Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > RC4WD Trail Finder 2
Thread: BTA Shock and servo winch questions
Old 10-20-2020, 11:41 PM   #1
Default BTA Shock and servo winch questions
Ok y’all, I got a Marlin finally. STILL waiting on parts from rc4wd to fix the bf Goodrich but hey, this gets me crawling
Anywho, I decided to do some of the basic mods including the behind the axle shock mount and relocate the shock hoop.
The issue I’m running into is that everyone and all the pics I see show the shock standing vertical, and mine seems to lean back a bit at the top. Pic attached of it
Secondly, I’d like to run a servo winch on here, I’ve seen some people run a servo winch. I’d like to but I can’t seem to find an idiots guide to making that happen
Thanks!
DavidVonDoom is offline   Reply With Quote
Old 10-21-2020, 04:30 AM   #2
Default Re: BTA Shock and servo winch questions
For the shocks you'll need a longer spacer on the lower shock to make it work.
For the servo winch I've seen it mounted where you would mount a servo for the 2 speed shift servo along south brake tubing flared st each end running from the servo close to the front to guide the route and prevent chafing. I can't seen too fond thre video I saw. I'll post it if I find it.
Im sure someone else will also chime in.
Dirt Runner is offline   Reply With Quote
BTA Shock and servo winch questions - Similar Threads
Deadbolt 2 servo winch mount questions. SStone Axial SCX10 II 9 09-26-2018 07:08 AM
Servo winch questions ariel Electronics 4 07-10-2016 09:14 AM
bta with vp shock razors??? sacdrums Axial AX-10 Scorpion 11 04-18-2011 04:30 PM
ld racing bta questions guapotaco Axial AX-10 Scorpion 6 01-14-2011 03:25 PM
Motor break in and winch servo questions mudrinner4ever Electronics 2 05-01-2007 05:37 AM
