08-31-2010, 04:32 PM | #81 |
Rock Crawler Join Date: Apr 2008 Location: Calgary
I just got my set up and I'm not terribly happy with the fit of it. The finish is great, all the edges are clean, the lines are straight, very well machined. One thing I am not happy with so far is fit. The spacer block is to wide to fit between the axle tube and the shock/link mount. The screw holes aren't lined up all that well to hold the servo mount to the spacer block. And the servo mount tab closest to the shock doesn't let me put my shock back on without using spacers. This just limits my steering even more than it already is. To make all of this work is fairly simple but it will require me to cut off one of my screw hole mounts in the ear of the servo as well as cut the mount back. Not really wild about having to cut a $100+ servo that is virtually brand new. I am running RC4WD shocks and they are very close to the Losi shocks but even the Losi shocks don't seem to work. Overall, not major issues and I should be able to make everything work but I'm just not too happy with it so far. |
08-31-2010, 04:42 PM | #82 | |
RCC Addict Join Date: Mar 2009 Location: Chilton
08-31-2010, 04:58 PM | #83 |
You shouldn't have to cut anything on your Servo. Don't cut your $100 servo. It's much cheaper to just fix the Delrin spacer. I'm sure you have tried. But have you tried flipping the bracket or Shorten the spacers to fit better. Let me see some pic's of your set up.
08-31-2010, 05:00 PM | #84 |
Hopefully Lance or someone from JP Customs will read this and give some advice. Like I said, I'm not to thrilled about cutting apart my 7950 just so I can use this link. I'd rather use this one as I really don't like the height and openness of the Xirtic mount.
08-31-2010, 05:14 PM | #85 |
I sent an email to JP customs with a link to this thread he will help out. I have always been told he is a great guy and will make things right. I think it is just a bad run of them. I got the spacer block to fit on mine it is the part the servo mounts to that is the problem. I am affraid to cut it it to much it will mak it weak around the mounting holes. I did try to cut it down a little and drilled the holes over a little but it still doesn't fit and my servo now lines up on one side and the other side lines up with the outer edge of the servo. Anymore cutting and drilling it will probably break with the torque of the servo. I am just putting my old steering back on for now. |
08-31-2010, 05:31 PM | #86 | ||
Lance isn't always on this board so I'll send him the link so he can see your concerns. | ||
08-31-2010, 05:33 PM | #87 | ||
I'd imagine that it is difficult to design this mount to work with all shocks and all setups.... Last edited by JeremyH; 08-31-2010 at 05:35 PM. | ||
08-31-2010, 05:35 PM | #88 |
| He posted while I was typing. I would put a pic up for him but I can't and I have already put my other steering back on now. Basically the only way I can hook it up is to cut one side way down and only bolt up one side of the servo.
08-31-2010, 05:36 PM | #89 |
Thanks Jeremy, I knew that but I didn't see his post. I was typing mine when his went up. I will get a pic up in a little bit. I have measured everything and it's like a mirror image so flipping it won't gain me anything. |
08-31-2010, 05:37 PM | #90 |
| That is definitely not correct. A pic would be really helpful. Can you measure the distance between the mounting holes on both the servo mount and the spacer??
08-31-2010, 05:45 PM | #91 |
| The problem is where the servo mounts on mine one side is lined up and the other side the mounting holes for the servo are just outside the ears on the servo like it is to wide. I have everything else modified enough to where the mount itself will fit but it took some cutting and redrilling to get it there. The servo will fit too but can only bolt up on one side without cutting on my servo. I am running a hitec 5955tg. the holes are about 1.75 inches across center to center on the servo and almost 1 15/16 inches on the mount for the servo.
08-31-2010, 05:45 PM | #92 |
Jeremy, I put my servo up to it and it may be big but only by about 2mm. I can deal with that. It's more than that that I need to mount the shock back onto the mount. Pic's are uploading as we speak. I will post up a link to them with a few different angles as soon as it's done.
08-31-2010, 05:49 PM | #93 |
08-31-2010, 05:56 PM | #94 |
Scott, yep, in this picture you can see the issue: I ground mine down a bit angled from the top (wider at the top and narrow at the bottom) if you dont want to space out the shocks. You can try inverting your shocks to see if it helps as well... If you want, I can try to get some pics of my setup this evening when I get home from work (about 3 hours)... |
08-31-2010, 06:06 PM | #95 | |
08-31-2010, 06:08 PM | #96 |
Inverting or shaving still won't get it quite close enough. I have already thought about that. I have about 6mm of screw left and it still doesn't even touch the mount. The servo is as far toward the gear case as possible as well
08-31-2010, 06:09 PM | #97 |
Rock Crawler Join Date: Aug 2008 Location: Strugglin
I had zero fitment issues with mine. I would'nt cut the ear of my servo.My shocks are inverted but not spaced out.
08-31-2010, 06:15 PM | #98 |
| I had to shave it to move it over some but it sounds like yours is worse than mine. They are to wide for some reason. Do your holes in the mount line up with your servo mounts or are they off too? Mine are off about as much as it was to wide to fit right.
08-31-2010, 06:24 PM | #99 |
08-31-2010, 06:29 PM | #100 |
I think what I might do is just make a new one, using Lance's as a template. I just need to make it a little narrower and not have any oxtra overhang towards the motor. Mine has both of these issues. I just need to get some delrin plate tomorrow and I'll see what I can do. Unfortunatley, even if a new one would be sent to me I would have to wait another 3 weeks because of cross border shipping. The idea is very sound and it looks like it works for almost everyone who has them but I am most definatley having some issues. I was going to just make this on my own but saw this one so thought I'd just save myself some time. I just looked at that picture again and noticed that the servo case is already cracked anyway. And it's not the ear I would need to cut off so now cutting that tab off is out of the question. |
