04-21-2014, 01:59 PM | #1 |
Pebble Pounder Join Date: Mar 2012 Location: Greece
| Rc4wd Bully BUiLD
This project started aprox. 3 years ago.I have a lot of pictures of its progress that I'll post soon. Βully Artr KiT Motors 2Χ Tekin 55T Esc: Novak M2 Dig Bec: Casttle Creations Servo: Hitec 7955TG Battery Turnigy Nano-Tech 3s 1300mAh Futaba 4pl radio. |
04-21-2014, 02:44 PM | #2 |
| Re: Rc4wd Bully BUiLD |
04-21-2014, 02:55 PM | #3 |
After a long time I upgrade some parts. Upgrade to V6 front driveshafts. New servo position with some cut needed. New chassis and links from chaotic crawlers. New shocks,tires,dual fxr esc,servo (not too strong,just till buy a new cause 7955 hitec is dead). A homemade battery plate in 'dangerous' position. losi miniT springs some shock ball mounts from JeepinDoug Last edited by DiKey; 06-15-2014 at 10:11 AM. |
04-21-2014, 03:57 PM | #4 |
RCC Addict Join Date: Mar 2011 Location: Way out there!
Wow smoke is probably rolling off of your tools! That is a lot of work for one hour. Keep your eyes open for some light weight cases and tubes.
04-21-2014, 04:15 PM | #5 |
New servo Some cut on the tires Also made some holes to wheels and tires for better foam breathing. New Ti link for steering I painted the body panels https://www.youtube.com/watch?v=f4EmgHktmD0 Greetings from Greece. Last edited by DiKey; 06-15-2014 at 10:25 AM. |
04-21-2014, 04:44 PM | #6 | |
| Re: Rc4wd Bully BUiLD Quote:
I have on mind for lightweight stuff. | |
04-22-2014, 08:47 AM | #7 |
Some knuckles,axial chubs,delrin upper link mounts,front driveshafts,delrin tubes front and rear from Erik D'Lux,to loose some weight. Rear long stock tube Rear long delrin tube Rear short stock tube Rear short delrin tube Stock upper link mount Delrin upper link mount Front stock long tube Front delrin long tube Front stock short tube Front short delrin tube Stock knuckle Modified knuckle with 5 bearings v6 front driveshafts D'lux long driveshafts I messed up with servo mount but finally found some good holes to hold it.Delrin is very soft material when make holes for screws. Before After Last edited by DiKey; 06-15-2014 at 10:31 AM. |
04-22-2014, 08:54 AM | #8 |
The problem is that I have to find a solution on rear axle to make it longer,because the front axle now is quite longer than rear that is in stock length. https://imagizer.imageshack.us/v2/19...0/823/aaym.jpg Before After |
04-22-2014, 01:36 PM | #9 |
Looks like you took the ultimate leap. Chopping that top corner chunk off of the top of the gear case is another cheap easy mod. Also if you turn your front lowers end for end and stand them up vertically. The links can be brought over closer to the case to allow for more interference free steering now that you have more than is usable. For the width try to get around 10 3/4" to 11" out side of wheel to outside of wheel. That front has to be over 12"
04-22-2014, 05:29 PM | #10 | |
Because of servo position restrict me about left lower link. Also,two lower link-shock mounts has to has a symmetry on the tubes.You can see that the position of link mount I placed,is the best choice for the steering. Here you can see the links is as closer to the cases as possible. https://imagizer.imageshack.us/v2/70...0/853/a4l7.jpg Some more pictures of steering link Yes,front axle is little over 12'' and the rear is 10 1/4'' .I think slw hubs are a good choice to adjust the width,front and rear. Last edited by DiKey; 06-15-2014 at 10:48 AM. | |
04-23-2014, 08:14 AM | #11 |
Here is a mistake with one of two shafts. MOV00336 - YouTube I tried to fix it with an old shaft. Maybe need a new one. |
04-23-2014, 12:08 PM | #12 |
New foams from Crawler Innovations 6.0 inch,Soft outer foam front-Medium outer foam rear+Comp cut Side to old stock foam Here with stock foams Here with new foams At last pictures the rc is a custom wheely king. |
04-23-2014, 05:25 PM | #13 |
Knuckle weights from Erik D'Lux |
04-23-2014, 06:18 PM | #14 |
04-24-2014, 06:52 AM | #15 |
| Re: Rc4wd Bully BUiLD Last edited by DiKey; 04-24-2014 at 12:19 PM. |
08-05-2014, 12:04 AM | #16 |
Newbie Join Date: May 2014 Location: Oslo, Norway
What kind of tires did you replace the stock tires with? Any problems changing them?
08-05-2014, 04:31 PM | #17 |
08-07-2014, 07:53 AM | #18 |
Looks like you've done quite a bit of work here - with a pretty nice result. I am currently working on my Bully 2.2-axles. One of the things I'd like to improve is the steering angle. Do you have any suggestions of where to begin and what to do? |
08-07-2014, 09:44 AM | #19 |
RCC Addict Join Date: Aug 2013 Location: Calgary - in the Great White North
That thing's looking great. How do you like the Chaotic Crawlers chassis? I'm liking mine wight the new Bully 2 axles. Got an old chassis for my original axles which I'm slowly starting to put together as I get the parts.
08-21-2014, 06:04 PM | #20 | |
Fist step for better steering is v6 xvd driveshafts upgrade if you use stock axles.Then you can try a lot of things to achive a better steering angle.There are some threads you can take help and ideas. RC4wd Bully Steering Modification My Bully Build 4th 2009 Comp Rig The Bully Steering Thread Bully tips, tricks and parts list. Narrowed 2.2 axial rims...took 1/4" off width...trying for more steer! | |
Rc4wd Bully BUiLD - Similar Threads | ||||
1st crawler build RC4WD BULLY | bdth9447 | General Crawlers | 11 | 10-01-2013 02:44 AM |
--Another RC4WD Bully Build-- | jeeper_05 | RC4WD Bully | 88 | 05-14-2010 04:35 AM |
DNA Slingshot RC4WD Bully Build | CoolRC | RC4WD Bully | 7 | 09-06-2009 04:39 PM |
RC4WD Bully axle build up | Etype R | RC4WD Bully | 101 | 03-14-2009 12:47 PM |
