11-08-2012, 07:13 AM | #41 | |
Quarry Creeper Join Date: Mar 2008 Location: Pittsburgh
| Re: cbp27's DRX Build Quote:
11-08-2012, 09:06 AM | #42 | ||
Rock Crawler Join Date: Jun 2010 Location: Colorado Springs
kyosho updating the drx Also, Infernosonly.com has the Dirt Hawgs in the DRX tires section. PRO107100 Pro-Line Dirt Hawg I 2.2” All-Terrain Tire | ||
11-08-2012, 09:33 AM | #43 |
RCC Addict Join Date: Nov 2008 Location: Frederick
| Re: cbp27's DRX Build That's nice to know, they sound like way to much of a PIA. Thanks for the heads up. |
11-08-2012, 09:41 AM | #44 |
Pebble Pounder Join Date: May 2011 Location: Port st. lucie
In this video the dirt hawgs are being used. They are great improvement in handling on loose dirt. However, if you watch Between 1:13-1:18 of the video. You can see the wheel well making contact with the tire's sidewall. To effectivly allow the full travel of the suspension. The wheel well should be trimmed. Not much though, less than 4mm. |
11-08-2012, 10:00 AM | #45 | |
I think the Dirt Hawgs would rub the side guards and/or dust cover body. I've had my stock tires rub, so I'm sure the wider tires would be even worse. | |
11-08-2012, 10:07 AM | #46 |
No, I do not have the side guards. Yes, The DBX body is what I use for underbody. The nitro version $23.99. Not the DBX VE $39.99. Last edited by buzzbuzzard; 11-08-2012 at 10:09 AM. |
11-08-2012, 10:17 AM | #47 |
| Re: cbp27's DRX Build |
11-08-2012, 10:41 AM | #48 |
| Re: cbp27's DRX Build Szczerba's DRX VE Demon Rally Page 2 post#25 I like the idea of the side guards as nerf bars. Not to spread out electronic layout. I like my layouts as close to center as possible. Last edited by buzzbuzzard; 11-08-2012 at 10:51 AM. |
11-08-2012, 11:28 PM | #49 | |||
I like that idea too. They should definitely help save the body. I added extra foam to my front bumper so it touches the body. And now for some reason I find myself having more head-on collisions lol That tear was from today. I gave the Road Rage tires a good test today of about 3 5000mah 3S lipos. Outside temps were around 45* and it was windy. These tires are very grippy on asphalt (my main running surface). They almost seem too grippy at some times. I had a handful of traction rolls in cleaner areas, but it landed on all 4 wheels every time. I even had some 2-wheeled driving and inside tire lifting on tight turns. This thing is a blast! Snapped these shots at the end of the runs. Curb rash | |||
11-08-2012, 11:57 PM | #50 |
I managed to take two short videos. Nothing special though. Last edited by cbp27; 11-09-2012 at 12:08 AM. |
11-09-2012, 07:30 AM | #51 |
I'm finding that the car understeers quite a bit on tarmac, and with the high grip tires, you can't break the rear end free to make sharp turns. I bet some stiffer shock springs or thicker oil would help with the understeer. Are you going to do any tuning on your diff and shocks to set it up a little better for tarmac? I was thinking about putting a narrow strip of electric tape on my Road Rage tires to allow them to break free a little bit. |
11-09-2012, 07:41 AM | #52 |
RCC Addict Join Date: Oct 2008 Location: PA
Looks like you had fun yesterday. Ever swap your motor polarity to solve the double tap forward single tap reverse issue?
11-09-2012, 09:09 AM | #53 |
There is a dude @ RCtech.net in Scale stage rally. That has a second front bumper for the rear. Plus has added foam to side guards. Looks like he shored up his body pretty good. I just don't like all the added mass. Looks good but not for me.
11-09-2012, 09:27 AM | #54 | ||
I have added 5000k oil in all three diffs along with the extra spider gears, but that's what I started driving with. I might just leave it that way since it's just a basher right now. Quote:
The foam bumper in the rear sounds a little silly but with the price of these bodies, any protection helps. That's why added the extra foam to the front. I may add some to the side guards as well. | ||
11-09-2012, 09:41 AM | #55 |
| Re: cbp27's DRX Build Exactly |
11-09-2012, 10:04 AM | #56 |
11-09-2012, 10:34 AM | #57 | |
Side impact protection isn't a bad idea. Last edited by Stburr91; 11-09-2012 at 10:36 AM. | |
11-15-2012, 12:14 PM | #58 | |
Haha yeah a little foam will help. | |
01-23-2013, 01:43 AM | #59 |
Finally have some snow on the ground so I'm getting the DRX prepped for winter driving. The Pro-Line tires are for on-road only and my original Kyosho tires are bald. Ordered a new set of wheels, tires, and an MP9 underbody to keep out the snow. I'll probably coat the electronics in some Plasti-Dip as a backup. I just hope with these cold temps the body doesn't shatter on impact lol
01-23-2013, 07:44 AM | #60 | |
cbp27's DRX Build - Similar Threads | ||||
cbp27's Defender 90 Build | cbp27 | 1.5 Scale Rigs | 293 | 02-02-2014 04:03 PM |
kyosho updating the drx | foproy | Rally | 31 | 11-29-2012 09:38 PM |
cbp27's Class 3 JK Build | cbp27 | 2.2 Scale Rigs | 132 | 11-15-2012 12:06 PM |
Micky's DRX VE | mickyteng | Rally | 5 | 11-13-2012 04:11 PM |
drx out of the box | coolair | Rally | 9 | 08-12-2012 12:26 PM |
