01-25-2010, 06:35 PM | #21 |
I wanna be Dave Join Date: Jan 2006 Location: ...the burning end of the rope.
how long is the shaft?
01-25-2010, 06:42 PM | #22 |
Newbie Join Date: Aug 2009 Location: queen city
| oops
nevermind be sure and make sure there arent pieces of packaging in the hole on your pinions when you try to put them on. thanks for making me take it off and measure the shaft. |
01-25-2010, 07:11 PM | #23 |
Rock Crawler Join Date: Apr 2009 Location: Saint Charles
Brand:fantom/Blitz Turn:45 Pinion front:13 Pinion Rear:12 Battery:1500 MAH thunder power 3 cells |
01-25-2010, 07:31 PM | #24 |
RCC Addict Join Date: Sep 2007 Location: Westland, MI
Brand:Integy Turn:45t Front 55t Rear Pinion front:12 Pinion Rear:12 Battery:G force 3s 1300mah 20C ESC:single Mamba Maxx DIG: micro servo controlled 22 amp micro switches Comments:The 45t up front gives more wheel speed for dig and climbing While the 55 has more torque to reduce stall but still give the rig a push. I have not changed pinions yet though I like the balance my rig has. The 1300 mah 20C lipo can last about an hour in my rig. |
01-26-2010, 04:30 PM | #25 |
I wanna be Dave Join Date: Dec 2005 Location: Gold Bar
Brand:JP warrior Turn:35 Pinion front:12 Pinion Rear:12 Battery:3s Comments:I used to run 11/12 and I haven't seen any difference runing 12/12 |
01-31-2010, 12:19 AM | #26 |
Rock Stacker Join Date: May 2009 Location: slc
35t integy v11 12 pinion f/r 1300mah 3s sooooo dam fast... prob need to limit it a bit.. however i did sell all my off road rc cars to fund this build. mayb keep some speed to keep me going. |
01-31-2010, 02:50 AM | #27 |
Rock Crawler Join Date: Oct 2006 Location: Germany
55t integy v11 12 pinion f/r 2300mah 3s Lipo E: Caste/Punk Fast enough for me and lots of torque |
01-31-2010, 08:40 AM | #28 |
Pebble Pounder Join Date: Dec 2008 Location: VP Auto
45t novaks 13 front 12 rear 8 cell going to 3s Tekin FXR Really fast for me. Had a 35r warrior in my shafty and the bully will smoke it in a race. May drop pinions. Stall is great. Just enough |
01-31-2010, 09:21 AM | #29 |
Rock Crawler Join Date: Aug 2007 Location: Orlando
JP warrior 35x2 LE's 12 front/rear 2200 2s but ordered 1300 3s |
02-16-2010, 09:49 PM | #30 |
Quarry Creeper Join Date: Jan 2009 Location: Irrigon
35 turn Fantom Blitz 12 tooth front 11 tooth rear 3s lipo 1250-1500mah Guess I never put mine in here, I also run FXR w/punk dig I love the wheel speed |
03-27-2010, 03:56 PM | #31 |
I wanna be Dave Join Date: Nov 2008 Location: Where freedom is earned.
Adding to the info here, I thought I'd add a tip on keeping the motors protected. Cheap tech: Hit the dollar section and grab some bottle that will fit over the motor can. I used a $1.00 "Stool Softener" bottle. Ha Ha. Dumped the pills and used the bottle after a bit of trimming. |
03-31-2010, 11:51 PM | #32 |
Rock Crawler Join Date: Aug 2008 Location: maple ridge
Updated the first post after more fine tuning.
04-01-2010, 06:12 AM | #33 |
Quarry Creeper Join Date: Dec 2006 Location: Finland
My successful setup Front: 12 pinion, 45t lathe Rear: 12 pinion, 55t Novak ESC: Mamba Max with PunkRC Dig <3 Battery: 3 cell LiPo |
04-01-2010, 07:40 AM | #34 |
Pebble Pounder Join Date: Jan 2009 Location: At the workbench
Motors:Integy 35t Pinions:13t front and rear ESC:Sidewinder, CC BEC DIG:micro switches Battery:HH 3s 1350mAH 20c Comments:35t seem waaaaay too fast, but I kinda like it. Stall is a little excessive, maybe due for a pinion change or a 45t in the rear. About 10-15 minutes run time. Changed front pinion; got rid of most of the clodstall but still has enough to keep from hitting the dig all the time. Last edited by PsychoCrawler; 08-12-2011 at 02:25 PM. Reason: changed pinion |
04-01-2010, 07:55 PM | #35 | |
04-02-2010, 09:26 AM | #36 |
RCC Addict Join Date: Feb 2008 Location: Nevada
Motor: 2 CKRC 45T Twisters Pinion: (F/R) 13-tooth/12-tooth Servo: JR DS8711 Dig: Punk Dig Switch Battery: 3S 1300 mAh So far so good Last edited by prusik333; 04-02-2010 at 09:28 AM. |
04-02-2010, 10:36 AM | #37 |
Newbie Join Date: Dec 2009 Location: L-ville
Brand: Holmes handwounds Turn: 45t Front and Rear Pinion front:12 Pinion Rear:12 Battery: 4s 1300 Comments: So far I like it, good wheel speed, but I may try a little more |
08-31-2012, 09:08 AM | #38 |
Pebble Pounder Join Date: Mar 2012 Location: Greece
| Re: Bully motor Thread
What pinion do you suggest me for more strength except stock,because i stripped my front stock 12t pinion? Thanks in advance. |
08-31-2012, 11:51 AM | #39 |
Newbie Join Date: Feb 2011 Location: San Tan Valley - Queen Creek
brand:Novac Fifty-Five motor:55t pinon:15 front, rear 13 battery: 2S ESC: Rooster Crawler Performance: I am new to crawling but as far as I can tell they have a ton of power and are pretty smooth. |
09-01-2012, 06:51 AM | #40 |
RCC Addict Join Date: Jul 2009 Location: Reno, Nv
| Re: Bully motor Thread |
