09-07-2013, 01:34 AM | #181 |
Rock Crawler Join Date: Feb 2009 Location: Wrightstown
| Re: AX2 2 Speed Transmission for Axial Wraith & SCX10/Honcho
I run 35t and that seems to be the best of both worlds. |
09-09-2013, 01:34 PM | #182 |
Newbie Join Date: Jul 2013 Location: Norway
How large pinion can the AX2 take before a smaller spur hav to be fitted? Is a 20T possible? Any suggestion on what pinion/spur combo will give 1th gear the same ratio as with the Axial gearbox? Sent from my LT25i using Tapatalk 2 |
09-10-2013, 08:44 PM | #183 |
Pebble Pounder Join Date: Feb 2013 Location: El Dorado Hills
| Re: AX2 2 Speed Transmission for Axial Wraith & SCX10/Honcho I don't know if anyone has gone bigger, but I put an 18t pinion on my 60t spur and had a teeny bit of adjustment left on the motor plate.
09-22-2013, 09:24 PM | #184 |
Quarry Creeper Join Date: Nov 2005 Location: Western, NC
I ordered my AX 2 tonight, and I know for the rear driveshaft I need the rear MIP C drive kit for the dig setup, but what front shaft do I need in MIP? And can I buy just the front alone, or am I stuck buying the whole set? I saw there is a combo kit for the AX10 with the dig rear and std front, would that work? Thanks
09-24-2013, 12:00 PM | #185 | |
Rock Crawler Join Date: Jan 2008 Location: Lehigh Valley, Pa
09-24-2013, 01:44 PM | #186 | |
| Re: AX2 2 Speed Transmission for Axial Wraith & SCX10/Honcho Quote:
I'm interested in one of those spur covers too, those are sick! | |
09-30-2013, 11:46 AM | #187 |
Quarry Creeper Join Date: Jun 2010 Location: Carson City, NV
So I have the RC4wd AX2 transmission and got it from a buddy of mine. He broke the output shaft and got the replacement one from RC4WD and the holes for the pins are drilled un equally. Can you guys swap this out? It's a manufacturing defect.
09-30-2013, 11:50 AM | #188 |
I wanna be Dave Join Date: Nov 2005 Location: Here
| Re: AX2 2 Speed Transmission for Axial Wraith & SCX10/Honcho |
09-30-2013, 12:00 PM | #189 |
I have, and have not received a response from over a month ago, that is why it is going here.
10-01-2013, 01:48 PM | #190 |
Rock Crawler Join Date: Jan 2011 Location: Blaine, MN
just was looking through a thread on RC Sparks and the guy was using the AX2 trans but he was also using super shafts ultimate motor plate or at least thats what it looked like. I thought if this does work it would make the AX2 a better choice.
10-01-2013, 03:46 PM | #191 | |
Quarry Creeper Join Date: Oct 2011 Location: Land of earthquakes
I installed the HD output shaft and broke the Axial HD pinion from the rear differential, so i believe the HD output is pretty tough, or the Axial HD pinion was so abused that just can't take it anymore. Anyways i have a new HD ring/pinion installed, i'll find out what die first, output shaft or pinion | |
10-23-2013, 04:02 PM | #192 |
Looks like I'm going to have to go to the Slash slipper setup, after installing the pro4 I can't get the stock one to hold at all. I even tore it down, scuffed up the slipper plate and cleaned / de-glazed the slipper pad, but no dice, it don't like the pro4. |
01-19-2014, 11:25 PM | #193 |
Newbie Join Date: Jul 2013 Location: Adelaide, South Australia
How are you guys mounting micro servos? I cant find many images :-)
01-31-2014, 02:24 PM | #194 |
I wanna be Dave Join Date: Jun 2008 Location: Sin City
| Re: AX2 2 Speed Transmission for Axial Wraith & SCX10/Honcho Did you try a dab of red loc-tight on it?
