Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > RC4WD Bully
Thread: Two
Old 12-08-2016, 12:34 PM   #101
5th D Owner/Driver
cboggs's Avatar
Default Re: Two
Pink springs, and shorter rod ends. Put the shock in the top hole, last one towards the center of the car. With the longer rod ends you have essentially created a longer shock.
cboggs is offline   Reply With Quote
Old 12-08-2016, 06:12 PM   #102
Default Re: Two
Did some adjusting, rocks Saturday.....
Hang up and Drive
mikemcE is offline   Reply With Quote
Old 12-08-2016, 08:56 PM   #103
5th D Owner/Driver
cboggs's Avatar
Default Re: Two
Front still needs to come down a lot...
Old 12-09-2016, 05:53 AM   #104
Default Re: Two
I'm stumped ..... unless these are too tall, not sure how to get that low without going back to the stock shocks. I will get the calipers out tonight
Hang up and Drive
Old 12-09-2016, 05:58 AM   #105
Custom Carbon Fiber
Robbob's Avatar
Default Re: Two
By chance, are you sure your big bores are 3.5'' and not the 4'' ones? I dont recall if you mentioned what ones they were thats why I ask.
Robbob is offline   Reply With Quote
Old 12-09-2016, 06:04 AM   #106
Default Two
I think 4", not sure anymore
I'm wondering if the front are longer
Are the shafts the difference or the bodies ?
Hang up and Drive
Old 12-09-2016, 06:11 AM   #107
Custom Carbon Fiber
Robbob's Avatar
Default Re: Two
Hang up and Drive
Eye to eye measurement cap to shaft end. The bodies are different lengths as well as shafts but eye to eye is what we always talk about.
Old 12-09-2016, 02:01 PM   #108
5th D Owner/Driver
cboggs's Avatar
Default Re: Two
They look like the 4" ones to me, which makes them even longer with the cap mod plus the longer rod end.
Old 12-09-2016, 02:16 PM   #109
Default Re: Two
If they are 4 will they work ?
Hang up and Drive
Old 12-09-2016, 02:59 PM   #110
Default Two
Measured .... Rears are 3.5" no cap mod, fronts are 4" with cap mod 4.25"
That explains a bit.....
I'm going to reverse them for now, I'm stumped on the different sizes, I must have had a senior moment.... Coronas strike again !!
Hang up and Drive
Old 12-09-2016, 03:42 PM   #111
Default Re: Two
No, I would leave them. Stock fronts are 4" and rears are 3.5". I'm pretty sure you can buy new caps if you want. Or limit them inside, or just buy another pair of 2660 3.5" and swap over your caps. I'm sure you can use that 4" later on down the road. And remember you can get shorter bent rod ends too, rc4wd sells a bag or dlux sells them in two's.
84yoda is offline   Reply With Quote
Old 12-09-2016, 06:16 PM   #112
Default Re: Two
Thought the 2660 are 3.75"
Hang up and Drive
Old 12-09-2016, 07:08 PM   #113
Default Re: Two
2660 = 3.5"
2661 = 3.75"
2662 = 4"
Old 12-09-2016, 08:28 PM   #114
Default Re: Two
Well I'm confused by sizing, but numbers check .
I'm picking up a pair of 2660's and will transfer parts to them and the 4" will go back to the slash.
My dlux knuckles are shipped and will be here Monday
So I will try LHS tomorrow if not order up !
Hang up and Drive
Old 12-20-2016, 09:49 AM   #115
Default Re: Two
New CI foams, shorter shocks built, waiting on axle , Erik is making a new tie rod for me.
Hang up and Drive
Old 12-20-2016, 12:05 PM   #116
Default Re: Two
Now, you just need a KR4 rear axle.
Old 12-20-2016, 12:30 PM   #117
Default Re: Two
You are correct, do you need my address for shipping ??
Hang up and Drive
Old 12-20-2016, 12:36 PM   #118
Default Re: Two
Lol, Robbob will after payment.
Old 12-20-2016, 12:51 PM   #119
Default Re: Two
What!!!!!! You're not Santa ????
Hang up and Drive
Old 12-20-2016, 01:06 PM   #120
Default Re: Two
Ssssshhhhh there's kid's on this forum. Lol
