03-15-2017, 06:36 PM | #201 | |
| Re: Two Quote:
You see the slot, that's to allow the pin into the hex Hang up and Drive | |
03-15-2017, 06:36 PM | #202 |
Rock Stacker Join Date: Jun 2016 Location: Bulgaria
| Re: Two
The hub included in the kit is kinda 13-14mm long... According to RC4WD: 2x 7mm Offset Hex Hub (Silver) 2x 10mm Offset Hex Hub (Silver) 2x 13mm Offset Hex Hub (Silver) So .. it seems that we already have the longest hub. Dlux has 1/4'' spacers - Dlux Fab ... don't know if they can fit the stock rim. Last edited by ssh22; 03-15-2017 at 06:42 PM. |
03-15-2017, 06:40 PM | #203 | |
| Re: Two Quote:
I use these https://www.rpphobby.com/product_p/gea1240.htm Hang up and Drive | |
03-15-2017, 06:44 PM | #204 |
| Re: Two |
03-15-2017, 06:46 PM | #205 | |
| Re: Two Quote: Unfortunately they won't ship this to Europe ... go figure it out. Im interested if Dlux spacers can fit in the original rims. | |
03-15-2017, 07:40 PM | #206 |
Quarry Creeper Join Date: Dec 2016 Location: westlerly
| Re: Two Isn't the lug pattern the same on all the rims?
03-15-2017, 07:51 PM | #207 |
| Re: Two |
03-15-2017, 07:57 PM | #208 |
I wanna be Dave Join Date: Dec 2006 Location: here
| Re: Two
Dlux knuckle weights won't change width of your rig. Only the hubs and hex will change width of your rig. The rc4wd scale hubs I bought before worked with my 2.2 VP slw v4 wheels. Slw hubs should work on bully2 wheels. If you look on eBay there's knockoff slw hubs set of 4 12.00 Look at this on eBay http://www.ebay.com/itm/232268028457 Last edited by tapped-out; 03-15-2017 at 08:03 PM. |
03-15-2017, 08:26 PM | #209 |
I wanna be Dave Join Date: Apr 2015 Location: Roseville, Ca
| Re: Two
You only get those 3 hubs when you buy the replacement rims (like I had too). The biggest hub is the same as what's included with the kit/rtr. Im pretty sure vp slw hubs will work or you can do what I did and pick up some slw spacers that go between the hub and rim. Its cheaper then new hubs. RPP, dlux and dravtech all sell them.
03-15-2017, 09:34 PM | #210 |
Pebble Pounder Join Date: Jun 2014 Location: North California
| Re: Two
VP incision method hubs in bully comp wheels. There is a gap on every lug and the threads sit on the edge of the hole so no way to center the lug screws in the hole. Last edited by UGLY; 03-15-2017 at 09:49 PM. |
03-15-2017, 09:53 PM | #211 |
| Re: Two
Maybe VP incision method hubs are different then VP SLW hubs. They do look different.
03-15-2017, 09:55 PM | #212 |
| Re: Two
Yes they are different and use smaller size hardware as well.
03-15-2017, 10:26 PM | #213 |
| Re: Two |
03-16-2017, 04:57 AM | #214 | |
| Re: Two Quote:
03-16-2017, 05:05 AM | #215 |
Quarry Creeper Join Date: Dec 2009 Location: Strafford, NH
| Re: Two
SLW hubs will bolt up to the stock rim.
03-16-2017, 06:23 AM | #216 |
| Re: Two |
03-16-2017, 10:19 AM | #217 |
| Re: Two
Pretty sure there equal to VP .600 hubs. I can confirm later on.
03-16-2017, 10:25 AM | #218 |
| Re: Two |
03-16-2017, 12:12 PM | #219 | |
| Re: Two Quote:
Thanks for the heads up though. However they would fit over the axial unis I just ordered I think Last edited by Evo93; 03-16-2017 at 12:15 PM. | |
03-16-2017, 02:05 PM | #220 |
| Re: Two I think I will try with SLW hubs or the 1/4'' spacers from Dlux. I still don't know what slw hubs do I need .. if stock hubs are the same as VP .600 then I will probably need the .725 (.850 will be too much probably). |
