | 11-29-2012 09:38 PM |
cbp27's Class 3 JK Build | cbp27 | 2.2 Scale Rigs | 132 | 11-15-2012 12:06 PM |
Micky's DRX VE | mickyteng | Rally | 5 | 11-13-2012 04:11 PM |
drx out of the box | coolair | Rally | 9 | 08-12-2012 12:26 PM |
