05-05-2012, 08:38 AM | #161 |
RCC Addict Join Date: Jul 2009 Location: Reno, Nv
| re: Stub's Dlux HALLSTYLE
Ha cool. I don't think so. He is liking the super bully shafts for the bergs. I think where the axle engadges the locker is to big on the bully to make an XR axle fit. Plus Eric doesn't like the 8* kingpin. I don't like it either and prefer the route we have taken. It is the exact same as he does with the berg cases. I should have it up and running soon so we shall see how it performs! |
05-05-2012, 09:47 AM | #162 |
I wanna be Dave Join Date: Dec 2009 Location: Lady Lake, Fl
Looks good stubs I was judging on the T1e course that your battery died on. Couldnt believe you didnt have one in your pocket But you still did well. R u coming down to the next So Fl state comp?
05-06-2012, 01:13 PM | #163 | |
| re: Stub's Dlux HALLSTYLE Quote:
Thanks. You I think that battery cost me top ten. Haha I hope I can make it. | |
05-06-2012, 01:21 PM | #164 |
Finaly got the front end together. I will get better pics and a weight when I get the rest of the stuff from Eric. No laughing at the tierod, it's temporary until the ti ones get here. The axle is about 5oz lighter than it was with cast tubes. Its a little wide right now with 475 hubs but i have some 225's which should put it at 10 3/4" Heres a couple pics. |
05-06-2012, 01:30 PM | #165 |
Weird seeing a Bully with a wider axle. Are you able to keep the tires out of the shocks/links now? How did the .9's work out or will you not know for sure until you get your new hubs? For good measure I would suggest putting a set screw in the top and bottom of the C also. Its possible to get away with not doing it but I think it makes it much stronger and reliable with just those two extra screws. Again, it just looks more proper having some width and not gaining it by absurd scrub. I think you will like this amount of scrub. Not too much, not too little. It will be cool to see where you take this car. As I said in our PM, no more dealing with compromises now. |
05-06-2012, 02:00 PM | #166 |
RCC Addict Join Date: Jan 2007 Location: Bouldertown
Looks good stubs! Josh6575 is running wider bully axles. He is our r-n-d guy. He said its a trade off. I am running 850 hubs and 1/4 in spacers on stock axles with d-lux rims and am pretty happy with it. Puts me at a little over 10 3/4" |
05-06-2012, 06:15 PM | #167 | |
I feel this axle is the best of both. It has a lot less scrub than the stock bully axle but more than an XR. So it burns good but I can still move the rear end around. | |
05-06-2012, 06:20 PM | #168 |
RCC Addict Join Date: Mar 2011 Location: Way out there!
Stubs the more I run mine and get it dialed in the more i like it. I am at 10 3/4 all the way aroung with the king pins 1/2 further out on each side. Missing the reach, but all the pluses are starting to outweigh the reach.
05-06-2012, 06:30 PM | #169 | |
I really like it so far. Reminds me of the things I liked about the XR with non of the things I didn't. What happens with the C's with only 2 screws? The tires are so far from the links with the 475's. They will be close with the 225's but I am sure it will be fine. 11 1/4" is super wide to me but there sure are some benefits. I am getting 225's and 350's so I will find the sweet spot. The rear it to narrow for the front right now. It was working so good today without any weight added to the front. the truck is at 4lb 6oz right now. It would do all of the lines it normals would and one I have never made. The front is 7oz heavier then the rear right now. The balance point is right at the front of the skid. | |
05-06-2012, 06:38 PM | #170 | |
Is your rear 10 3/4"? If so, how did you get it that wide? I'm 10 3/8" with 850's and a 1/8" spacer. | |
05-06-2012, 06:48 PM | #171 |
Quarry Creeper Join Date: Feb 2012 Location: Adams, MA and Florida, MA
MY bully is currently at 11 1/4" wide in front by flipping the dh wheels and using the 835 hubs. I havent even driven it yet but just looks a lot more stable when I put it on the side of a board to see how much of an angle I can go on when sidehilling I could shave my knuckles for 50*+ of steering and just be rubbing the shocks. Great looking front axle btw. How have your delrin rear tubes held up? I'm thinking of trying my skills at the lathe and making myself some
05-06-2012, 06:56 PM | #172 | |
I drilled through 3 of the six holes in a set of dh hubs and screwed through them and the dlux wheel faces into a set of slw .75 hubs. I know it doesn't sound good, but It got me right where I want to be. Also drilled the centers out of the dh to let the nut and wrench pass through. Quote:
05-06-2012, 06:56 PM | #173 | |
05-06-2012, 06:58 PM | #174 |
| re: Stub's Dlux HALLSTYLE |
05-06-2012, 07:15 PM | #175 | ||
The huge scrub is sweet if it were nothing but reaching for ledges. I got super sick of the huge scrub because of the opposite effect, when I needed to get over a bump on a climb but had to turn while doing it, I would be over the bump but because I had to turn, my inside tire would turn so much that it would fall off the bump. Its the inside tire that lost so much wheelbase that really turned me off, especially when I had to grab a ledge with my inside tire instead of the outside, then it was a huge disadvantage. If youre using the 3mm screws they can be so small that over time they act like a cheese slicer in the delrin. It happened on my super VERY quick since there are more forces played on the C. If you look at the screws on the C you can also imagine how the C could rotate clockwise or counter clockwise when looking at the screw in the C from the front. If you put one on top and bottom the C could no longer rotate. Its captured from all 4 sides. To sum it up, just a much stronger solution. Quote:
Yep, Berg width from kingpin to kingpin. Its a bit wider over all from hex to hex though since they have the weird bully knuckle. That in itself is a small benefit though since the long snout acts as a knuckle weight of sorts and allows a narrower hub which in turn gives a lighter wheel setup. Last edited by Erik D_lux; 05-06-2012 at 07:19 PM. | ||
05-07-2012, 05:05 PM | #176 | |
05-07-2012, 05:23 PM | #177 |
Thanks for the links and knuckle weights Eric! |
05-07-2012, 05:29 PM | #178 |
This looks super nice man. Those tubes are awsome and the stance of this rig is nasty looking |
05-07-2012, 05:37 PM | #179 |
05-07-2012, 05:39 PM | #180 |
Oh ya, with the knuckle weights im sitting at 4lb 13oz rtr.
Stub's Dlux HALLSTYLE - Similar Threads | ||||
DLUX 2.2 AND 1.9 wheels | Erik D_lux | Vendors Tires and wheels | 136 | 12-02-2015 08:24 AM |
catpwreds Hallstyle 2013 build | catpwred | EnRoute Berg | 26 | 01-02-2013 10:20 PM |
