01-28-2017, 08:05 AM | #21 |
| Re: Look at what I just bought
Very nice find, I love the TA chassis. I've got quite a few builds on it, everything from crawlers to drifters to trophy trucks. Add bearings, keep the power reasonable and it'll last a long time.
01-29-2017, 01:31 PM | #22 |
I wanna be Dave Join Date: Mar 2013 Location: Minden
Check out this Bling Bling There all Alloy and some are beadlock I like the purple ones and the BBS style ones And the silver and black ones and the 5th ones are old school racer I'm thinking the 3rd or 4th ones would look bad ass With the Sand Scorcher Body Last edited by kgb424; 12-11-2018 at 01:10 AM. |
01-29-2017, 09:55 PM | #23 |
Pebble Pounder Join Date: Aug 2011 Location: gaylord
Quick question on the mini tropy, does the interior piece mount to the cage or somewhere else? I have one of them cages on my wroncho and never got the interior because manual really don't show how it mounts.
01-30-2017, 12:06 AM | #24 |
Hey Robrick I got 2 sets of the drivers for the mini trophy So I took some pictures, the drivers are 2 pieces that over lap each other, There is 2 screws that screw into the spur gear cover on the transmission to hold them in place And there is tabs on the front of the drivers and in front of the cage, there are slots for the tabs go into Last edited by kgb424; 12-11-2018 at 01:10 AM. |
01-30-2017, 06:27 AM | #25 | |
| Re: Look at what I just bought Quote:
Sent from my XT1650 using Tapatalk | |
01-30-2017, 12:07 PM | #26 |
Hey Robrick Ebay has the un-painted drivers sets, that come with the stickers I think I bought the second set painted with the stickers already in place You might be able to find a painted set maybe I bought mine a few years ago Last edited by kgb424; 12-11-2018 at 01:10 AM. |
01-30-2017, 03:01 PM | #27 |
Here is a small parts list Bearing kit CVD axles shafts Motor Mount Diff gears Diff grease and Plastic Grease And Main Shaft Last edited by kgb424; 12-11-2018 at 01:10 AM. |
01-30-2017, 03:12 PM | #28 |
I found these Aluminum Tamiya OG wheels They would be bad ass If was going Rally/Pre-runner Or off road truck I'm going Street/Drifter Style Last edited by kgb424; 12-11-2018 at 01:10 AM. |
01-31-2017, 09:39 PM | #29 |
I'm having a really hard time finding a car body with a 12.3'' wheelbase for the HPI Mini Trophy I have been looking at 1/8th scale bodies and not finding nothing with a 313 mm or 12.3'' wheelbase either Did see some 1/8 scale bodies that had a 11.5'' wheelbase but not finding anything Also been looking at hard bodies and other plastic cars and again come up with nothing Don't want a truck body or short course truck body Last edited by kgb424; 01-31-2017 at 09:41 PM. |
02-01-2017, 09:31 AM | #30 |
Who know that a Traxxas Titan 12 turn that is a 550 size motor, fits in the TA chassis It longer than a 540, I thought the 550 was bigger in diameter its not, Will have too see if the 550 clears the Sand Scorcher body I checked it's at my local post office, so it should be here later today |
02-01-2017, 12:15 PM | #31 |
I ordered my upgrades Bearing kit to replace plastic bushings Main shaft to run more power Bevel gear sets for the differentials CVD's front and rear Motor Mount to use a brushless motor Diff grease and plastic grease Now I can run brushed or brushless with the upgrades Last edited by kgb424; 02-01-2017 at 12:32 PM. |
02-02-2017, 01:36 PM | #32 |
You know just got to be smarter then what your working on With the 10'' wheelbase the body was off and didn't look right to me The genius part is I flipped the rear swing arms and it shortened the wheelbase to 9.2'' Yeah Baby now the body looks dam good Need a some wide rims and tires for the rear and tires with more sidewall Last edited by kgb424; 12-11-2018 at 01:09 AM. |
02-02-2017, 02:32 PM | #33 |
I got these extra HPI Mini Trophy Drivers And they don't look too bad sitting in the Bug body Last edited by kgb424; 12-11-2018 at 01:09 AM. |
02-02-2017, 03:55 PM | #34 |
Wow Tamiya USA actually had the parts I needed in stock That's rare cause usually everything is out of stock |
02-02-2017, 11:02 PM | #35 |
I'm thinking I need narrow front wheels and wide rear wheels Cause the Bling Bling wheels fits inside the front fenders and looks a lot better than sticking out Like they do with the Axial wheels and the HPI wheels Last edited by kgb424; 12-11-2018 at 01:09 AM. |
02-02-2017, 11:58 PM | #36 |
Found some 20mm wide front wheels and found some 31mm or 34mm wide rear wheels But can't find a matching set, the fronts are different from the rear wheels |
02-03-2017, 12:35 PM | #37 |
I also love old School Chevy's this C-10 is bad ass, and almost bought one before I went with Sand Scorcher
02-05-2017, 01:14 AM | #38 |
I figured out how to make it work with out having to use wide rear wheels, I used my 11 mm wheel wideners And now I can use normal 26 mm wide wheels and use street tires or slicks or the hard plastic drift tires I can't decide if I like the 24 mm wide wheels which is the Bling Bling, or the 26 mm wheels which are the black Axial wheels Again the 26 mm is more common and a lot more options Doesn't look that bad actually with them sticking out passed the fender some Again need to be smarter then the RC your working on Last edited by kgb424; 12-11-2018 at 01:09 AM. |
02-07-2017, 12:35 AM | #39 |
I found some pictures of a couple Drifter VW Bugs I like them both, but not what I doing with mine Last edited by kgb424; 12-11-2018 at 01:09 AM. |
02-07-2017, 05:08 PM | #40 |
It had its first hard impact and broke the ball stud out that connects the front right upright too the steering arm It went exit stage right on me under throttle going from wet asphalt to puddles and it power slid into a curb and it was done for the day I found the dog bone easily cause I let off before impact and rolled to a stop quickly and that is the only thing that broke Last edited by kgb424; 12-11-2018 at 01:09 AM. |
Look at what I just bought - Similar Threads | ||||
Built not bought, with a bunch of things I bought. | imthatguy | Axial SCX-10 | 28 | 01-10-2016 08:41 PM |
bought fx-r | troy95chevy | Electronics | 13 | 08-23-2011 12:17 PM |
Anybody bought a new JK lately? | Harley | Chit Chat | 3 | 02-21-2009 12:29 AM |
Look what i just bought........ | mxracer525 | Tamiya TLT Crawlers | 7 | 06-17-2007 10:07 AM |
who bought this? | OIT_TLT | Chit Chat | 5 | 01-24-2007 12:24 PM |
