Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > RC4WD Bully
Thread: servo clearance??
Old 11-17-2013, 06:47 PM   #1
Default servo clearance??
How far can you grind the axle tube on bully lightweight axles for servo clearance?
tweak6 is offline   Reply With Quote
Old 11-17-2013, 07:08 PM   #2
Default Re: servo clearance??
I filed mine down to the bolt holes, I have a picture of it on my thread.
I could have gone further but it was just enough with room to spare.
CrAsHmAsTeR is offline   Reply With Quote
Old 11-18-2013, 05:37 AM   #3
I have had no issue with going all the way to the bore exposing the axle a little. Still plenty of meat in them if they are not turned down.
josh6575 is offline   Reply With Quote
Old 11-18-2013, 11:13 AM   #4
I don't know how I feel about going all the way into the bore of the axle, I would think dirt and all kinds of stuff would end up in there. That would be the easiest thing to do for clearance of the servo. I like the idea of going down to the first bolt holes better, but idk if that will give me the clearance I need for the 7980 servo. It's just a little nerve racking to take a grinder to a set of new axles. Thanks for the input.
Old 11-22-2013, 05:32 AM   #5
It's a little strange at first, but gets easy-er, trust me . You'll be cutting off gear box cases in no time, grasshopper.
Ace138 is offline   Reply With Quote
servo clearance?? - Similar Threads
Servo clearance? Beej Axial Wraith 6 10-29-2017 02:55 PM
Axial high clearance knuckles w/ servo on axle? Big Daddy Axial SCX-10 6 07-08-2013 11:32 PM
Wraith servo/winch clearance issues memphis_m3z Axial Wraith 0 06-09-2013 05:32 PM
Clearance issue-servo and box 07trd4x4 Axial SCX-10 6 03-14-2012 06:02 PM
65:1 bully motor pinion size and servo clearance. TedBull Superclass Crawlers 3 07-16-2011 09:30 AM
