09-01-2012, 12:56 PM | #41 |
Quarry Creeper Join Date: Apr 2010 Location: Centurion, GP, RSA
| Re: Bully motor Thread
I have run various setups and going to test some more. For the price one cant beat these. Brand: RC4WD Turn: 35T's Timing: STD Pinion front: 12 Pinion Rear:11 Battery: 3S 1300 mAh I like this one. Brand: Holmes Hobbies Torque Master Expert Turn: 35T's Timing: 6deg Advance Pinion front: 12 too slow 13 Better Pinion Rear:11 too slow 12 Better Battery: 3S 850 mAh 65C disharge Too fast for me. Brand: HH Torque Master Pro cans with 16T CM hand wound armatures. Turn: 16T's Timing: 6deg Advance Pinion front: 13 Pinion Rear:12 Battery: 3S 850 mAh 65C Next up to test. Brand: HH Torque Master PRO TEAM 2012 Hand wound(cans from above) Turn: 35T's Timing: 6deg Advance Pinion front: 13 Pinion Rear:12 Battery: 3S 850 mAh 65 C Brand: HH Crawl Master Hand wound Turn: 20T's Timing: 6deg Advance Pinion front: 13 Pinion Rear:12 Battery: 3S 850 mAh 65 C All with dual FX-R's I just love HH motors! |
09-02-2012, 05:15 AM | #42 |
Pebble Pounder Join Date: Mar 2012 Location: Greece
| Re: Bully motor Thread |
09-02-2012, 06:18 AM | #43 | |
RCC Addict Join Date: Jul 2009 Location: Reno, Nv
| Re: Bully motor Thread Quote:
With 55t I would think you could run 15t pinions. I run a 13t in the front and 12t in the rear with 40t broods. I have thought about going up one on both axles. Pinions aren't to expencive, you might want to get a pair of 14's and a pair of 15's so you can expirment a little. I think the 15's would be the best with those motors though. As for a smaller pinion in the rear, if you run two esc's you don't really need a smaller pinion in the rear because you can adjust the bias (or premix) in the radio. But if your running 1 esc and a dig switch it is a good idea to have the rear pinion one tooth smaller so the front is always pulling a little harder. It will make the biggest difference on climbs when the rear wants to stall out a little so the front will pull down instead of the truck flipping backwards. | |
09-03-2012, 08:13 AM | #44 | |
Something else,Are those pinions the only that i can use on my bully or i have other choices? Bully Parts Dimitris | |
