01-23-2013, 11:19 AM | #61 | |
Rock Crawler Join Date: Jun 2010 Location: Colorado Springs
| Re: cbp27's DRX Build Quote:
I was going to coat that tiny heat-shrink wrapped electronic board next to the ESC first. I'll take a closer look at the ESC and maybe I'll crack it open to coat with Plasti-Dip. It doesn't seem like any other DRX owners are running right now though. Just too cold? | |
01-23-2013, 11:56 AM | #62 |
Gettin’ back on the horse Join Date: Feb 2006 Location: Hoonsville
I ran mine the other day in the mud and before that I ran it in hard pack and slushy snow. The underbody and side guards keep everything out, so unless you are running in deep puddles there is no reason to waterproof the electronics. |
01-24-2013, 09:27 PM | #63 | |
We got another light dusting of snow and I couldn't wait for the underbody to arrive any longer... Daylight was quickly fading After about 1 5000mah 3S lipo... It still works! | |
01-24-2013, 10:24 PM | #64 |
| Re: cbp27's DRX Build Yeah Mamba Max Pro, not sure if it has any water resistance, every time I dunk them in water they stop working. If it means anything it is still the original MM pro that I put in the car a year ago. I am also using a 6 channel 4pl receiver that has zero resistance to water, the second it sees water it glitches, but with the underbody and side guards I have not had any issues. |
01-25-2013, 03:45 AM | #65 |
Newbie Join Date: Aug 2012 Location: at home
Good idea to cool the motor with snow How did you get the snow out after run? Does your ESC make a terrible noise, too? Or is mine just damaged? |
01-25-2013, 10:30 AM | #66 | ||
Terrible noise from the ESC? Like beeping? The fan on top of it makes some funny noises when starting up. Its wires get stuck underneath so I have to move them around to free the blades. | ||
01-25-2013, 10:37 AM | #67 |
Pebble Pounder Join Date: Aug 2009 Location: Fullerton
thats awesome clay, i still kick myself for letting my rally car go.
01-26-2013, 02:55 AM | #68 |
| Re: cbp27's DRX Build First time i switched it on, the fan started and went to something like max power and made a terrible noise so I just switched it off But there are no wires in it, it can spin freely. But maybe it's just me, who didnt hear such a loud fan, yet. |
01-26-2013, 03:37 AM | #69 |
01-30-2013, 07:50 PM | #70 | |
Thanks Marc. What rally car did you have? New parts came in today. Amain had good prices, but only gold wheels in stock, so they were given a quick spray with black Kyrlon Fusion. Foams were taken from the stock wheels and a JConcepts body was fitted. I made two aluminum tabs to help support the inner body. Just need to figure out how to push the rear corners of it inward to clear the tires and add some Velcro®. | |
02-05-2013, 07:33 PM | #71 |
| Re: cbp27's DRX Build |
02-05-2013, 09:22 PM | #72 |
Why?!
02-05-2013, 10:08 PM | #73 |
| Re: cbp27's DRX Build lol Don't worry, I still love this car. It's getting kind of lonely being the only one around with one so I'm thinking of trying something else. My r/c budget only allows for 2 rigs at a time, so I have to sell one to buy one. Once I get a real job (college student) I'll be able to pick one up again. |
03-19-2013, 12:08 AM | #74 |
I thought I would try the Exo Terra but realized the DRX was too much fun to pass up. Gave it some nice upgrades. Pro-Line Powerstrokes (rears) are in all 4 corners, fresh Kyosho wheels/tires mounted, inner body is fitted, and a Mamba Max Pro SCT 2400kv combo for power. Also picked up a MadDogRC Double 4" light bar and fitted it into an Exo light bar guard. Tonight was the perfect time for a test run with a snow storm. The light bar is awesome and MMP setup feels a lot smoother than the Orion system. The underbody kept out most of the snow. I'll post some closeups of the light bar setup once it dries off. A good evening of testing... |
03-19-2013, 12:17 AM | #75 |
Awesome! The Exo would have a hard time looking as good as the DRX in the snow. Light snow on tarmac is my favorite thing to drive my DRX on. Looks like it kept you busy for a while. |
03-22-2013, 08:29 AM | #76 | |
Here's a good shot with the new light bar from yesterday. It's not exactly the right scale, but it's mainly for functionality. | |
03-22-2013, 08:50 AM | #77 |
Looks like it will do the job! Next time you do a snow or mud run try soaking everything in wb-40 before you start should help keep the snow from sticking to everything.
03-25-2013, 06:47 PM | #78 | |
Decided to finally throw on an exhaust tip. Just some aluminum tubing attached to an aluminum tab all Gooped to the body. | |
06-27-2013, 07:51 PM | #79 |
The DRX is still alive and well. I can't believe how much abuse this thing can take. I've flipped, rolled, smashed, and bashed it so much and the the only damaged part is a dog bone, other than the body and tires. Replacement is on the right. Definitely thicker. This car has a lot of grip on the tarmac, which causes a lot of rollovers, so I got the swaybar kits for front and rear. And this is in the works for when the Fiesta body is retired. |
06-27-2013, 09:21 PM | #80 |
cbp27's DRX Build - Similar Threads | ||||
cbp27's Defender 90 Build | cbp27 | 1.5 Scale Rigs | 293 | 02-02-2014 04:03 PM |
kyosho updating the drx | foproy | Rally | 31 | 11-29-2012 09:38 PM |
cbp27's Class 3 JK Build | cbp27 | 2.2 Scale Rigs | 132 | 11-15-2012 12:06 PM |
Micky's DRX VE | mickyteng | Rally | 5 | 11-13-2012 04:11 PM |
drx out of the box | coolair | Rally | 9 | 08-12-2012 12:26 PM |