02-13-2014, 09:45 AM | #195 |
Newbie Join Date: Jan 2014 Location: The hills
02-13-2014, 10:45 AM | #196 |
It's a very good transmission, I have two and haven't had any problems at all. But if you are not going to use it as intended, like put a monster brushless motor on it, don't get pissed when it breaks. I don't know about there c.s. because I never had to use it. One person having trouble should not scare you away.
02-14-2014, 08:03 AM | #197 |
Quarry Creeper Join Date: Jun 2007 Location: east michigan
I have the AX2 2speed from RC4WD in my Axial JK Rubicon. It has been a great trans so far! Heck I thinking about getting another! I haven't broken mine yet with a Holmes hobbies BRXL and 27 turn stock brushed motor on 3s lipo. BTW 1st gear is so creepy crawly, I just love it! I don't get to rough with my rigs, and I do take care of them very well. The best advise I can give is NOT TO SLAM the trans into 1st gear from 2nd gear (hi-speed) to slow it down. (Thats what the throttle control is for.) Also DO NOT SLAM from forward to reverse or vice versa. This puts so much abrupt stress on the entire driveline, this is especially the case for you brushless motor users. Or people who run weight in their wheels. Remember that rotational mass of all that weight needs to go somewhere, so the weakest link is going to give. The mount for the shifting servo has 2 mounting points 1 to allow standard size servos and 1 closer to accept a micro servo. Just move the 1 mount closer to the other for a micro servo installation. The standard size servo is the easiest to setup on this trans, where as the micro servo takes a little work. Still no biggie. Hope this was helpful. If you do get 1 you'll love it! Last edited by dwblue00; 02-14-2014 at 08:10 AM. |
02-14-2014, 10:30 AM | #198 |
Quarry Creeper Join Date: Oct 2011 Location: New Mexico
So I know this product was released some time ago but hopefully people still check it. I bought one of these and ran it for the first time last night. I have it in a 1/6 new bright hummer and so far I am pleased with it. However, I am running revo shafts and the yoke that attaches to the front output of the trans is pretty big therefore it only allows me to run an 48p 80T or a 32p 52T Spur. I cannot shave the yoke down due to the crosspin requiring e clips. Currently I have a 21T pinion (a 20 is too small) that gives me a lowest possible gearing of 3.8 on a 1200kv tekin roc412. The truck is too fast on 3s and I'd like the gearing to be at a 7-10:1 ratio. Questions: Is there a longer front output on the market for this transmission? Will an wraith trans output fit in there? Should I abandon the 80T spur/Revo shaft and run a wraith driveshaft to get my spur size back? Reason I ask is because if I stick with 3.8:1 then I will buy a 500kv tekin 412 and run it on 6s. |
05-14-2014, 09:40 AM | #199 |
Newbie Join Date: Dec 2012 Location: Mississauga, ON
GUys what motor you suggest for this Transmission? $$$ is no issue so prefer to buy once but good! I will be mostly crawling and no speed runs
05-19-2014, 09:16 PM | #200 |
Rock Crawler Join Date: Feb 2011 Location: Spur, TX
I think this transmission is pretty forgiving as far as motors go because of the variable gearing. However the pinion and spur gears you choose are pretty important. For the motor you plan to run and intended purpose, choose spur/pinion gearing in between the high/low gear range for the best of both worlds. Regardless of what you choose I would recommend getting the Heavy Duty Outputshaft for the AX2, the stock output has weak points at the internal e-clips (as noted previously in this thread) and tend to sheer there. Just learned this the hard way with my pro4 powered wraith. |
AX2 2 Speed Transmission for Axial Wraith & SCX10/Honcho - Similar Threads | ||||
Axial Wraith & Honcho | Trailing in the Forest | burtonkidd | Videos! | 1 | 01-15-2012 03:47 PM |
2 speed transmission for honcho | Dfrog | Newbie General | 18 | 03-28-2011 07:52 AM |
