05-31-2013, 07:10 PM | #161 |
I wanna be Dave Join Date: Nov 2005 Location: Here
| Re: AX2 2 Speed Transmission for Axial Wraith & SCX10/Honcho |
06-23-2013, 02:59 PM | #162 |
Quarry Creeper Join Date: Oct 2011 Location: Land of earthquakes
After a lot of use and abuse i broke my output shaft today: Now i'm upgrading to the HD one |
07-09-2013, 04:43 PM | #163 |
Newbie Join Date: Oct 2005 Location: Cambridge
I will be picking up this tranny in a couple of days for my JK kit I'm building. After running through this thread I'm just wondering if I should really worry about the HD shaft since I'm not really planning on running 3s or a high torque motor like the Pro4's that some people seem to be doing. I'm only really planning maybe a brushed 27t.
07-10-2013, 08:57 AM | #164 |
RCC Addict Join Date: Jul 2008 Location: Fox Valley WI
My buddy and I have been running 3S and 35T motors with this trans for months, no issues. I just ordered my 3rd . Once you go "2 speeds" you can never go back!
07-10-2013, 09:22 AM | #165 |
Rock Crawler Join Date: Feb 2009 Location: Wrightstown
x2 from the buddy, I love this trans. Wish I had the money I would buy 3 more. |
07-10-2013, 04:28 PM | #166 |
Thanks guys that's what I was hoping. Actually if it wasn't for this tranny I don't know if I would've bought the truck. I like the idea of being able to do double duty having the 2 speed.
07-16-2013, 07:23 AM | #167 |
Pebble Pounder Join Date: Feb 2013 Location: El Dorado Hills
Is there any ETA on the HD output shaft being back in stock?
07-23-2013, 05:49 PM | #168 |
Rock Stacker Join Date: Mar 2011 Location: sacramento
Any possibility of different internal gearing options in the future?
08-10-2013, 08:12 PM | #169 |
Rock Crawler Join Date: Jan 2008 Location: Lehigh Valley, Pa
I wiped out mine yesterday. Haven't taken it apart yet, but no rear drive but everything still appears attached. Should be interesting. I got about 6-8 packs on it. Hope the HD shaft comes in soon.
08-14-2013, 10:49 PM | #170 | |
| Re: AX2 2 Speed Transmission for Axial Wraith & SCX10/Honcho Quote:
EDIT: Just ordered 2 Last edited by aqwik69; 08-15-2013 at 06:51 AM. | |
08-17-2013, 12:09 PM | #171 |
It was in stock yesterday. Good news for though, apparently I busted a m4 traxxas pin that's in my punisher instead of the output, so rafter I got the pieces out and stuck a new pin in, I am back in business.
08-21-2013, 02:41 PM | #172 |
Needing some suggestions on a shift servo, mine was just an old hitec i found in my spare parts bin, it gets a million degrees no matter what I do so I'm going to pick up a new one. Any suggestions guys. looking for something affordable Last edited by StEv0; 08-21-2013 at 03:36 PM. |
08-21-2013, 03:59 PM | #173 |
I am guessing your servo is probably getting super hot because of an end point problem, or lack there of? I am just using some low dollar metal gear servo on mine, but have also used plastic geared one as well. A 645mg or something similar is probably more then enough, but I would make sure your end points are setup good. Tim |
08-21-2013, 04:08 PM | #174 | |
08-21-2013, 08:01 PM | #175 | |
Dial down the EPA so that it doesn't max and over heat. Then just turn up the EPA until the tranny shifts. Other way is to just dial back your setting now until the servo stops humming. | |
08-21-2013, 10:44 PM | #176 |
After about an hour of adjusting and readjusting i think i got it figured it out.
08-21-2013, 10:54 PM | #177 |
Pebble Pounder Join Date: Feb 2012 Location: NTG Racing - San Diego
Just to let every one know, I asked RPP to add the AX2 HD output shaft and they have and they are in stock ready to ship. My account just got smaller |
08-22-2013, 04:32 PM | #178 |
| Re: AX2 2 Speed Transmission for Axial Wraith & SCX10/Honcho I'm running a Hitec 65mg mini servo underneath and so far it's held up to hundreds of shifts. I think it was $24.99
08-23-2013, 08:59 PM | #179 |
08-28-2013, 10:32 AM | #180 |
Here's my alternate setup which leaves room for the battery crossways on the chassis just in front of the trans. After some "hit or miss" shifting issues, I put a thin slice of fuel tubing under the ballends to eliminate side to side movement. I used an Axial axle mount servo plate bolted to the frame.
AX2 2 Speed Transmission for Axial Wraith & SCX10/Honcho - Similar Threads | ||||
Axial Wraith & Honcho | Trailing in the Forest | burtonkidd | Videos! | 1 | 01-15-2012 03:47 PM |
2 speed transmission for honcho | Dfrog | Newbie General | 18 | 03-28-2011 07:52 AM |
