10-02-2012, 08:07 AM | #301 |
Rock Crawler Join Date: Sep 2009 Location: Orangevale
| Re: Stub's Dlux HALLSTYLE
Damn Stubs I think it the best looking rig I have seen you drive. Great job and once you get use to the open wheels you will love it.
10-02-2012, 12:50 PM | #302 |
| Re: Stub's Dlux HALLSTYLE |
10-03-2012, 05:43 AM | #303 |
RCC Addict Join Date: Mar 2011 Location: Way out there!
I am anxious to see how a lexan chassis works out. I have used it for skid plates and had it bust out around the screws. Is it a typical lexan or is it something special? Looks like a material I would like to try to work with if it holds up. How thick is it?
10-03-2012, 06:10 AM | #304 |
RCC Addict Join Date: Jul 2009 Location: Reno, Nv
The guy John (just won nats) that makes these chassis has been running them for a couple years now with out failure. There are quite a few guys from the BYB that have been running them for over a year. They are proven at this point. He makes them in two thicknesses. A thin one, which is the one I'm running, for people that aren't hard on there rigs. And a thick one for the more "when in dought, throttle out" type driver.
10-03-2012, 01:26 PM | #305 | |
| Re: Stub's Dlux HALLSTYLE Quote:
Wait you are a when in douht, Throttle out Type! | |
10-03-2012, 03:50 PM | #306 |
10-03-2012, 04:10 PM | #307 |
Rock Crawler Join Date: Feb 2010 Location: chin ckeck
it's looking good stubs , can't wait to see it run.
10-03-2012, 04:40 PM | #308 |
It is weird seeing you run a bodiless 2.2, but cool, I like it |
10-03-2012, 08:26 PM | #309 |
| Re: Stub's Dlux HALLSTYLE Thanks guys. I can't wait for your season to start. I will be down there for sure. Just remembered. 4.46lb rtr |
10-03-2012, 11:25 PM | #310 |
Very sweet. Looking very good |
10-06-2012, 05:31 PM | #311 |
I better start practicing then.did you gain weight with the chassis change?
10-06-2012, 07:54 PM | #312 |
Lost weight. It's working so good right now! Finally got some testing in today. I moved the front links up to the top hole in the chassis. Moving the links up seemed to help smooth out the front. I am enjoying all of the room above the links with this chassis. |
10-06-2012, 08:39 PM | #313 |
Rock Crawler Join Date: Feb 2006 Location: Cutting Comms
Love the Hall Style chassis. Best looking bodiless yet. At one point you posted being at 4.07lbs. Just wondering, how did you get it back to 4.46? |
10-06-2012, 08:47 PM | #314 |
Knuckle weights. The rock where I run around here I don't seem to need it. But I needed it at nats so I put it on and haven't taken it back off. I go back and forth.
10-06-2012, 08:48 PM | #315 |
With a bully you have a bunch of front weight without adding extra.
10-06-2012, 09:01 PM | #316 |
OK, I must have missed knuckle weight not being used at 4.07. Additional knuckle weight was my first guess. |
10-07-2012, 05:51 AM | #317 |
| Re: Stub's Dlux HALLSTYLE im right at 4.4 with my setup now,i did try it at 3.11 and 4.o but could not find that happy rtr weight untill i got to the 4.4 range too.
10-07-2012, 06:17 AM | #318 |
| Re: Stub's Dlux HALLSTYLE Ya, that seam like a very comfortable weight for me right now. How much knuckle weight do you run? And what foam? Rovers or sedonas?
10-07-2012, 06:31 AM | #319 |
4.7oz of knuckle weight's,shaved /narrowed donnas on the front shaved rovers on the rear,dd closed cell 5.5 wide soft front med rears.
10-07-2012, 01:59 PM | #320 |
Stub's Dlux HALLSTYLE - Similar Threads | ||||
DLUX 2.2 AND 1.9 wheels | Erik D_lux | Vendors Tires and wheels | 136 | 12-02-2015 08:24 AM |
catpwreds Hallstyle 2013 build | catpwred | EnRoute Berg | 26 | 01-02-2013 10:20 PM |
